repair hole in fuel filler neck
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI never said to do it while its on the car. :-p Although if you filled the tank with gas all the way to the very top of the tube you could. (maybe)
I know, I know, I should just replace it
Fairtax4me replied to griffenrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't see this as a big deal. I've never replaced one on any car that I've ever owned. But I've never had one that leaked either (even if there were plenty of other seals that did). I guess if it starts to look wet around the drain plug then replace it on the next change.
Air conditioning questions
Fairtax4me replied to SubaruForDan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess I've just been around cars for too long. I can't figure how anyone would have a hard time finding an AC compressor. Especially under the hood of a Subaru. But you got it all fingered out now so it's all good. Re-charging with the kits they sell in parts stores is done through the low side fitting. Most of the time an AC system that is not working is just in need of a recharge.
Stuck in neutral... sometimes
Fairtax4me replied to subyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis car have a cable operated clutch or hydraulic?
Tranny problems
Fairtax4me replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFluid is probably low. Change it again, and make sure you check the fluid level with the engine/trans warm and in park with the engine running. Shift through all gears before checking the level.
Electrical issue (strange!)
Fairtax4me replied to BrightLights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich would work fine, except that's not the way it's allowed to work. Legally the driving lights have to turn OFF when the high beams are turned ON.
1996 Legacy Problems
Fairtax4me replied to jason53818's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTrans oil cooler will be in the side of the radiator. Drivers side end tank IIRC from looking at cars in the junkyard. There will be two small hoses (1/2" dia.) one about 1/4 of the way form the top, the other down near the bottom for the transmission fluid. It's pretty easy to check with a vacuum gauge, or a cooling system pressure tester. You'll need to remove the lines, and apply vacuum to one side or the other while the opposite side is capped closed. Or you can remove the lines and put pressure in the cooling system and watch for antifreeze to drip from the lower line. I found a picture.
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJB weld, fuel tank repair epoxy. You could even solder/braze a patch on if you're really good with a torch. JB is quicker though.
134a capacity in a '94 Legacy?
Fairtax4me replied to rsthj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll the parts seem to be the same from 94 to about 98 so I'd imagine the capacity should be the same.
Top speed on 94 legacy sport
Fairtax4me replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can only go as fast as the tires will let it without blowing out.
Fairtax4me replied to BrightLights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo the green wire has voltage at all times when the switch is on. Did you check the white wire for continuity to ground when the highs are on? I'm thinking its something like this. They've got this drawn up with marker lights but it can work with any bulbs just the same. The purpose of this is to make the side marker alternate blinking with the front turn signal bulb. Normally the side marker is just on solid. By cutting the ground of the side marker and splicing that into the signal wire of the front marker/turn signal bulb, the side marker light grounds THROUGH the bright filament of the signal bulb. For some reason (I'm not well enough educated about electricity to explain how this works) the side marker will light and the bright signal bulb will not. But once the turn signal is turned on, the signal bulb lights, which I guess cuts the ground path of the side marker bulb, which then turns off. And the bulbs alternate blinking. Maybe there is some circuitry similar to this with the high and low beam bulbs in your car.
How to use sealant properly?
Fairtax4me replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they told everyone how to use it properly they wouldn't make as much money on people coming back to buy more after screwing it up the first time.
Fairtax4me replied to jason53818's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah that's normal for the lights to come on if the engine stalls. I'm gonna guess at maybe a broken or jumped timing belt. Unless you've had it replaced in the last 20k miles?
How do you get this off?
Fairtax4me replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably have to remove the wood trim under neath the vents, and on the other side by the ignition switch. Sometimes you have to remove the lower kick panels first in order to do that even. Behind that wood trim there should be a few more screws for that cluster panel. Oh and if your steering wheel isn't adjustable you might need to drop the column to get access to remove the cluster.
Fairtax4me replied to rsthj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should say on a sticker under the hood. My 96 takes 0.6 - 0.7 kg. About 24oz.
Fairtax4me replied to BrightLights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can run a line from the dimmer switch under the dash, or the high beam relay to a normally closed relay. When the highs are switched on the relay cuts power to the relay you have wired up for the lights.
Freshly rebuilt EJ22 seems anemic
Fairtax4me replied to pvenuti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the vacuum line off of the Fuel pressure regulator and make sure its dry inside.
Fairtax4me replied to jason53818's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles? Is it an auto trans? Has it ever overheated? Oil in the coolant isn't a good sign. Usually that means a head gasket, which isn't common on the 22. But it could also be a leak in the transmission oil cooler which is inside the end tank of the radiator.
Fairtax4me replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMah bad. I was thinking the rear seals on the 2.2. Use a very thin film of assembly lube on the bearing surface and wipe the sealing surfaces with alcohol or brake cleaner before applying the sealant.
Bent sway bar??
Fairtax4me replied to mountainchef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake it out and lay in on perfectly flat ground, like a garage floor. Its possible to bend a sway bar, but probably not without being in a good accident first. I think you'd have to get both wheels at full travel in opposing directions to bend one noticeably.
Fairtax4me replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to remove all traces of oil and grease for any sealer to work. The end caps should not need any sealer because they're silicone/rubber. (something like that) You don't put sealer on rubber gasket/seal material because its supposed to seal itself. Use sealers for metal to metal only. Clean all of the sealer off, and put the end caps back in.
Is this anything other than a head gasket?
Fairtax4me replied to foam-n-fibre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReally depends on how much you like the car as to if its worth fixing or not. Though to be honest, at 200k, and having all the trouble that the car has, it's probably best to scrap it. There are plenty of others out there in good shape for less than it would cost to fix everything that's wrong with yours. The collapsed hose is just an indicator of bubbles in the cooling system. (air, exhaust, etc.) Foam in the coolant is a sign of a head gasket failure.
Help on Snapped Timing Belt Question
Fairtax4me replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe just did an incomplete job, possibly on purpose. He may have replaced the belt, or he may not have. Doesn't matter either way. If you have one of these engines apart for head work, you replace the water pump, timing belt, and all of the idler pulleys. That way you don't have to do it all over again in 10k miles when one of the pulleys locks up. More than likely, he knew this and is just trying to get more money out of you, in which case, you take it to another shop. On the flip side, maybe he didn't know this, in which case, he doesn't know what he's doing, so you should still take the car to another shop.
How to tell...
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a new lead. CEL popped on last night after driving down some gravel roads on the way home. Scanner pulled a P0106 Map/Baro sensor circuit/range/performance.
calibrating throttle body position sensor
Fairtax4me replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not that difficult. You just need a VOM. Connect to pin 24 and pin 25 at the ECM connector (under glove box on passenger floor pan) and adjust it to approx. 0.50V reading at the connector.
