Everything posted by Sushi
Legacy GT
Sushi replied to Sushi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat site does give some good information on the GT, but not quite what I'm looking for. Perhaps I should itemize my questions. With regards to the GT.. -does it have an LSD? -different interior (seats, dashboard)? -lower springs or different struts? -I know it has different front bumper, hood, wheels, and side skirts, how about rear bumper? -headgasket prone 2.5l only available engine? -upgraded brakes/rotors? Do you think it would be worth it to upgrade a regular or brighton, or just hold out to find a decent priced GT?
Legacy GT
I am considering buying a 2nd gen, Legacy GT. However, they are somewhat hard to find around here, yet Outbacks and Brightons are very common. So what is it that makes a GT a GT? What sorts of things would I need to change? Has anyone had the oppertunity to drive a JDM GT with the Twin Turbo?
2.5 damage limits
Sushi replied to Sushi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a SOHC. Are the timing belt covers the same for an EJ22 as an EJ25 assuming both are SOHC? I'm having trouble finding a new cover (the P.side long one) or does anyone have one for sale?
2.5 damage limits
Sushi replied to Sushi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI checked the compression and the cylenders on the side that slipped was actually slightly higher than the other side, but both were within 20psi of each other. I hope I can get it together soon and really test it out!
2.5 damage limits
Well I have begun rescuing Subarus from the local salvage auction and this week I got my hands on a 99 Forester. It was hit in the lower middle front (possibly a pole or tree) and the radiator fans ended up inside the timing belt cover. I checked the timing and it was out about 5-6 teeth on the passenger bank, also the oil filter was punctured and mangled. After refilling and filtering it (there was about 1 liter left in the oil pan) and resetting the timing belt it started up nicely. I have not done a compression check yet (my gauge may not reach) so my question is this. How far can the valve timing go out before the 2.5L will begin to.... interfere, and how long can an engine run without oil pressure before things start to take damage? If there was still a liter of oil in the pan, I would think the engine was shut off fairly soon after the accident, right? It runs smoothly and revs nicely, but its hard to give it a real test since there is no radiator and I don't want to also kill the water pump.
Finally, an Impreza.. however
Today I won an Impreza, 93 wagon AWD 5spd at an auction. I have wanted a coupe (preferably 2.5 RS) for many years so this is kind of a step in the right direction. I bought it just to fix and sell as I already have a newly modified Loyale, however this Impreza is quite addicting.... I doubt I'd keep it but at least it'll be fun to drive for awhile. It is really nice to finally have some power although the seats are kind of low and that airbag steering wheel has got to go.
rear hatch struts. where to get them?
One suggestion. My struts also died long ago, and since I didn't want to replace them and prop rods are a real pain, I just bent them. Grab the 2 rods and push them outwards, or sideways ect. and it will keep the hatch up no problem. Slightly harder to open, but not $100 harder.
2. Pros and Cons of Dual Range VS AWD
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI meant in theory only. If I really cared about a center LSD I'd just convert to EJ... heh.
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter looking at the above posted pages, it seems to me that the 5spd impreza tranny would work, and is designed the same as the xt6 one. The only difference is there is a clutch pack where the 4wd locker once was, if a person was skilled enough (and had the time and machinery) they could theoreticaly replace the 4wd locker with a clutch pack and have real AWD. Am I right?
Is there a demand for bolt pattern adaptors?
Whichever bolt pattern you decide on (I would prefer 4x100 for strength issues) make sure it is both hubcentric and wheelcentric.
86 gl 10 4wd questions!
Why not convert to an xt or xt6 ft4wd transmission (depending on your diff ratio), or an RX tranny?
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I'm looking for is just a internal visual of an Impreza tranny. Does it have a setup similar to the xt6 tranny? Front pinion run though hollow countershaft, center diff behind with lsd clutch pack or...? Also, is the Impreza 5spd a true 50/50 split untill something slips like the xt6? I would love to see the offical repair manual for this. Just to clarify, this is regarding a first gen Impreza.
Part-time AWD transmission????
Sushi replied to thatswhatshesaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tranfer case on your Jeep has got me thinking... I would guess this is already the case in some vehicles, but could you make/remake a t-case that has a center diff in it to make a Jeep or other 4x4 truck full time 4x4?
Pros and Cons of Dual Range VS. AWD ??
I can believe it. I had an '82 Toyota Tercel fwd which was fantastic in the winter untill the rust caught up with her. I never thought I could respect a fwd car before.
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice to know I can run different tires after I made a special effort get a matching set for the transmision. I suppose using very different tires would have an adverse effect on any of the 3 diffs though, similar to pinion failure caused by running a temp spare on the back of a rwd car. I have studied the schematics for the ft4wd xt6 5spd tranny, and I would like to see how it compares to an Impreza one, does anyone have a link or pdf for that?
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhh, that is a good point. I was somewhat unsure of the difference between ft4wd and awd. So with ft4wd is it as necessary to use tires of exact diamter on all sides as it is with awd?
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExactly as you said. awd most of the time and 4wd (locks the center diff) when its really deep or the awd slips. Also 4wd makes it easier to drift at low speed I've found.
Grimmspeed gear oil cocktail made shifting worse!
Sushi replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the old pt4wd tranny in my Loyale I could put it into 1st at around 30mph without an issue. The new awd tranny won't go in over 15mph
If we are talking about an EA car here, don't all the AWD trannys have a diff locker anyways? You can use AWD anywhere, and still keep the 4x4 for difficult spots
Sushi replied to cole098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter installing AWD on my Loyale, I could never go back to part time 4wd. It is fun to drive on either snow or pavement now! And you save the 4wd button for those very deep areas....
Ensure rims
They do look ufoish. I originally bought them just for the tires but as you said alloy > steel. I actually like the look of the stock steelies better but their offset is too high, these alloys have 1-2 cm lower offset.
Ensure rims
Ok, pics are up. Subaru centercaps not pictured http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=22507
Ensure rims
That is a fantastic list of wheels, however my mystery rim is not there.
Ensure rims
Has anyone ever heard of a rim company called "Ensure"? Might also be the rim type... I was refinishing some alloys I got from an XT turbo and realized that they don't look like other suby rims, also they don't say Subaru anywhere on them other than the centercaps, and printed inside the hub they say Ensure. I'll post pics later today. 13 inch hubcentric 4x140
found some 13 inch snow tires
I just got some 185/70-13 MS tires that look almost exactly like that, studs and all. Also not worn, hardly used. Anyone ever heard of Snowmark?
