Everything posted by Hocrest
The rotor can move somewhat when you have the wheel off since the wheel and lug nuts is what holds it solid to the hub. The caliper will move perpendicular to the rotor, as long as there is no other movement you should be OK. If the disk brake pads look good. It could be the drum brakes that are used for the parking/emergency brakes. To check them, you'll have remove the caliper bracket and then the rotor/drum will lift off. If it isn't the brakes, my next guess would be wheel bearings. My SVX made noise for a year or so before I got it repaired, but you probably shouldn't wait that long. Are the tires matched front to back and side to side?? And you should probably post over at http://www.subaru-svx.net Most of the folks here don't have an SVX...
In the area that we are in, I would recommend the cheap snow tires at your local tire shop. I've paid $40-50 depending on the size. And with the AWD they are as good as you'll need. I got two winters out of them on the Legacy, probably about 20-25,000 miles. They pulled me through the occasional deep stuff and when the highway was covered with snow and slush, they allowed me to fly up and down Rte 81 at near normal highway speeds.
CT Cookout..Who wants one?
Hocrest replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
I uploading them now.... Go get an Ice Cream cone, they'll be up in a bit... Here ya go.... Photobucket linky -
I stopped by a body shop on the way home this morning, they should be able to fix it for about $450 :lol: Seriously, that trim screw has been missing, you didn't break anything. Thanks for having us up there. John, glad you made it home safely. Paul, you need to learn to put Soob events on a higher level of importance than a family event. I mean come on, you see your family every day... How often do you get a chance to see US. Connie, so you got to "hear" the racer's new exhaust. What do you think?? -
I've "topped off" my Legacy every 300 miles for 205,000 of it's 245,000 miles and have never had a problem. I did recently have a problem that the bottom of the filler pipe rusted out though. Maybe pull the cover that is under the rear seat or in the trunk to see if you can find the source of the leak??
Yeah, we know... That's why we all speak slowly and use "little words" when you're around :-p -
I stopped in Yonieville today to pick up 2 dozen ears of Bread and Butter .... YUMMM It looks sweet and juicy :slobber: The best part is that as I was driving away from the roadside stand, Bucky's twin pulled into the stand :D:D -
You made the right decision... Best bet is to give me a call sometime, or PM a number for me to call... -
CT Cookout..Head Count
Does anyone know how to let Jesse know about this? -
Saab wheels and sube == saabube?
Hocrest replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
These are the "Sunburst" rims from the USMB wheels page; These are the ?Saab? wheels on Jesse's Brat; -
"Saab" was stamped on them somewhere?? Or maybe I'm completely wrong? -
I know of a member that has Saab wheels on his Gen 1 Brat. I'm not sure what year Saab they are from, but they do have some years that fit. Here is a picture; -
We had a FWD Imp transmission in our AWD SVX racer for a short time. The wiring was plug and play. At WOT it didn't shift right from 1st to 2nd, We would have to go off the gas as it shifted. But otherwise all was fine. At the rear, either he can leave the rear diff and axle's in place or remove them and source a couple of axle stubs off of a front wheel drive imp or leg.
Probably, we would be leaving the WB/Scranton area sometime around 11. Give me a call when you know what your plans are... -
PA Corn :D
CORN!!!!! Looks like a lot of food, don't get too carried away;)
De-powerizing the steering?
Hocrest replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can you tell me how many turns it is stop to stop on the manual rack?? Me and Ben are considering getting rid of the PS on the SVX Racer. The two options right now are; adding an XT6 pump or putting on a manual ea82 rack. -
At times:cool: but the PO abused it... If I knew what I know now, I would have passed on the one that I got. Even thought the transmissions are a week spot it is unusual to go through them like I have. It has become commonplace to swap the stock 3.54 EAT with a 4.11/4.44 EAT's or 5/6 speeds. It is a great car, as finances allow, I will probably end up with an additional one. Do your homework, read the site and figure out if it is a ride you're willing to take.
