Subaru 5 spd's
Fairtax4me replied to KKDrex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat'll probably work but you'll have to buy a $15 socket to use it. A new drain plug form a dealer is about $10. If all the gear oil drained out though, you may have bigger fish to fry.
The direct injection BRZ motor
Fairtax4me replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo it has a conventional transmission and rear differential. A transaxle is a transmission and differential unit built together. Subaru's being AWD have front transaxle AND rear differential. The Corvette would have a rear transaxle unit.
Fairtax4me replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will definitely be looking for these to hit the lot at the local dealer. Looks to small for me to fit in though.
Transmission problems
Fairtax4me replied to Xadamx1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXX8 on a broken cv axle. That wil cause all of the above symptoms.
Still Need a FWD MT, good ole MSB strikes again!
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I kinda figured i could just swap it over. Thanks for the info!
Help: Mysterious *Fluid* Leak
Fairtax4me replied to wolfhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is the compressor leaking it's leaking compressor oil. Does it have a green tint to it in the sunlight? The common leak points on the compressor are where the hoses attach up on top. The O rings dry out and the refrigerant and oil leak out. The O rings can be replaced fairly easily once the refrigerant is evacuated from the system. Generally if there is a large amount of oil, its one of the main case seals on the compressor. Not going to hurt anything if you don't mind not having AC. If you want the AC to work you'll have to replace the compressor and have the system re-charged.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll keep you in mind if this one doesn't work out. Now for an important question. The trans I got has a cable speedometer drive. But I'm pretty sure the car has a digital speedometer. Can I pop out the cable end and thread the digital drive part in there? Or will I have to dig into the trans and swap gears?
2.2 stumbling
Fairtax4me replied to shanta74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIncorrect timing can cause some strange problems. I got the timing off by one tooth on one cam on my wagon, and I chased misfires for over a week. It only did it when warm, under about 3500 RPM. When it was cold it was fine, but when it warmed up to a certain point it was like you had flipped a switch and all of a sudden it was running like crap again.
EJ22 timing covers?
Fairtax4me replied to Redcap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI left mine off on my wagon. No ill effects yet, but winter is coming and I am kinda wondering how it will do with the snow. Last time I drove in the snow the engine bay got packed full of wet snow and slush.
Head Gasket/Compresson Question
Fairtax4me replied to jimmyberka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you have the heads machined? Did you clean the block down to bare metal? Did you follow the head bolt tightening procedure to a T, as if your very life depended on it? If you can answer NO to any of these there is a good chance the gaskets did not seal properly. Air in the system can play tricks on you after a head gasket job. Make sure you have bled all the air out of the cooling system. What brand of head gaskets did you use?
Cam/Crankshaft Sensor Spec
Fairtax4me replied to mwbean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnything that doesn't indicate a broken circuit is good, but the sensor outputs are more important than resistance specs. Check each with an analog multimeter set to AC and look for the needle to jump. There is a pattern to the "jumps" which can you find in the FSM which you can find by looking here: http://www.main.experiencetherave.com/subaru_manual_scans/ Something like 1, 1 2, 1, 1 2, for the crank sensor and 1, 1 2, 1, 1 2 3, for the cam sensor. Or maybe it's the other way around, I don't remember exactly.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe old seats seem to hold up better too. Both of my cars the foam in the side of the bottom cushion is collapsed and you can feel the steel bar of the seat frame. Most of the older cars I've sat in the seats are still in good shape.
2.2 stumbling
Fairtax4me replied to shanta74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSound like the timing is off. Pull the belt covers and check the cam sprockets marks with the engine at TDC. This is the one time its ok to use the arrows on the sprockets. They should all point straight up. Other possibilities are plugs and wires, vacuum leak, or a loose intake tube.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that didn't take long. Found one in a 90 legacy with 194k on it. Just have to hope it works. Car was nice though. I took all the seats too. They're grey but in really nice shape and the drivers seat has adjustable height and lumbar.
1998 Legacy Outback Pedders springs/custom spacers
Fairtax4me replied to kanurys's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo looking in the FSM, there is no specified adjustment for caster on these cars. If you do some googling on doing homebrew alignments, you can do the "string method" and with some complex math (like adding 2+2 :-p ) you can figure out what the current measurements are and which direction you need to go to bring them back to the proper spec. The FSM for your year will have the specs you need and how to measure them. How you design the parts to compensate for the lift depends on how much adjustment needs to be made. With a 4" lift longer brake lines will be a must. Hopefully you won't need to extend any wiring, but the radiator hoses can probably be replaced with those universal flexible ones. Automatic trans cooler lines? Steering shaft will need to be extended, not hard to do if you have a welder and some metal pipe laying around. Don't forget about lowering the driveshaft support bearing, rear cross member, rear trailing arm brackets, rear sway bar brackets (if you want to keep that), rear diff support (the big Y part), and the pitch mount will need to be extended. Although it might be easier to just make a drop bracket to bolt onto the firewall than to make a longer dogbone. I have a full 2" lift kit for my car sitting in a box in the shed I'll look at the list of parts it came with tomorrow to see if there is anything else, but I think that covers all the basics.
How to get motor and manual tranny that last bit together?
Fairtax4me replied to mtnpat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you center the pilot tool when tightening the bolts on the pressure plate or did you let hang all on it's own? If you just hang the disc it will be out of alignment. You need to wiggle the alignment tool all the way up, down, left, and right, to find the center right after the pressure plate starts to grab the disc. With the trans in gear you can turn the output stubs on the differential and it will turn the input shaft to get the splines lined up. One of my tricks is to ratchet strap the engine to the firewall and ratchet it back to bring the angle of the bell housing away from vertical. This will give you more room to move the transmission around without hitting the firewall or tunnel, or getting the release fork hung up in the pitch mount bracket.
2.2 crank sensor removal
Fairtax4me replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the alternator, grab the top of the sensor with some pliers and twist it to get the rust/corrosion knocked loose. Then twist and pull it out of the housing. If it's really stuck you can drill it out and drive a self tapping screw into it to pull on it with.
Forester Vibration Problem - Serious
Fairtax4me replied to rmmagow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is probably due to a worn inner axle cup. That could account for the clink when going into gear as well. The trailing arm bushings have to be pressed in. Replacing them on your own will be difficult without a press. But you can probably rent a ball joint service C-frame press kit to press the old bushings out and the new ones in.
Subaru Legacy lift complete! (OB spring/strut swap)
Fairtax4me replied to Mike-D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou just need the rear brackets to lower the sway bar.
Oxygen Sensor
Fairtax4me replied to shimshim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDenso or NTK make the OE sensors. Either way, it's always been my rule of thumb that you don't mix German (Bosch) parts with Japanese cars, or vice versa.
serious help needed short in 98 LEGACY
Fairtax4me replied to kirkpeer123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your battery cables. Are they tight and free of corrosion? Check the ground cable where it attaches to the body near the battery. Tight and fre of corrosion? Take it to autozone or another parts store that will test the battery and alternator.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar-part.com is where I found the one for $175. Unfortunately there really wasn't anything else very close. I'd have to go to PA and pay twice as much or more. I have a few good junkyards not too far away that have a few 1st gen cars to look in. Would be nice to find one this weekend but I'm not in too big of a rush to wait a little while for a $120 trans to pop up that I can pull myself. Yeah from what i can find the 1st gen legacy trans at least uses the 24 spline clutch so any other differences should be minor I hope. Think there is any difference in FDR in the FWD transmissions? All I could find was a pretty vague article on Wikipedia that listed a bunch of Subaru transmissions. It just listed the fwd 5 mt trans at 3.454 fd. But it didn't specify for legacy loyale or impreza.
2003 engine and what I have learned
Fairtax4me replied to Whitedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBroken rings or a hole melted in the piston. There will always be some blowby past the rings. Did you check the other cylinders for the same symptom?
Gonna pick up a 95 FWD Legacy L in decent shape. Transmission is SHOT. Has 1,2, and 3, but pops out of 3 when you go down hill. 4th and 5th it won't even go into. Thought I had sourced a good 94 Impreza transmission from a place only about 45 minutes from here for $175, had 110k miles on it. But I googled the trans code and found out it had a 21 spline input shaft. Not a big deal im thinking, until I looked up a clutch kit for it. The clutch disc for the 21 spline shaft is only 7-7/8". The 24 spline trans in the Legacy uses an 8-7/8" clutch disc. So I'm guessing that one won't work without changing the clutch and possibly the flywheel. Would make it a beach for anyone trying to change the clutch in the future trying to get the right parts. Plus I don't think the smaller disc would hold up dragging the Legacy around. So I'm trying to figure out which year cars are the best to look for a fwd transmission for this thing. I know the legacy went AWD all the time after 96. What about the Impreza? I figure I'll have the best luck looking in first gen Legacy's. Other than the transmission, it needs a muffler, fluids changed, and something in the accessory drive is rattling. Alternator or idler bearing is my best guess. Two rust spots on the rear wheel arches that need attention, shouldn't be too hard to patch those up though.
2012 Subaru sales suspended
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pedal travels further than it "should"? Is this an intermittent thing or something that works in slowly as the car wears? It could just be normal and people are expecting the pedal to feel like a BMW.
