Everything posted by Mikevan10
'97 Legacy - Troubleshooting cooling fan
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never utilized the aforementioned test connectors. Do you know what color they are?
1992 Legacy - MIL (CEL) upon startup
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn - Were you having issues like I am?
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJumped the gun before I say Tex's message. I will take a look and see what I got. Thanks again!
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Gloyale. I think there may be two coolant temp sensors? One for engine control and one for the temperature gauge?
My trusty '92 has developed an intermittent condition where when I first start it up from cold (first thing in the morning, for example), the MIL/CEL comes on, the radiator fan comes on and it runs rough and idles at a very low speed (like 5 or 6 hundred rpm). The light goes off and everything returns to normal about the time the temperature gauge is coming up to the normal, just below midpoint, reading. It does not do this every time. Often it starts and runs normally. Non turbo EJ22, manual transmission, front wheel drive, 220k miles. Any ideas? Thanks, Mike V.
The electric radiator cooling fan does not seem to come on even when the car is sitting idling (in traffic for instance). I say "does not seem to" because I am getting the info second hand. Assuming it does not come on, how does one troubleshoot this issue? Vehicle is a 1997 Legacy with the original EJ22 non-turbo SOHC engine and it has the manual transmission. Mileage is about 290,000.
99 BK Rear Drum To Disk Conversion
Mikevan10 replied to WhtMke's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you can't beat a Brighton! Wife has a '97. Very sweet. Curious though, why convert such a vehicle to rear disc brakes?
Clutch replacement - 2006 Forester
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the additional comments fellas. I typically just drop the trans when I do a Subaru clutch. As it turns out, it looks like I won't be doing this job anyway. But I appreciate the tip about the axles which I will keep in mind if things change. Thanks again. Mike V.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the feedback guys. Mike V.
I have replaced clutches in Loyales and Legacies as new as 1997 but never a Forester. Would the Forester be significantly different in terms of time and effort? Any special considerations, etc?
2007 Leg 2.5 run with no oil
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks again guys. Just FYI, I got my niece's other car (Toyota 4Runner) back on the road so that sort of takes the pressure off of the Subie situation. I'll come back here once a plan materializes. I will try to phrase my questions better at that time. Don't seem to be getting my point across at present.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Gloyale, Sorry for my density, but would you please expand on why I would need to swap over the intake manifold from my old engine? That was kind of my question: What model year range engines (and other stuff like California car or not, etc.) will be plug and play? I would have thought that doing something like swapping the intake assemblies (with the associated wiring harnesses) would only be necessary if I am not using the same generation engine or something. And why would I want to change over the camshaft and crankshaft sprockets? Thanks again.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, so I take it that I need a 2006 to 2009 SOHC 2.5. Does the type of trans (Auto versus Manual) matter? I am looking for plug and play and am worried that there may be some difference in the ECUs or wiring harnesses or something. Thanks again, Mike V.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year range of 2.5 liter SOHC engines will be a direct swap-in (this is an automatic transmission if that is important) for this particular motor?
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks GL66. It's non-turbo, so SOHC.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for he comments guys. But you've heard this story before: The owner is strapped for money so I need to do this at a very low cost.... I just took a look at car-part.com and these 2007 motors aint cheap!! And it seems they installed SOHC as well as DOHC units in that model year? Bad situation.
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo this is something (short block) I would buy from the Subaru dealer?
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYikes
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat would be the relative availability of a good shot block versus a complete engine?
Seems to have killed it This is my niece's car' She only had for about 3,000 miles. What are my options regarding a replacement? Thanks guys, Mike V.
99 outback gaskets again
Mikevan10 replied to whynot162's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the head bolt torques in the FSM based on LUBED bolts?
Proper front cat for 1997 Legacy 2.2
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I installed the $150 Walker cat back on July 22. Installed a new Bosch rear O2 sensor at the same time. Have put maybe 250 miles on it since. No CEL/MIL yet. Finally passed emissions inspection! The Walker fit fine. We'll see how long it lasts....
Blower is not dead?
Mikevan10 replied to familyguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the original poster is saying that the blower DOES NOT come on when he turns the fan on. I had this problem on my '92 and it turned out to be a wiring (actually connector plug) issue. Of course there are other reasons for this problem.
1992 Legacy - Electric module on left side of trunk
Mikevan10 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the money Cole. Thanks!
There is some kind of electrical/electronic module on the left (driver's) side of the trunk. It is mounted up along the side, under the carpet forward of the jack stowage area. It is a plastic box measuring about 4" x 5" x 1" thick. When I started the car this morning it started ticking. And it kept ticking when I shut the engine off. So I pulled the multipin connector. What the heck is this thing and any ideas about the ticking? Thanks. Mike V Now back to replacing the cat on the '97....
