136
There was some stuff I found a while back, that was a vulcanizing rubber cement. You put two pieces of rubber together with it, and it would bond the outer layers in such a way that you could not take them apart without cutting them. I can't for the life of me remember what it was called or where I saw it though. :-\ Exactly how much tread is left on the tires? You may be able to find a used tire store in your area that has a tire with close to the same wear. Unless you plan to drive 100 mph on a regular basis (I doubt it) Then the size and wear rating is the only thing that really matters for the "new" tire.
As long as it smells like water, ant not antifreeze, then it's fine. It's normal for the humidity in air to condense into visible vapor when cooled. Like a foggy night after an after noon rain shower. Was the condensation on the windshield on the outside? You know when you take a cold beer out of the fridge, and after a few minutes it starts dripping water off the outside of the bottle? The defroster vents can make cold spots on the windshield where moisture in the air outside will condense. Moving the temp setting from coldest to somewhere in the middle will keep dry air moving across the windshield inside but it won't cool it enough to make the humidity outside condense and stick to the glass.
The stubs are probably fine. Axle vibrations are usually most noticeable when accelerating (wobbling). You'll also usually get a harmonic type of shimmy similar to what you would feel with a bad U joint. It will come and go at certain speeds, and you might feel a clunk when going from drive to reverse. I'm thinking either a wheel bearing or tread noise from the tires. Wheel bearings are the hardest to test when on the drive wheels of any car. Best thing to try is jack up the car, grab the top and bottom of each wheel, and try to rock it back and forth. There should not be any play. If there is any noticeable movement, its likely to be the bearing or the ball joint. Have a friend rock the wheel while you look at the ball joint and the inner side of the hub for movement. A good place to watch is the outer cv joint. On non-driven wheels its easy, you just spin the wheel as fast as you can and listen.
Over filling wouldn't cause the stubs to feel loose. A new axle has new grease in it. New grease is thicker than old grease, therefore you get more drag (resistance) when trying to turn the new axle than trying to turn the old one. The front diff is "open", so one wheel can be completely stopped, while the other spins about twice as fast due to the ratio change that happens when the differential spins. You might not feel this difference in drag, but the effect is that one wheel is basically held in place almost like the brake is on. The other side (lower drag) is able to spin freely because of the action of the differential. Give the non spinning wheel a nudge by hand and see how it reacts. Lots of things can cause vibration. What is happening with the car when you notice the vibration?
You did realize this thread is 4 years old right? But since we're on this topic. I use about a two foot section of 3/16" i.d. vacuum hose connected to the evap purge line nipple right on top of the intake manifold right by the throttle body. It's the easiest one to get to, and if you come prepared with your own extra length of hose you can put the can on top of the radiator and dip the hose into the can just enough to slurp up the seafoam, while you balance the throttle speed with your free hand so the engine doesn't stall. Do a half can, and kill it, then watch the smoke show. Just be sure to face the front of the car upwind from the exhaust.
Well there's an adjuster in there for the valve lash. That would probably make a good bit of racket all the time if it was out of whack though. As far as the tensioner. Could be possible, but I think the only way to find out for sure would be to pull the covers off and start the engine. Do you have a mechanics stethoscope? Those are helpful when hunting around for strange sounds. edit: It should have been MMO. Marvels Mystery Oil.
Only one potential problem with the lifter theory... Your engine might not have hydraulic lifters. Somebody who knows a bit more about the changes in the EJ22 across the years will have to chip in and confirm. Marvels Mystery Oil. Typo, my bad. The high mileage stuff has extra detergents in it and some other additives that help prevent things like sticking or collapsed lifters. It's the next best thing besides switching to full Synthetic.
If it's by the axles it's probably differential oil. Get some non corrosive degreaser (purple power works good) and spray down the area then hit it with a water hose, try not to use too much pressure. Do that a couple times to be sure you get all the grease out of there. Drive the car a mile or so and then look and see if there is a new trail of oil that will lead you to the source of the leak. Probably going to be the axle seal since that's the only thing in that area.
That is brilliant advice. I was picturing someone digging through wiring diagrams for hours trying to match up which wire goes where and then soldering and heat shrink wrapping a gajillion leads under the hood. It's laughable how simple you just made that. Is there any power difference between the 1.8 and the 2.2?
