Everything posted by BigMattyD
Doj...
BigMattyD replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI Installed a NAPA replacement axle, and it has rocked the house for two years in my 96 Legacy. No Probs whatsoever. Big D Out...
Service Manual CDs on eBay
BigMattyD replied to BushmasterSI's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the thing... they would rather not give you the information. They want you to take it somewhere to get it fixed, preferably a "Genuine Subaru-Approved Repair Facility, i.e the Dealer" to get it fixed... matt
Everything New - Gas Mileage Got WORSE
BigMattyD replied to SuperSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe since you got the work done, you've been hopped up with excitement and been driving more aggressively.... matt
1995 Legacy L axle nut
BigMattyD replied to artistic_gore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm pretty sure this person knows "lefty,loosey, righty tighty!!" The problem is that some people's axle nuts are harder to remove than others. Mine was actually easy to remove, but I have read many posts where the nut had to be cut off or the car taken to a truck garage to be blasted with a heavy duty impact wrench. It all depends on your particular situation. matt
"Tick of Death"
BigMattyD replied to dave1rr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis sounds suspiciously similar to what happened to me last year. Read this thread, and see if it may apply to you... http://www.ultimatesubaru.org/forum/showthread.php?t=34929&highlight=tick Matt
Brake job advice
BigMattyD replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXConsider buying OEM pads online. They come with new shims and clips, and are very good quality. I used the cheap ones for a whhile, about 1 set every 18 months, and they would often squeal, etc. I recently went back to Subaru parts, and it is far better. I got mine at subarugenuineparts.com matt
How did subaru increas the ground clearance on the new outbacks
BigMattyD replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey drove the car up onto some two by fours???
97 OB 2.5 Timing belt hell
BigMattyD replied to r_3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOf course double check the plugs and wires, but also look for vacuum leaks, especially the 3/4 inch hose that attaches to the air intake assembly near the air flow sensor. Once I forgot to reinstall that hose, and the car would barely start, or it would start and immediately die. I don't know the specifics of your intake system, but I have heard others speak of this hose causing problems. matt
H6 Swap...
BigMattyD replied to BruceyWV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget to add a turbocharger. matt
high speed braking shimmy
BigMattyD replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper, I had steering wheel shimmy when braking from high speed, and it was intermittent like yours. It lasted several years until I replaced the front rotors, then it stopped. I didn't originally think it was the rotors because it didn't happen all the time, but alas, it seemed to do the trick. I did not change the tires at the same time, if anyone was wondering. Matt
Low Gas Mileage 2001 Forester
BigMattyD replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNeed an update please... matt
P0302/P0304 Misfire Codes
BigMattyD replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOBD II is great as long as everything is working when you need the car inspected... Actually, having a somewhat universal system for all types of automobiles is a good thing, and the fact that you can use aftermarket readers to monitor/diagnose is excellent. Being able to read sensor outputs is also cool. But having to have it working at the time of inspection can be a hassle, as you found out. Matt P.S. I also think people should update with solutions to their problems, and it seems that a lot of people already do..
Rust on the the timing belt?
BigMattyD replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would probably just wipe it off as best you can with a clean rag, when you run the engine again, it should polish itself up real quick. Kind of like brake rotors... Matt
'96 Legacy 2.2 hot (non)starting issue
BigMattyD replied to b1pig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow get out there and replace it!!! good job on the H2O trick. thumbs up to your wife who knew where the CPS was. matt
Okay, I'm officially pissed off for the evening...
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I'm officially in tthe market for an air compressor now. There is a model on sale at sears now, around 20-30 gal tank, comes with a basic tool set for 279.99. I'm putting it on my Christmas wish list... Hopefully I'll get it before Christmas, though. matt
Engine making a clicking sound!
BigMattyD replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, unfortunately I believe you are wrong. The oil thins as temperature increases. The difference between "multi viscosity" oils is not that they don't obey the laws of physics, but that they still thicken when cold, but not to the degree a single viscosity oil would. matt
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe interesting part to me is that on the same car, in the same area of the car, that there can be so much difference in the difficulty removing bolts due to rust, etc. On my car, the difficulty scale has been as follows: Impossible: Ball joint pinch bolt and strut bolts Very difficult: Front control arm bushing bolt, one of the two rear bushing bolts Moderately Difficult: Sway bar link bolt, Brake caliper mounting bolts, one of two rear control arm bushing bolts Easy: Axle Nut, roll pin, lower brake caliper pin. matt
P0133 O2 sensor trouble code
BigMattyD replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy bad. I did not look up the code, to find out that it was O2 sensor slow response. The only other thing to do is check for exhaust leaks prior to the O2 sensor, which you would probably be hearing already!!! I agree with the others. If it fails to clear up, try another O2 sensor. Maybe OEM if available. But I would try resetting the CEL once or twice more. Maybe the new sensor needs time to "break in..." Matt
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think anyone was quetioning you hammer technique as "caveman-style," In fact I think he was saying the hammer technique is a good one, but that air tools are great as well. Next time, I may try the hammer technique, as it would be quicker, and fewer parts to disassemble/reassemble. Matt
BigMattyD replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo me, the noise does not sound like valve lifter ticking, it is too loud, and more of a clanking than a ticking or tapping. I have had experience with valve lifter ticking, and it is a much more staccato ticking, with no "ringing" afterward. Now anything is possible. It may be the lifters after all, but I know mine didn't sound anything like that. Matt
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried to remove the strut on the first attempt, but I couldn't get those bolts to move. I think the lesson here, besides using an impact wrench, is to find whichever parts you can remove to give you slack. If you have to get it done in one day, I would jack up the car first and see if you can loosen the needed suspension components to allow you to complete the job. Once you are sure you can get them apart, you can commit to the actual removal and replacement. matt
Wheel nut torque?
BigMattyD replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon my 96 legacy, the FSM states 65 +/-7 fl/lbs it seems low, but it works matt
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe job is done. I gave a brief thought to working on the pinch bolt and strut bolts again today. I heated up the pinch bolt with a torch but it made no difference. Using a good quality 6 point socket, I was still unable to budge it, and the corners were rounding off. I thought about removing the castle nut from the ball joint and separating the control arm there (this was before I read the post from Mikevan,) but decided not to because I didn't want to chance screwing up the ball joint since I knew I would not be able to easily replace it. I removed the top bolt from the sway bar bushing relatively easily, then moved to the front bushing for the control arm, or A-arm, etc. That took some serious torque to break free, but then was relatively easy to remove. I then loosened, but did not fully remove the two bolts that secure the rear bushing of the control arm. This gave plenty of wiggle room to get the old axle out, and put the new axle in. The old axle slid right out like it was brand new. I was actually very surprised. The outer boot was torn, which is why I replaced it. I plan to clean up the joint later. If it is still in good condition, as I believe it will be, I will replace the boot with a new one, and I'll have a spare axle on hand. I can't wait till I can get a compressor and impact wrench. My back is really sore from pulling on those wrenches tonight. Thanks to my USMB support group for weary do-it-yourself mechanics. Matt D
BigMattyD replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should also check the connnection between the sensor and the ECU. If you replace the sensor, but there is no connection, you will still be having a problem. Your first post did not explain whether or not you had checked the wiring. matt
BigMattyD replied to BigMattyD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a simple general purpose propane torch. I am hoping that given time and PB Blaster, I won't have to heat them, but I will if I have to. I have heard that heating it as quickly as possible and then dousing it with water creates some thermal shock that helps to break the rust bond. Some people say heat it up, then remove it while its still hot... Well, I'll get to it another day. Matt
