Everything posted by HATCHY
I was up exploring mt saint helens,, and there is a ton of 4x4 up there. I was wondering if anyone else has checked out that area.. I was just wondering if it is worth my time to go back up there wheeling
rwd is it hard on the transfr case
HATCHY replied to HATCHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice Ill keep that in mind I think im going to try to do it sometime soon.. But I dont know I only own one subaru right now and its summer. which means alot of camping -
IS THE BALL INTHE BLOCK SIDE OF THE PUMP OR IS IT IN THE ADAPTER PLATE. OR ON THE PUMP ITSELF.. I BROKE THE PLATE TRYING TO GET IT OFF NOW i HAVE TO CHIZEL ALL THE FRAGMENTS FROM AROUND THE THIG.... IM SO UPSET RIGTH NOW
willit mess my pump up if I dont have it in when I reinstall. I dont get it why the hell is there a ball there?/ will anything else work?? Or do I have to go buy a whole new pump now?
Oil Pump People Keep Saying There Is A Ball Like A Bearing But I Just Looked At 2 Oil Pumps And Didnt See One.. There Is Supposed To Be A Ball In Trhe Spring Or Under It Or Something
Is there supposed to be a lose ball bearing under the spring that goes into the pump.. or is it just a spring.. cuz I have no ball bearing there
is there supposed to be a bal bearing under the spring... ? if so I dont have one!!!!
I took my oil pump apart.. does that spring in the oil pump back in with the FAT SIDE UP OR FAT SIDE DOWN??? INTO THE PUMP p0lease help
Any body tried those drilled slotted rotors they have for the older soobs?? I want to get them but I think its almost pointless.. anyone have anythng good to say aabout them
Crap a CV! Can anyone help?
HATCHY replied to yodannyc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pick A Part. probably 20 dollars at most. for a used axel -
or even in small events.. Like a 75 hp class .. That would be sweet
Ive heard that awhile back they had A rally course at SIR. or Kent international or wahtever.. Does any1 know if this still exists? I looked on the webpage and they didnt have anything about it.. And I was wondering if it open to the public to come race it.. Like solo or in small groups. /
Dude when your messing with your suspension.. You dont want to go cheap. At least spend like 300$.. I bet the stock suspension is better then and 80$ set oF coilovers.. especially if you plan on like racing and taking a bunch of corners
Dam I should be able to get some cash up too my aunt has ms and shell donate,, I worked the ms walk this year.. Ill see what I can do too
THANKS FOR THE HELP I ACTUALLY USED A SCREWDRIVER AND LOCKED ON TO THE FLYWHELL AND GOT THE PULLY OFF THANKS FOR THE THOUGHTS I WANT TO TRY THE ROPE ONE TO THATS A GOOD IDEA:cool:
'87 GL--problems engine over 2500 rpms..please help!
HATCHY replied to Leaker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
weber redline 32/36 electric choke -
yeah no doubt cats are like really expensive.. I think your mechanic should sit down and read a little about an old soob!! but that sounds just like a carb problem .. my freinds ea71 carb chokes out kinda like that not as bad as yours but its getting there.. buy a rebuild kit for like 50 bucks.. or go get a new weber hahahaha weber pwns:headbang: -
EA71 rebuild or replacment questions
HATCHY replied to rsb's topic in Historic Subaru Forum: 50's thru 70's
ford airbox??? -
I thought about converting to rear wheel drive for like a month or something.. I want to know if this is gonna be hard on my diff.. cuz i really dont want to have to repair that.. for a little in the rain drifting fun. even though we have extras alot of extras at pull a part//// so will the rwd driving hurt my transfer case????
I would start now with the carb either rebuild it or spend 400 bucks and get a weber.. then youll be able to deliver pizzas a little faster and a little funner -
i DONT THINK THRE IS A SENSOR LIKE THAT IN HIS SUBARU.. SOUNDS LIKE YOUR CARB IS PEICE OF CRAP OR YOUR FUEL PUMP OR SOMETHING LIKE THAT.. IT SEMS LIKE FUEL DELIVERY -
Which Guy Was It That Big Fat Guy With The Beard He Didnt Mark Something I Got Before Either.. Im Thinking About Going And Getting A Paint Marker.... And Well Taking Back Some Parts.. If You Know What I Mean
Im trying to get my oil pump off I got it of But I cant clear the main pully.. How do the pulley Off. Clockwise or counter. And I cant get my flywheel to stop moving when I wrech on it.. its i:banana: n 4 wheel drive and reverse but it wont lock it up.. ANY SUGGESTIONS.. NOW i have two broken punches floating around inside my tranny and a brocken screwdriver!
So my dad's not a big Subaru guy...
HATCHY replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
subaru 4 life... -
Car wont idle at times, maybe the EGR?
HATCHY replied to BlindSight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
probably some vaccum lines in the wrong spot or like 1 tiny one not pluged in or a whole in it.. I dont know I had the sane thing happen to me. But I adjusted the idle screw to fix it. Ive had vaccumm problems befoer too though. Pcv may make it run like idle liek crap i think! I dont General Disorder knows most
