Everything posted by frag
Possible Oil Pump Leak 2.5L?
frag replied to redeyss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf by "left" you mean the driver's side, then it's not the oil pump which is right smack in the middle of the engine (around the crankshaft front snout) and has a tendency to leak under the timing belt cover and not over. The part of the engine you refer to is quite near the oil fill tube. Is it not possible that the leak comes from where this tube enters the left cam cover (there is an O ring there). I had to stop a leak there on my car a while back.
Cranks Slow
frag replied to sacts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt depends on how slow is slow. I've often noticed that my Subaru starts a little slower than most other cars (specialy the american ones), but it always starts even during the coldest winters. Other cars : v-v-vroumm ; Subaru : gna, gna, gna, gna, vroum. The number of times the engine revs before starting is the same be it summer or winter, it's just a little slower in winter.
Sticking Calipers = Smokey Brakes... EEK!
frag replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt any auto part store you can get special high temp grease specialy for that application.
Possible to push-start 1990 Legacy AWD automatic?
frag replied to Zack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn my car's (man trans) owner manual it's written not to push start it cause it would damage the catalytic converter. I dont understand why. Anyone?
Oops... front strut / suspension question
frag replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReading the subsequent replies, I must admit I was wrong. I did all four struts on my car two years ago but honestly dont remember the exact details. If that spacer is tapered it must be for a reason and that reason must be to make a point of contact between the strut seat and the strut mount so that contact and pressure only applies to the inner part of the ball bearing (the part that moves). So it means the tapered part must go on top and in contact with the mount. There would be no reason to install it the other way. With the spacer under the spring seat instead of on top of it, it's possible for the spring seat to rub against the outer part of the ball bearing (part that does'nt move) thus damaging the seat and the bearing in the long run.
frag replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only effect I can see is that the spring preload will be slightly less (proportionnal to the spacer's depth). If you feel no ill effects on the way the car handles over bumps, I woud'nt worry about it. Just an opinion though. Wait to see if a strut expert will chime in. Good luck!
frag replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put rebuilt front calipers (and new rotors and pads) on my car recently. They are very reasonnably priced when you take into account what they give you for the core. Looking at yours, I think replacement with rebuilts would be more in line than messing with them. Just my opinion. Take care.
CEL Light Randomly Comes On At Around 100 km/h. Any Suggestions?
frag replied to Faithbleed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cooling fans are triggered by the coolant temp sensor thru the ECM. Maybe this sensor is acting up at a specific temp range. Cheap fix. A little hard to get to but nothing out of the reach of a DIYer. Make a search on this forum and you will find lots of info on how to find, and replace it. No use to test it. It's cheap enough so that if you get it out it's better to put in a new one. On a 95 it's already up for replacement anyway. Good luck!
95 Impreza LX (Please Help - I'm scared)
frag replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have no binding on turns and if AWD works OK I dont see why you should have the transfer clutches replaced. Ask them how they came to the conclusion that it needed replaced. The "vent" or separator plate is sometimes cause of an oil leak between the engine and transmission. Unless you're loosing a lot of oil (you say there's nut much oil underneath) it usually can wait to be replaced. My two cents.
frag replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd maybe it's just the slide pin that's corroded and needs a cleaning, polishing and relubing. Take a special look at the rubber bellows that protects the slide pin. Maybe it's ripped or dislodged and is letting water in. This need a special high temp grease found at any auto store. Good luck!
Subaru Shake when Idiling
frag replied to Tallica1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are known to live not far from the Platinians.
Raw fuel smell
frag replied to Tommymc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have no experience with raw fuel smells but i remember reading here a similar thread where the culprit was a leaking fuel rail connection somewhere along where the injectors are (maybe on the right - passenger - side). If the purge canister trail leads you nowhere, maybe try looking around the intake manifold for signs of leaking fuel.
frag replied to Tallica1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt regular intervals (3 to 4 months) my engine starts shaking at idle but the idle speed is correct and stable. Each time I get rid of it by using a top end cleaner directly fed by a vac line on the throttle body. I suspect that shaking is caused by carbon build up that produces a mild case of miss in some cylinders. You could try a shot of Seafoam or similar cleaner in the top end and see if the condition goes away. Good luck!
Coolant temp sensor
frag replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo you dont. Just push aside some wires and hoses and use a ratchet extension.
climate control backlight - how to change bulbs
frag replied to CPAScott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=2498&highlight=climate+control+light
Wheel Studs Procedure
frag replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it just squeeze in when you torque the wheel lugs or do you press it in or bang it in from the inside?
Notice: Wholesale OEM parts from Auburn Subaru
frag replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, but I know what «bump» is for. What I did'nt understand is why he linked it to my post instead of to the last one in line. Just wanted to know if I was missing something.
Torque bind- a temporary solution?
frag replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you permit me to differ LosDios, I dont think so. Cause everything will still be moving (rotating) except that small lenght of removed shaft. I dont think that will same much gas.
How to conquer the wheel bearing.
frag replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX32mm or 1 1/4 "
frag replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX?
Initial hesitation after sitting for a week?
frag replied to trevize1138's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it was the coolant temp sensor, you would have the problem at each start up and not only after the car has been sitting for a week. The fact that it only shows up after a week makes me think that it's fuel related. Starting from here, it's all speculations. In a week's time, the fuel can drain from the fuel lines and if you have a dirty fuel filter or weak pump, maybe it takes a little time for the pressure to get back to normal. I would begin by replacing the fuel filter if this has not been done for a while. If it does'nt work, test the fuel pressure at start up after a week. If fuel pressure is OK., then hope for more expert help which you are sure to get here if you're patient enough. Good luck!
frag replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will not be so easy up here. Rust is ennemy no 1 in Montreal.
frag replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm bookmarking this. That's a lot more than I asked for ! Thanks a million !
frag replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know I will have to do this sooner or later and I'm slowly getting readiy for it. I read everything here, I bookmarked the link you're talking about and I already bought a 12 ton press cheap. What I would like to learn from you is the size of the sockets you used to press out and in the hub and the bearing itself. They are probably too big to already be in my socket kit. Thanks for reporting back.
alternative gas saving ideas...
frag replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike a golf ball ? That must have been quite a hail storm !
