Vacuum Issue?
Fairtax4me replied to 1.Slow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it's the throttle position sensor or a stuck idle control valve. Did you just buy this car? How many miles on it? What transmission?
Crank Pulley came loose & mangled keyway...but...
Fairtax4me replied to CouponBarbie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou weren't the one tying up traffic on E264 in the rain last Saturday were you? I'm just kidding, but there was an Impreza sedan on the side of the road with the hood up. Seems kinda strange that the crank bolt would stay put for 7+ years and then just work it's way loose randomly. (but knowing the way the roads are there, it could be possible) :-p Did you have it in for service any time recently? (any kind of service)
Shift bushing woes...
96 Legacy awd I snagged an entire shift linkage with good bushings from the junkyard this past weekend. Today I was ready to put it in. Got under the car to disconnect mine then realized... Mine was different. The bracket that attaches the linkage rod to the selector shaft on the transmission is the only difference I think. But then I also realized, I remember the one in the junkyard being a lot easier to get to. Then it occurred to me that the car I got it from was a Fwd, not AWD. The lack of a drive shaft coming out of the back of the transmission wasn't apparent until I got a good look at mine. I'm now trying to figure out of I can modify the bracket one the "new" one to work on mine. I'd take pics, but it's raining out.
1996 Legacy rear cat converter, flange rusted off. New cat?
Fairtax4me replied to davesh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA decent muffler shop should be able to fix that. Don't worry about Carbon monoxide. I had a Chevy caprice that the exhaust system fell off of (including the cat) just past the Y pipe. Rode with it like that for 6 months and I'm fine.... I think...
Electrical issue...
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey did, although the file idea took about 20 minutes to get decent results. Quite right. [ / British accent] :-p It's one thing to use grease on a light bulb connector, but on the battery post it does more harm than good because of the amount of current that needs to be able to move through that connection.
Electrical issue...
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't say I've ever done that but I have used a pocket knife, a flat head screwdriver, channel lock pliers, even a finger nail file (the flip out kind on the back of the clippers) to clean posts in a pinch.
Electrical issue...
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA post cleaner... like this one http://www.amazon.com/gp/product/B000SL0LFU
Electrical issue...
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I got a week out of it with no trouble... now it's back... with a vengeance! Got a call from a friend that he needed a jump. Hopped in the car and turned the key, all the lights went out, nothing. Had to take the backup car (my Lincoln) and leave diagnosis of the soob for when I got back. Turned the key in the on position and I could hear a relay clicking and the key in ignition chime was making a gurgling kinda noise. Very carefully I opened the hood so as not to upset the interruption so I could take some readings with the VOM. 13.5v at the battery post. 4.2v at the fusible link in the main relay box. Reached up under the relay box and managed to get the probe on the bolt for the power wire from the battery, same voltage. Bolt that holds the cable on the starter, same voltage. Checked at the terminal it went up to 4.3v. Checked the post again 13.5V. Touched the terminal with my finger and found it was warm. Grabbed a wrench out of the tool box and smacked the positive terminal one time good... And the Lord said "let there be light"... and everything turned back on, lights, radio, chime, HVAC fan... Removed the terminal to find what looked like concrete all over the post, and some really deep pit marks in the cone of the terminal. The stuff was gray, and hard as a rock. Now I know this stuff wasn't there when I put these new terminals on because I cleaned the posts after I removed the old terminals. Only thing I can figure is that some kind of protectant was put on the terminal when it was made, and whenever I started the car it would cook because of the current trying to flow through it. And what it turned into didn't conduct electricity at all, so compounding the generation of heat from cranking the car and eventually leading to a bunch of arcing inside the terminal, pitting the post and the terminal and leaving, essentially, burned lead. Sound theory? Cleaned the posts (for the second time) and the new terminals and now its all peachy again... for now.
A/C noise
Fairtax4me replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tensioner pulley is the one that puts tension on the belt so it doesn't slip. If you go look at your engine, it's the one directly under the compressor. The idler pulley is number 1 in the picture.
How to Replace Cam Seals In car
Fairtax4me replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou use a seal puller to remove the seal. No the cam does not come out to replace the seal. You will get better info if you give the year and engine size.
A/C noise
Fairtax4me replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXListen with a mechanics stethoscope, or the screwdriver method. Or you can remove the belt and spin the pulleys by hand (engine off) and listen for noise and check for play or wobble in the pulley. Yes, it is the bearing that makes the noise, not the pulley itself, but unless you have a press it's easier/cheaper to replace the whole thing as an assembly. The AC clutch pulley will need some special tools to replace. The idler/tensioner pulley is one bolt, very simple.
P0710 and Oil Temp High Troubleshoot
Fairtax4me replied to mikerayvt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked resistance through the wiring between the TCM and the sensor?
I'm stumped. '95 EJ22 won't start
Fairtax4me replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReading through some threads about timing belts it seems that some people are able to get their cars to run at idle but will stall when given throttle if the belt is of by one tooth. So forget what I said earlier, jumped timing shouldn't be ruled out just yet.
Headlights !!!
Fairtax4me replied to BRATDUDE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTried swapping the relays?
serpentine belt diagrams
Fairtax4me replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe this will help...
squeakly idler pulley, a lesson relearned
Fairtax4me replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDifferent belt. You ought to find a U-pull-it yard. Much cheaper than a dealer.
Multiple HLA failure, 1996 2.2
The oil is delivered through the rocker shafts. That's the easiest place to check first for blockage. Another member is dealing with a similar issue except on the intake side. http://www.ultimatesubaru.org/forum/showthread.php?t=104137
Cannot get rid of this lifter tick!!!!! (NEW PUZZLING UPDATE)
Fairtax4me replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I understand the mark for installing the timing belt puts the crank at about mid stroke. It sounds like the timing could be off a tooth.
Fairtax4me replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe "uneven" cranking could be because it is trying to fire on some cylinders but not on others. Since it does run I doubt that it is timing related. The FPR is a pretty simple check, pull the vacuum hose off and see if gas drips out. Stalling on throttle input could be due to a bad TPS. It could be a stuck or sticking idle control valve, could be a large vacuum leak. If you have a vacuum gauge hook it up and see what it reads at idle.
Vibration at 2500rpm
Fairtax4me replied to john97obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the bolt is only what holds the pulley on. If the pulley is indeed loose, then it is probably damaged now. There should be no "play" in the crankshaft pulley though. I can envision something that looks like it has been beat with a sledge hammer under neath of that pulley. The alternator belt shaking would indicate that it is loose, or that something is causing it to become loose at that certain speed. Have you ever tried removing the belts entirely and seeing how/if that affects the vibration?
A/C noise
Fairtax4me replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it still makes the noise when the compressor is engaged then the compressor is also bad. The pulley rides on it's own bearing separate from the actual clutch. When the clutch is engaged the pulley is locked to the shaft of the compressor. The bearing on the pulley is no longer spinning at that point. Therefore, the noise should stop if that bearing is the source of the noise. I would suspect, since it's in the same area, the tensioner pulley for the AC drive belt. The tensioner pulley spins on its own bearing at all times when the engine is running, and is placed under higher load when the compressor is engaged. It's also a hell of a lot easier to replace.
K&W head gasket and block repair question
Fairtax4me replied to Benfolio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt fills the cracks by coating the entire cooling system with sludge. Testing in a shop is nothing like driving in the real world. The engine is turning, but it has no load on it. Even when just cruising down the highway there is plenty of load on the engine. Gravity, friction, drive line resistance, wind resistance, all play a major part in how hard the engine works to move the car. The engine is under its heaviest load during acceleration, that is when the most heat is created, and the most stress is put on the cooling system right after that. I'm not sure how your coolant analyzer works, but most will detect exhaust gases based on chemical contamination of the coolant, not by air/exhaust physically moving through it. If there were any evidence of exhaust gases in the coolant the analysis would have showed that whether the engine was running or not. If you haven't done so, change the coolant. Don't do a flush, just drain and refill with Subaru approved antifreeze and distilled water. Put a new thermostat on, and a new radiator cap. Follow the procedure for properly bleeding the cooling system and make absolutely sure that you get all of the air out of the system.
A/C noise
Fairtax4me replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to make sure that I'm understanding correctly, the noise is coming from the engine compartment? There are more than a few sources of noise near the AC compressor. Take the belt off and spin each pulley by hand to see if any have play or feel rough.
HVAC Bulbs :: Panel Removal Help Needed! [picture]
Fairtax4me replied to Shaka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould just pop out with a plastic trim tool or similar. I have a small curved pick tool that works great for this kinda stuff. Just nudge it in, turn it 90° and give it a tug.
squeaky brakes
Fairtax4me replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow long have these new pads been in use on the car?
