Everything posted by Prospeeder
'89 xt6 leaking oil and water... ideas?
Prospeeder replied to misledxcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
make sure you replace your timing belts too, that oil will be slopped all over the timing belts and they will break in short order, i just fixed my RX whos previous owner just kept adding oil and it was pouring out all over the belts and broke them -
i got that relay, you didnt tell me i had to rewire it or somthing, its defintly not the same, so i didnt do anything with it. But i lubed all the window tracks, they all go up and down fast and on thier own....ecept for my dirver side rear one, it goes down fine but on its way up it needs help,i think the motors probably hosed
Erm, i had my intake plenum off, and i notice when the gas inside is floored, the throttle plate doesnt open all the way, only like 3/4 of the way, mabye less. and it i take my hand and pull on the cable or what its connected to i can easily make it open more, and theres a ton of slack in the pedal. So when floored, should the butterfly be open all the way and wich way to i adjust it?
ok thank you, i appreaciate it, so are these relays plug and play or not?
Home alignment on EA82 wagon
Prospeeder replied to ShakotanBoogie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
are alignments that much? I had one done on my mazda for $35 for a 4 wheel alignment ($25 for a 2 wheel) -
id be leary of using it, it might be bad for seals in the fuel system, but im not 100% sure, and probably will damage Catalytic converters.
sooo yea about the ground location and more info on the relay, lol
What to do When the Mark is Hit
Prospeeder replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the little fiting itself actually broke in half, lol -
My friends Mercury Sable had one of those pastic things for flushing, it blew apart and nearly overheated the engine by spilling the coolant everywere -
where is the ground for them? and this relay thats avalible, any specific numbers on that, i dont have an autozone, i have Shucks, napa, and carquest. I greased the hell out of a few spots on one of the slow windows and it sped it up, but going up is still ALOT of trouble for it, but going down its fast now. When its going up, from the bottom its very very slow, it needs help alot of the time then it gets halfway then goes pretty quick on its own. Also i cleaned the contacts with sand paper and lacour to get the carbon off. they looked pretty clean and were really dirty, and i did All four switches including the master
Ok so i did what was said and cleaned the contacs at all the switches, but it made zero difference in all the windows performance. The drivers windows fairly quick, untill it gets to the top and it squeaks and then goes slow. The rest of the windows HARDLY work and need help going back up they have such little power going to them or somthing. Somtimes if you use thier direct switch they work abit better. THink my master switch is hosed? Some kind of relay? Or are the motors shot, i thought when those went they just didnt work.
Leaking coolant possibilties
Prospeeder replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I checked the radiator, no coolant coming out of it. I got a new water pump for 30 bucks. And then a hose under the intake manifold decided to spring a pinhole leak and spray coolant everywhere. LOL gosh you people arnt kidding when you say Subarus always leak somthing -
86 Turbo RX Sedan Questions! Timing, body, ect
how does it go on, the stupid thing keeps falling off on me, lol -
intake gaskets not leaking. I stareted it and the fan blew a bunch of coolant out and then it stopped, im not even losing coolant from what i can tell. could it be coolant in little areas getting nocked out when i start the motor and dripping down? cause alot of coolant went everywhere when i took the water pump off to do the seal. Im still looking like crazy for leak spots, but im finding nothing -
Wheres this vacuum hose go??
hey thanks, i really appreaciate it, i found exactly where it went after you gave me an idea were to look -
no one knows?? -
waterpump and Timing cover ???
yes they are, the rear covers are bolted down anyway, they cant move at all, and the belts dont rub or anything -
oh arlight, thanks, ill check that out, make sure those manifold gaskets arnt leaking. And any of those hoses. Im really hoping its anything BUT the water pump, lol -
yea but still, if you know any odd coolant hoses, or places coolant can just drip drip drip down lemmie know, so i can check em tomarrow. Other than whats been listed -
why would they drain coolant tho? Im going to tighten the water pump bolts a little more, i went fairly light on all the bolts, afraid to squish the gasket. but im not gonna wrench on them and snap the bolts, lol, thad be stupid -
yea and the exhaust is in the front, right under it, and the coolant is dripping down the block from somewhere onto the exhaust pipe that runs in front of the oil pan -
you know the front exhaust manifold/pipe? It runs right under the timing belts and all that Yes it has that steel input line, i smothed it in that gasket RTV stuff to make sure it sealed, wich from what i can tell it is. What are these holes ur talkin about?? Like freeze plugs? -
im looking, im not seeing any hoses, do the manifold gasket leak externally also? i may check that out, like can it drip down to the exhaust? its right on the center, a little off to the drivers side abit, not centerd. -
Figured out the belts, one was pushed under the seat The horn pad, doesnt have and screws underneath, this is the one with the clip thingies that are metal, i cannot figure it out it likes this one http://www.donkeysarecool.com/img/GL-10/Gourmet%20Dinner%20020.jpg (not my pic but its just like it) Thanks for the help! -
uhg seriously, i got the surface as clean as possible, and put the silicone sealer stuff on the places it looked iffy if it would seal right. Did that screw me over? Can the water pump go out without taking the timing belt and stuff out??
