Everything posted by Mr. Brat
anyone using the magnaflow ej22 exhaust?
Mr. Brat replied to tallwelder81's topic in Subaru Retrofitting
No worries, I just thought you were repeating yourself. As far as I remember the cats are differant between the EA and EJ. I think they have differant numbers. If you have the stock EJ y-pipe, you can put a new cat in it if you would like. You will have to cut the y-pipe to fit... The EA car suspension is the same. And the same cut and modified y-pipe from the EJ18 will bolt right onto the EJ22 if you decide to upgrade later as I did. Nothing changes, if I remember right the 18 and 22 heads are almost identical. So to answer your question about will it change from motor to motor, yes it will. Putting a magnaflow cat inplace of the stock, there is no need. If the cat is working fine... dont replace it. -
When swaping to an EJ you will have to cut your y-pipe or the cat will hit your sway bar. So to answer your question. You could keep yours and cut it apart and weld it in. Or just like I answered in your other exhaust thread, you can get a magnaflow cat and weld it in place of your stock cat'd y-pipe. And I answered your other question in your other exhaust thread about yes it will fit... I had an EJ18 in my brat and then swapped to the EJ22. http://www.ultimatesubaru.org/forum/showthread.php?t=124485 -
BIG NORTHWEST SUBARU MEET... whos going?
Mr. Brat replied to Mr. Brat's topic in Meet n' Greet. Your USMB Welcome Center
Yeah, I could do that. -
Coming to WCSS? What are you bringing?
Mr. Brat replied to 92_rugby_subie's topic in Meet n' Greet. Your USMB Welcome Center
I will be bringing my lift blue brat which is also ej swapped. -
I am going to try this and see how well it works in my WRX BRAT.
So I read through his right up (really great info), but still didn't find what I was looking for. I really like the idea of using the red wry factory calipers, but I never seen what kind of bracket was needed. I am looking to find someone that has done this upgrade and can give some words of advice on parts needed.
I am going to go a 5 lug swap on my other brat, I will be using the legacy front knuckles and struts and what not. I was looking to see if there was a factory type upgrade for the brakes. As in wrx sti rs... I thought I seen somewhere on here that you can use wrx front calipers and rotors but you would need to get a mounting plate from subaru... cant find that thread anymore...
how much limted weight for tow boat.
Mr. Brat replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is not answering the question... You are saying that you THINK it weighs that much... That is NOT the tounge weight. You are refering the the GVW (gross vehile weight) which is the second part of figuring what hitch you need. You NEED to know your tounge weight to determine what class of hitch you need... If you dont know how to do that (just read above, Nipper told you how to do this) then just get a class 3 hitch with a 2 inch reciever. You could just take it to a hitch shop and they can tell you what you need. -
BRAT Meet 2011 - Leavenworth
Mr. Brat replied to Fenix747's topic in Meet n' Greet. Your USMB Welcome Center
I didnt, I know Mugs took pics of everyone leaving Safeway. And Rob had the video... -
I have thought about the spacers... I want my wheels and tires to sit right at the outside of the fender and not any wider... and I also plan on a wide wheel and tire to.
I even got the drive picture with another Subaru in it -
Here is the pictures I took... Not that many this year... -
I know that you can bolt up the EA82 front cross member in and that would widen the front and and solve alot of problems, But this also widen the front an 1.5 inches if I remember so, thus would have a wider stance in the front. I dont want that at all. I want to stay the same width if at all possible.
There will be one next year... Start planning -
Not going to speak for all the guys on the east side, but I dont think they would be willing to drive all the way over... But on the other hand, could be good for all the people over here with brats to get together. -
What is this? I cant remember.....
This is what I did to EJ swapped brat
