Everything posted by Olnick
Starter rebuild 1996 2.2
Olnick replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to find the contacts at an auto electric shop (starter/alternator rebuilder) or at a Subaru dealership. Maybe even Toyota, I believe they used the same starter too. Suggest you remove your old ones and take with you to visually compare--there are several different designs. Here's an old thread that has some good pix: http://www.ultimatesubaru.org/forum/showthread.php?t=58142&highlight=starter+contacts Good luck.
Olnick replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid the solenoid throw when the key was turned to "start" or did it throw after you tapped the starter? If it worked with the key, then the problem could be simply worn, pitted copper contacts. That's a relatively cheap and easy fix.
95 Legacy Fuel Filter Replacement
Olnick replied to robm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo need to drop the tank. There's an access plate on top of the tank, you get to it from behind the rear seat.
98 OBW 4k miles after EJ22 swap update...
Olnick replied to BluetoE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's great to hear--and thanks for the update. The EJ22 is a beautiful little hunk of aluminum. Just a bit of preventive maintenance every now and then and you should have many miles of happy motoring. Enjoy!
Olnick replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what's the problem with your present starter?
96 with OBD-1?
Olnick replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFigures, huh!!! The California/OBD1 stickers appear to be add-ons to the standard certification sticker. Most likely so the cars will be tested according to OBD1 standards/procedures. Proof would be if the ebay seller would check to see if there is an OBD2 port on the dash. (I'll bet there is.)
96 with OBD-1?
Olnick replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcellent theory hankosolder! I seem to recall reading something about the "readiness" monitor problem. Anyone out there with a California '96 who can verify the underhood add-on sticker?
1995 Impreza 1.8 L: basic maintenance questions...
Olnick replied to wombatsauce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAin't that a great feeling? Congrats--and thanks for saving another Subie.
heater control back light on OBW
Olnick replied to bkvail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis might help you, it sure helped me! http://www.scoobymods.com/legacy_hvac_bulb_replacement-t91.html?threadid=91 Follow the suggestion later in the thread about disconnecting the cable at the bottom--much, much easier. Good luck.
96 with OBD-1?
Olnick replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomething sounds fishy here. Subarus adopted OBD2 with the '95 model year. Is it possible for you to go see the car yourself? Or if not, ask the seller for a photo of the car and maybe a closeup photo of the sticker that states that it is OBD1?
1992 legacy, cant shift into 5th gear
Olnick replied to church272003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes your shifter have a lot of "slop?" It could be worn out bushings in the linkage--especially the boss joint where the linkage connects to the tranny stub-out. Good luck.
was looking for snow flake rims & look what I found
Olnick replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoot = trunk. (The other end from the bonnet.)
Scan Gauge II
Olnick replied to rlsimpso's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'95 Legacies are OBDII.
Impreza L upgrade
Olnick replied to echoecho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome echoecho . . . echo! Can't help you with your questions but I'm sure others are gonna' enjoy making input. Sounds like a great project. Good luck and keep us posted.
New to USMB
And Hi to you! Welcome aboard USMB--lotsa' good stuff here.
Two mechanics stumped, anyone here have an answer?
Olnick replied to twojtyniak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the codes again and post them here (the code numbers, not a verbal description.)
Installed CEL Bulb - 2 codes and 17 mpg
Olnick replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI drive a '95 Leagacy too, although with manual tranny. I think the Bosch O2 is fine (although others on here will say it must be Subaru OEM!) Knock sensor is probably best from dealer. And I second what fairtax said, a general tuneup would be a good idea. Spark plugs and wires, new filters, PCV valve (and clean the hose), check vacuum hoses. Maybe even try a Seafoam treatment, clean MAF sensor and IACV. That 2.2 is a beautiful little engine--sounds like you're off to a good start. Good luck.
EJ22 Overhaul
Olnick replied to coldfusion21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust curious, but what is in a "top end kit?" Does it include the head gaskets? Are they aftermarket? Not sure I'd use anything but Subaru OEM for the HGs. Anyway, good luck with the project.
Shift bushing woes...
Olnick replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's great! And that is an excellent diagram. By the way, TiC supplied my pivot joint bushing, an excellent product. Now comes the fun part--trying to drive the roll pins out of the boss joint! Good luck.
Olnick replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome aboard USMB, hustle. Dealer should be able to get what you need (if not, call Jason at Mike Scarff Subaru 866-528-5282). Subaru changed the linkage design over the years so be sure to tell them it's for a '91 Legacy. There are several different bushings used in the shifter system--2 large ones used to attach the stabilizer rod to the tranny and the car body, a small tubular one that connects the shift lever with the control rod and 2 in the boss joint (the universal type joint that attaches the control rod to the tranny stub-out.) It's the last two that usually go bad and cause sloppiness. If you want to learn more, use the search function up top--type in "shifter bushing", select New Generation forum and hit enter. Lots of discussion of the topic over the years. Good luck.
What is the secret to getting the inner tie rod boot on the rack lip?
Olnick replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGosh, porc . . . sure would be nice to see a picture of it!!! (j/k, congrats.)
06 Forester 60k on factory plugs
Olnick replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRe: plugs, general feeling is that NGK is best for our cars. I've had good experience with the most basic copper (V-Power) plugs, but then my car is much older than yours if that makes a difference. Also, consider changing your plug wires--OEM Subaru only. Good luck.
Double DIN in '96 legacy
Olnick replied to excalibur5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats, that's great! Did it wire in/plug in okay?
Power but no start - 98 Legacy AT
Olnick replied to rottenhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely the copper contacts in the starter solenoid are worn/pitted/burned. You can replace them quite inexpensively but you have to remove the starter to get to them. Try a search for "starter contacts"--been discussed a lot. Good luck.
My friend's 92 Leg overheating
Olnick replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't say it is the cause of the problem but you really should only use an OEM Subaru thermostat.
