mountain brat
Everything posted by mountain brat
  1. it was simple for hoses and very clean.i have a 6" lift so my hoses could be longer
  2. trying to get a pic up here but not sure?
  3. oh yah also i used a 24"flexible hose for lower hose and 19" flexible with a 90*on one end got them at napa and adapters for size dif
  4. i fit two 12" fans in stock position. found some fans on a mercedes that were quite skinny made some brackets and capow although i did have to move passengerside fan off to side slightly because of power steer nut.i have pics somewhere
  5. anymore info?most of the motors i've bought from there before were in the 185-190 range
  6. i think were at 1500 ft and its a 96 2.2 i want to put in 98 obw
  7. its at a junkyard ive bought motors from before they test and pull for $500 probably will work hopefully
  8. would you buy a 2.2 with 170 on all four? whats best around 190?
  9. no its cammed against existing firewall stopper i'll have to get it running to see how strong it is .right now it won't move
  10. also have pics of my pitch stopper but it wouldn't let me post it here with others sorry
  11. been busy finished 6lug,rear disc,pitch stopper,radiator and fans they fit in stock side and kept ac,starting exhaust and finish wiring
  12. also i cut the skinny end off of original stopper and used for spacer and couple of washers.the legacy stopper was perfect length
  13. what i did was took xt pitch stopper mount and legacy pitch mount also and hardware. took the leg pitch stopper mount flipped it upside down and put to firewall mount spread one end to accept big end of legacy stopper. drill new hole about 1\2 to 3\4 of an inch back from original hole and bolt it all together sorry if this is a confusing write up not a computer person ill try and attach photos next. i haven't tried it out yet still have exhaust and wiring to finish up
  14. hi chux ,i tried to pm you i was wondering if you have a write-up on wiring will buy it if its clear and detailed thanks alot
  15. have both cars just curious who has done this and any info or pointers thanks alot
  16. 92 lego my friend was driving it and she said it came to a stop and wouldnt move. i got it home unhooked driveline and jacked it up put it in gear and no wheels turning when its in gear no grinding sounds clutch was going on it could it have broke ? going to pull it on fri just thought i'd see what you guys think thanks justin
  17. i want to keep my ac anyone have good pics or info on how they fit everything. i have an 86 gl and i'm going to be using ej radiator because my ea is toast ,so i know i will be notching the bottom for rad any help would be appreciated want to drive it to show if can get it all done in time thanks justin
  18. oh yah i didn't read through all the posts is it kid friendly?
  19. hi im a newbie i was wondering if a suby powered vw westy counts i don't think i'll get my current progect done in time justin
  20. Will a power steering rack from a 2WD EA81 go into a 4WD EA81? How would I go about keeping the cruise control? I've got a donor '83 EA81 fwd wagon with cruise and a donor '92 awd legacy with cruise. My '84 gl wagon does not have cruise. Can I put the column and dash controls from the '83 in and splice them to the wiring from the ej? Thanks...tforce using mountain brat's computer.
  21. is this the wheel that has the rare tire or is it easy to find tires for ?? thanks alot info please
  22. anyone know if i can fit a 3.0 in place of 2.5 if not im going to put 2.2 in but came across good deal but dont if i can thanks fellas any info would be great
  23. I need to check but can i take 2.5 intake and put on 2.2?
  24. will this work both are at ill probably have to reroute wiring out back of motor anything else?
