94 SVX with oil in the rad.
Gl-boost replied to Gl-boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, I checked the atf its normal not mixed so its engine oil. I just din't know if I am going to get it though. Im still decideing on a bunch of cars this is just one I have liked and thought about.
I looked at this really clean 94 SVX with leather and AWD. The guy says head gasket but its not smokeing any antifreeze out the exhaust and it runs dam good and smooth. only problem is oil consumption in the rad, its sucking oil in to the radiator and I wanted to know if these cars have oil coolers in the rad that could have broke. So let me know what you think, thanks.
steering wheel swap
I put an 94 Mazda MX6 steering wheel on my 87 GL-10. It is an airbag whel but I took out the inflator, and there is no Mazda emblem in edged into the wheel ither. It just says air bag. Its a three spoke and preferated leather. Here is a pic, just click the link and then click enter. http://www.imagestation.com/album/pictures.html?id=2106836952 I think it looks good and its not a whimpy stock wheel. I had to modify it a little to get it to work, but its been fine, only my cruise is not hooked up but I havent had the time to mess with it, and the only other thing is the turn signals don't shut off automaticly when you turn the wheel, but they rarely did that with the stock wheel.
Pneumatic Suspention Tip #64009
The previous owner took out my air struts to, would have been cool if they still were there and working. I still have half the air suspention stuff thouh in the car, don't know why he wouldnt have removed it. .
Leaking GAS! (3.00$ a Gal.!!!) What is this part?
ok then, I didn't mean to steal your thread but thanks for the help also.
Mine leaks from ther also, but its a very mild drip. I have a leaking gas tank so that is my main concern right now. I just have to find the time to drop it, and well since the rear had to be droped also just to take out the dam tank. It sounds like a good time to me . I just hope all goes well, and nothig breaks such as bolts.
Relocate the battery
On my 86 BMW 325es , my battery was in the trunk. I find it like this in alot of BMW cars but some had them under trhe hood also. The battery cabble was routed through on the side of the rear fender well on the passengers side, I think it then went into the floor and was in the inside of the car along the rocker panel area and then went into the engine compart ment. That would be a rather large piece of cable, and my BMW had a large fuseable link. It was about half a foot from the battery in the cable itself. So it was cable then fuseable link then the rest of the cable, if you get what I mean. So if you could find a older BMW and get the cable out, it should work. I think it will be long enough. I think all 325,e,i,es,is cars have trunk mounted batteries, and that the 318 models had them up front under the hood. Hope this helped any.
3AT Govenor woes, How can I finalize the fix.
Well I just completed my cleaning for the third time. I used a dremmel with a rounded bit and did it best I could. I will post about its progressive state.
Modifier's delight
Leon, did the large ic pipe come of a Saab 9000, it looks like the pipe I have in my parts bin. I was looking at an ram air system to, I took out the silencer in the fender well the other day and it looks like you could run a pipe from the side of the fender well to the front of the bumper right behind the right turn signal. The only problem is you would have to relocate the turn signal.
Ok then, I will try that out. I just didn't want to damage anything. I will also try the sharping stone way.
Modifier's delight
Yes, on my 87 turbo sedan the hard starting was due to a bad connection at the CSS(cold start sensor).Its probly called other names but thats what I call it. On my turbo engine it was located behind the air intake hose to the turbo inlet. It is in a PITA spot but when you unplug it im sure it will be corroded.Clean it up on both ends and put a dab of grease on it to help stop it from happining again. Same for the idel connector but this one is easy to get to its right on top of the engine in front. Mine was corroded also so just clean it up and it should be fine again. Hope this helps allitle.
I wa swiating for that reply, . How ever, as much as I like to my car has a substantial amount of rust/rot on the underside of it. It is not worth it for me to get to involved in a swap. I just want to fix the govenor so I can drive it long enough to just save money for a new car, then I have plans after I buy my new car to take my motor and various GL-10 parts and get another sedan with the 5 speed in it already. I just have to find one.
I have had tranny shifting issues with my 87 GL-10 turbo since I got it, previous owner said needs a tranny its slipping:rolleyes: well we all know the case of that:D . I have taken it apart twice now and it is fine for about four days then starts acting up again. I have the fix thread and clean thread bt I cant seem to get it good enough. I want to know is what is the best and most efficent way and tool to buy and use to clean and debur the edges of the spring loaded part of the govenor. I did it nice and easy before, because I was affraid to damage it, but what is best to use and do. Also can I smooth the edges down enough to visually see a curve. Oh and its not apple cored.
Resurrecting 87 GL...
I could help you out with this one. My 87 GL-10 Sedan turbo 4WD was in by the previous owners driveway but in the field type brush part not on black top. Was there for about a year and a half but I have had not had much rouble. Only time it broke down was when my coolent turbo hose blew apart, but I managed to drive it home. Expect any rubber items to be dry rotted and cracked. I had to replace two tires. Check for frame rot from siting. Oh and expect a mouse nest in the HVAC system, I had one and I found it alive in my trunk compartment. Hope this helps some.
i have too much free time.
wow, I want it. Thats it you have helped me make up my mind. I want another turbo sedan. Five speed though. I like it alot, it looks great, I like the sedans better than the rest of them. I thought you were talking about being bored. I got bored in study hall today, so I printed some of those paper soob cars on here and made one:rolleyes: My friend thought I was crazy but when he found a brat he made one to.
Gl-boost
