one eye
Everything posted by one eye
  1. I got some videos and pics, it was raining and Snowing pretty hard so I didn't get to many, I'll upload a few after bit. I killed my doors and woody tried to put a bullet in his sedan, but other than that very little damage was done, Next run I think welded rearends will be a must, John did pretty good considering but still had trouble. The jeep of course did very well but the other jeep was on its first run ever so he took it very EZ. I'll post up some vids real soon ......................... Jeff
  2. Does thurston Co. ORV park have hard core trails? Jeff
  3. Are you still in Scott? Jeff
  4. Rick is out, TOD couldn't get fixed, so he S-canned the whole motor. There should be four Subarus and a couple Jeeps and one Toyota. Jeff
  5. Should be pretty warm, and raining, as long as your fan is blowing you should be fine. Jeff
  6. NW Washington Offroad http://www.youtube.com/profile?user=jpjumbo87&view=videos The second one is my fav. Jeff
  7. Rain!!! Should make for a little more fun. http://www.komonews.com/weather/planner Although Accuwheather says 48 and feels like 38 with a chances of rain, I don't dought Steve Pool but.............. he has been wrong before. http://www.accuweather.com/us/wa/mount%20vernon/98273/forecast.asp?partner=accuweather&traveler=0&zipChg=1&metric=0 Jeff
  8. John did you replace both of those rear blocks with the wider ones? Jeff
  9. +1 If it has done it long enough you'll have to replace the cone washer and dome washer, its like it gets little metal filings in it and it will end up backing off again in a few days.................... Jeff
  10. Eric the crazy thing is Todd uses that Brat as pretty much one of his everyday drivers to this day!! I can't wait to do this meet, I think there are going to be 4 or so of us coming down for it, kinda hard for everyone to say yes for sure, They might be back to work by then. Jeff
  11. Well that now makes 5 of us so far. Jeff
  12. Well the battle has come to and end................ the gasket was folded over and causing it to leak mess load everywhere. The mystery is over.... it was the Gasket. Jeff
  13. Thats what it was on the old one but this one seems to have water running running more freely, to the ground. Jeff
  14. The only thing we didn't check was the water pump itself, but that seems real hard to belive that it, being new, would leak the same way as the old one, I guess we'll have to dive back deep into the EA82 and see WTF. Kinda of a bummer considering where it is located...........:-\ Jeff
  15. Very Nice!!! You're getting close to having a sweet ride. I'll send you a PM about what we talked about last week too!!! Jeff
  16. Rick is in and woody too!! Jeff
  17. Its one of those Napa brand new ones............. Jeff
  18. So.............Today Dan and I figured we would change out the water pump since it was leaking, after getting a new water pump from Napa and cleaning the gasket very good and it is leaking down through the t-belt covers at a very good rate. It looks like it is coming out of the bottom of the water pump again, Is the any where else it could be coming from, it has a new gasket, new pump, and tight bolts and hoses................... what else could it be????? Jeff
  19. I would like to see it up north a bit. Bit that's just because I live up this way and have little faith in long distance drives with my wheeler wagon. Jeff
  20. Rick's went the same way yours did, But mine broke in the rearend. So As I tried to pound the axle off the stub started to walk out of the housing. Jeff
  21. This is the problem area Jeff
  22. Live rear axle and you're good to go!! Jeff
  23. I Was thinking the same thing, just a metal ramp, like for loading a lawn mower would do the trick. Jeff
  24. The last run up to walker was a bad run, 3 out of the 4 of us where knocked off in the first ten mins of of wheeling. So might as well try it again on Saturday March 14th, I think it would be cool to try and go up in the gravel pit and go up upper Mainline, trying to get around the gate at the lower side is just going to tear everthing up, there is no good way to get by there, you just drop down on your axle and bust the rearend or the shaft coming out of it. anyways............thats the plan.............. Meeting place @ GI Joes at exit 227 mount vernon 9:00 AM Jeff
  25. Was that one up north somewhere? I see it is on 92.9 kism---Bellingham! Maybe I'm wrong, but it was worth a guess:) Jeff
