Everything posted by Markuss
New~ IRON ON~ SUBARU PATCHES $4.00 EACH Free shipping
New~ IRON ON~ SUBARU PATCHES $4.00 EACH Free shipping in the U.S..Pay Pal to muatcls@yahoo.com leave name and address---->> Thank You
Manual 1999 Forester No Lights No start,No Fun,Its a Bummer!
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will also check that today.Thank You.
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was the problem,That is why I replaced the battery and cables.Yes,I replaced Pos+ with Pos+ and neg- with neg-But I will try checking neg- with multi meter.This weekend.Thank You.
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo aftermarket security system.I replaced the battery and cables because they were(Old) crusty.Did not check voltage at the fuse boxes.Which ones should I check and voltage amounts?
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnothing yet
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure to connect the smaller lead on the positive side that goes to the under hood fuse box?Yes,I did that.Also checked all the fuses.
I Installed new battery,No dash lights when turning on ignition switch,No start.Could it be a bad ground to the transmission?The wires to the battery are also new. Need wisdom and insight!
98 Forester - yes, no, or maybe?
Markuss replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast year I bought a 1999 Forester for 500 bucks with bad head gaskets,Installed head gaskets twice,Then assumed it was so overheated so much the short block was warped.So I pitched the EJ25 and installed a low mileage 2001 EJ 22 from an Imprenza for 350 bucks.And after 14k miles It is still running Great!
Thule bar type
Thule roof racks are now made in China.I bought mine on e bay for $89.99 and 49.99 with the extention.Total about $140.00 bucks(free shipping).Same folks that makes Thule.Without having to pay for the Thule name.
What 2.2 engines can I use in my 1999 manual trans Forester
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWent to car-part.com bought 87k mile 2000 2.2 for $350.00.installed engine and new Y pipe runs like new...
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes,I had the heads machined.
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsed new gasket,Still leaks.In the market for a 2.2 for my 99 Forester.Any one gots one within 100 miles of Cleveland,Ohio???
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPics of old blown gasket,I dont know if this one was orginal Subaru.But this one is a mutilayered the right one was a single layered one.
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will use this gasket,Is there a right and left gasket?
What 2.2 engines can I use in my manual trans 1999 Forester?I have read egr non egr bla,bla bla....Thank You!
99 forester driver's side head gasket
Markuss replied to Markuss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used mizumo gaskets the first time,I am going to use fel pro for the second try.If they don't work this I'm throwing the towel on this engine..Yep,the timing cover on that side was melted/distorted.Does the EJ 22 plug right into the EJ25 harness?Thank You.
I have a 1999 Forester i just bought that needed a new head gasket on the driver's side left.I had the head milled and installed properly torque etc..,the engine almost immediately started blowing white smoke and vomiting coolant out the tail pipe (burning coolant).Took the head out and had it pressure tested,tested good,The only thing I could see wrong was the steel rings on the upper short block(the rings you can hang the head gasket on?)One of them is pushed almost completely into the block,Could this be my problem???? .Thank You
- 1996 Legacy Lift Kit
EA 82 Turbo to regular Fuel injected engine
I have a 1988 GL-10 that was orginally a turbo car,I put a regular SPFI engine in itI have the wire harness and ECU from that engineThe old wire harness that is in the car just does not match up to the turbo harness,Will I have to pull the old turbo harness and install the SPFI harness and ECU?If so How is it routed?and the best way of Pulling the old harness and installing the right harness for this engine?Thank You Very Much in advance!
Rust repair,radius rod mount
Just like the rest of the comments.Cleanup all the surrounding undercoating.After welding brush on rustoleum rusty metal primer,2 to 4 coats. then re undercoat.will be stronger than factory.used to do Beetles,Things,Karmann Ghias and Those ratty 356 Porsches.
aquired 1988 GL-10
Hello Folks,I aquired a 1988 GL-10 manual 5 speed 4 X 4.It has no engine,There was a EA-82 Turbo in it.....My question is could I put a EA-81 Turbo in it?If not ....I have a EA-81 for sale or Trade for the EA-82 I would need.Thank You Very much in advance! USMB is the Bestest!
1988 Gl what engine did it have?
- 1988 Gl what engine did it have?
I am aquiring a 1988 GL wagon.What engine was in it?I have a Turbo EA 81,Would that work?- Awesome video I made of my lifted wagon in action
groovy!- Is 1991 Loyale engine...
excellent Doug,Thank You! - 1988 Gl what engine did it have?
