bleeding brakes
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've used a Vacula, which is the same thing pretty much. Either works just fine. But neither is necessary. You can do it easy enough with a one man bleeder kit, or just a section of clear plastic hose. The stupid little bottle they give you with those kits is useless IMO.
Coolant flow diagram?
Fairtax4me replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like you got it. For future reference there is a shortcut button. It's the yellow icon with what looks like mountains on it and a stamp in the corner. The one right next to it does quotes.
Fairtax4me replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMostly what changes is flow through the radiator. The other parts of the system will still have flow regardless of thermostat position. I would assume that it would be greater than normal flow rate during the warm up period due to the vacuum created by the water pump. It normally pulls large amounts of coolant from the radiator, which can't be done if the thermostat is closed. This builds vacuum in the system on the "pull" side of the impeller, which will accelerate coolant flow from any other hoses or passages leading to the water pump. There will be a small amount of coolant moving in the radiator, but not a significant amount until the thermostat heats up and opens.
hard rubber hose snapped replacement?
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, plain old rubber vacuum hose. I wanna say 1/8" I.D.
Cranks, no start, injectors tuned, timing belt
Fairtax4me replied to Jim Simmons's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I've seen stranger things happen. Fuel, Spark, Compression. Pull the spark plugs and crank it (unplug the coil to prevent arcing from igniting fuel vapor). If you get fuel out of the spark plug holes, check for spark. If you got fuel and spark, check compression.
New alternator, new battery, still dies.
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the field wire is in harness with the plug. The cable that's held on with the nut is the charge lead. Yes it is.
Rear diff locking up??
Fairtax4me replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChances are the crank seal is fine. If you have a leak it's about 99% going to be the separator plate. ("Lets make it cheap so it leaks and make it completely unaccessible so it's a royal PITA to fix!" [/ Subaru engineering dept. discussion]) Yes, it can be done with the engine still in the car.
Fairtax4me replied to Jim Simmons's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you happen to unplug the cam or crank angle sensor while you were doing this work? Or hit it with a hammer or wrench by accident? What else did you change? Did you remove the cam sprockets for any reason?
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind a Napa near you and have them test it. But in the mean time, check all the ground connections on the engine and frame. Make sure ALL cables are tight and fee of corrosion. Check the main fuse panel cable as well.
Fairtax4me replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah not much way to see if it's bad other than being able to drive the car. Luckily it's not a difficult swap, just time consuming. When you remove the center diff the output shaft has to come out with it. They both just pull straight out though so it's pretty easy. Getting them back in is a trick, if you cock the bearing at all in the bore it will hang up and won't seat all the way. use plenty of fresh gear oil on the bearing race and the inside of the bore on reinstall to help it slide in easier.
92 Legacy Stalling on Hot Days
Fairtax4me replied to 79er's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a fun one. Knock sensor sounds possible. So does a dead TPS.
Wheel time
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was looking at those same wheels on tirerack. I like the gunmetal, but I wasn't sure how it would look on my white car. Yours is more the right color for those, but then you might end up with two shades of grey that don't work together.
Missing Hole !!!!!
Fairtax4me replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to me that if you ground the MT ID pin on the ECU it stops looking for all the AT related stuff? But either way. Except for the light being on the engine should run fine with no EGR. If it pings switch to mid grade fuel and you should be good to go.
Intake Manifold Torque 2.2
Fairtax4me replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXManual says 18ft lbs. No tightening order listed, but I always start in the middle and work out on aluminum parts. Broke a corner off of an intake manifold on a SBC 305 because I started on the outside. Got to the 3rd corner and CRACK.
removing rusted brake line fittings / what is the fitting size?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen that kind of rust on 7 year old Toyota pickup frames. It's not pretty. (the first of Toyota's recent major recalls)
Fairtax4me replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour center diff is shot. Search Torque Bind to get some more info. That's not a hard fix on the manuals. The transmission doesn't have to come out of the car. New parts ain't cheap though so plan on making a junkyard run. Are your front and rear tires the same size? Tread wear even?
Missing Hole !!!!!
Fairtax4me replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould he just go get the ECU out of the car he got the engine out of?
93 Impreza LS Wont Start!
Fairtax4me replied to eddiec168's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy taking the ground wire off, you let in some fresh air to mix up more magic smoke. Everything electrical runs on magic smoke. The smoke gets old after a while and doesn't quite have the same effect as when it was new, so taking apart a few connectors here and there will "renew" the magic smoke and let it start working again. If you let the magic smoke out then you're really SOL.
brake pads
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles do you have on the "new" rotors?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA flare nut wrench usually works for me. But if they're really rusty stuck the wrench will just expand and round off the corners. (unless you buy some high end $150 wrench set, they might work better) That's when you get to use the vice grips. Or get out your favorite saw, cut the line, then put a socket on the nut and use an impact gun on it.
brake pads
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah that sounds like the rotors are warped. It doesn't take long if you have excessive run-out. I'd take the rotors and have them turned. When you remove the rotors, grab a small wire brush and go to town on the hubs and remove ALL rust/scale buildup. Anything that isn't flat will cause the rotors to "wobble" as they spin which causes them to drag on the pads. It wears a small bit off here and there until eventually the rotor is no longer "flat". They make special shims to correct run-out but you need a dial rig to find out what the run-out is so you use the correct shims.
No Oil??
Fairtax4me replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas a little late on that one... The oil's going somewhere. Check your spark plugs for ash deposits/buildup.
rusty brake rotors, 98 obw
You can clean them up with a wire wheel on a bench grinder. But if there is any pitting you'll need to have them turned or replace them.
brake pads
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen does it occur? high/low speed? Hot or cold brakes? If you're currently using semi metallic pads then any type of ceramic will be a huge upgrade. Duralast ceramics have worked very nice for me on other vehicles. If there is a Federated Auto Parts store in your area they sell re-stickered Raybestos/Wagner ceramics for a good price. They were $40 here, but price may vary in your area.
brake pads
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh. Maybe check Tirerack then, they carry them. Though I'm not sure of their price...
