Rear defroster sucks
Been getting colder here at night the past few weeks. The past few mornings I've walked out the door to see frost on the car. Which never bothered me... til I got this Subaru. I turn on the defroster as soon as I start the car, and by the time I get to work (roughly 15 minutes drive) about 1/8" of the frost on either side of each line has melted away. All of the lines work, they all melt the frost, just not very well. Is it just mine or are they all like that? I often have to parallel park at work and its no fun when you can't see out the back window.
2001 OBW codes P0446 and P1400
Fairtax4me replied to baccaruda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne of the evap hoses is probably cracked or chewed through by a mouse or something. All of those components should be at the back of the car near the fuel filler tube. The pressure sensor is inside the car though to protect it from the elements.
Advice on purchasing code reader
Fairtax4me replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCAN means Controller Area Network. It's a new twist on the On Board Diagnostics system that basically allows more information to be read. Cars are getting more and more new sensors every year, and the ODB system has to be able to communicate with those sensors in order for it to maintain proper operation, and more accurately detect faults when they occur. edit: He beat me to it.
97 impreza, bad throttle control sensor
Probably not much more. Most places I've been to charge about $40 for a throttle body, and in the neighborhood of $15 - $20 for a TPS. It's not difficult to swap, but you need to use a volt meter, and you have to pull up the carpet on the passenger floor to get access to the ecu.
1996 Subaru Legacy Wagon Issue
Fairtax4me replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt issues are common. They're supposed to be changed every 60k miles, but most people don't know that, or don't ever think to check it.
Black plastic canister next to the ABS pump - what is it?
Fairtax4me replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEvaporative emissions canister. It's to catch fuel vapor from the gas tank rather than letting it escape into the atmosphere and cause global warm... I mean, climate change. The engine sucks the vapors out when driving and burns them away.
Fairtax4me replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on the car? It could be that the "new" ECU is dead. Hard to say though. Will it still start with the old one? All of those are circuit codes except for the misfire code. You could have a loose or broken ground wire somewhere causing the trouble. That would be the easy fix. My first thought was skipped timing belt. Has the timing belt ever been replaced? I'm also always suspicious of vacuum leaks whenever multiple codes show up, or general poor driveability is encountered. There are certain conditions that when present the ECU will cut power to the number one injector, kind of a Failsafe mode, to alert you that there is something seriously wrong and it needs to be checked out ASAP. Try searching those code numbers here on the board and you might come up with some other ideas to check.
How's this for some snow tires?
Fairtax4me replied to georgefgd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweet, when can I order one?
96 with OBD-1?
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet the VIN for the car. Most likely, because CA emissions laws are so strict, the sticker states that the car exceeds emissions equipment requirements for an OBD1 car. I have a 96 sedan. It is OBD2.
96 with OBD-1?
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA 96 will be OBD2. IIRC 1996 was the mandate year for OBD2. If it wasn't OBD2 by then, it couldn't be sold in the US.
Stealerships replacing heat sheilds??
Fairtax4me replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParts and labor, doesn't sound too bad. Did you have it replaced under warranty back when it first started rattling? I would have.
cutting out while driving
Fairtax4me replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOooh, where's that Endwrench article about the P1507 code... ? The P1507, I think it was only for manual transmissions that the article applied, but it seemed that that code was usually present with a ton of others if the neutral position switch was bad. P1700 is Throttle position sensor circuit malfunction. That's a manufacturer specific code, and though several manufacturers use that code, each one has a different definition for it. P1507 Idle control system fault. This, again, is a manufacturer specific code. P0122 is TPS sensor circuit low input. I'd be willing to bet all this can be cured by replacing the neutral switch, but I'll let another more informed member post their opinion.
1992 legacy, cant shift into 5th gear
Fairtax4me replied to church272003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's good news. Yeah you probably want to replace the bushings in the shift linkage.
MPG improved... fuel guage lame
Fairtax4me replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that's worse than usual. Most that I've read about the gauge reads empty with around 4 gallons left. Some people have reported improvements by running a bottle or two of Techron fuel system cleaner through the tank. You could try it, but it it doesn't work you'll have to either put up with it or replace the sender units in the tank. (there will be two of them if your car is awd, one for each side of the hump)
Fairtax4me replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat engine light will probably lead you right to the source of the problem. Get the codes read and post the numbers here. I had a similar problem that was due to an internal break in the MAF sensor circuitry. Grabbed one at the junkyard and it was cured.
anyone want to trade leather seats - grey for tan?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI could use a front seat but I think tan leather would clash pretty hard with the rest of my interior. :-p
P301-304 codes and poor mileage
Fairtax4me replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I said in your other thread. I'd bet it's still fixable. The pulley is replaceable. I bet the crank timing is off a tooth from the cams. The sprocket may be damaged, but again, it's replaceable. This is a pretty common problem on Subarus, and despite a grim diagnosis, is usually repairable.
Torque Converter Special Tool
Fairtax4me replied to pickn4him's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think he's more concerned about the torque converter pulling out of the transmission when he tries to separate the engine and trans. Just bend a piece of metal and bolt it to the bell housing to push on the converter. It doesn't need to be anything special, just as long as it will hold it there and not get in the way.
Sell 98 Brighton Wagon as is or part out?
Fairtax4me replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStill fixable I bet. If I had any money to spare I'd probably pick up that thing for myself. (the 98 I mean) After having the sedan I wish I had held out for a wagon.
What is this?
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be Autotraders fault. We've had trouble with them posting the wrong pictures in a listing several times. We usually end up with pictures of a Honda or a Toyota or something in the listing for a Mercedes or BMW. It could also be a rebuilt car. Flood damage, salvage title, etc. Go find that exact car and check the Vin against what is listed on the website. I promise it's not the same. Get the VIn for the car pictured and run a Carfax on it.
seized eng/d.p. bolts?
Fairtax4me replied to LegacyWagon92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should go ahead and replace the rear main seal. Use Subaru parts. Put a SMALL bead of anaerobic sealer around the bore the seal sits in before you install it to prevent potential leaks.
Subaru Overheating - can't figure out why
Fairtax4me replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the car need any other work besides the gaskets? i.e. Brakes, exhuast, suspension, tires? How well does the transmission shift? Is the car rusty at all? Have the timing components been replaced recently? Is there anything that you might have to spend another large chunk of change on within the next year or so if you do change the gaskets? You could also consider selling it rather than sending it to the scrap yard.
Fairtax4me replied to LegacyWagon92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't necessarily HAVE to remove the torque converter bolts. The converter will pull out of the transmission with little trouble. The only thing is you have to make absolutely sure that it is reinstalled correctly. It's not difficult to reinstall but it HAS to be installed correctly or the oil pump in the transmission will be destroyed the first time you crank the engine.
2006 Legacy hot air on driver side, cold air on passenger side.
That could very well be the answer. What made you decide to use Bars Leak in the first place?
tranny and engine oil type
Fairtax4me replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been using Amsoil full synthetic in my Lincoln for the past few years. I run 15k miles / 12 months drain intervals and change the filter at about halfway. I plan to do the same in my Subaru once I get all the oil leaks sealed up. I did regular oil analysis testing (every 2500 miles) when I switched to determine a baseline change interval. I still do testing, but now only about every 6 months. Amsoil full synthetic has a regular change interval of 25k or 12 months under normal conditions. But even doing the heavy use interval of 15k miles you still spend less money in the long run compared to the 3k/3 month conventional oil interval.
