Help! Pulley Issues?
Fairtax4me replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, not the new pulley but a different one altogether. Could have been damaged when the other pulley blew up. They are plastic, and plastic generally gets brittle with age. Inspect the belt, replace if necessary (probably necessary), and install a new pulley is about all you can do. Then find something else to break. Like the dome light. Because if one thing is broken and you fix it, something else that is required for proper operation will break. So if you break something that isn't too important, nothing else that really matters will break. It's one of those car laws. Like right after you detail the car a bird will use it for target practice.
Chewbacca steering
Fairtax4me replied to pickn4him's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly pumps that I know of that make noise even when they're fine are on Mercedes' or Fords. And at that the Merc pumps only make noise at start up, they quit after a few seconds, unlike Ford pumps which whine continuously even after warmed up. I would think that if yours is making noise and the fluid level is fine then it's probably on it's way own the drain. (btw foaming will make the level appear higher, best to check it when the fluid has had time to settle)
Fairtax4me replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBad luck? Maybe the belt was too tight?
95 Legacy Fuel Filter Replacement
Fairtax4me replied to robm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is an access port. It's under the carpet behind the rear seat. In the trunk on sedans, but either wagon or sedan it is still easily accessible.
05 Outback XT Won't Shift Into 3rd
Fairtax4me replied to nycoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it stay in just second gear if you slow down or stop? Or will it use first and second when this happens?
Engine swap question?
Fairtax4me replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think you eve have to do that. This has been discussed many times here. The search function is your friend.
P1443 Evaporative emission control system vent control function problem???
Fairtax4me replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't hurt, Seafoam is the shtuff! And it'll at least clean the injectors a bit if nothing else. Seems kinda strange that it does it only when its under a half tank. Have you tried keeping it above a half tank for a few weeks to see if it stays away? (or is that how you figured out that it only comes on under a half tank :-\) edited for content which isn't allowed by the blocker. Muh bad. :-P
How to store a Subaru
Fairtax4me replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut a bottle or two of fuel stabilizer in the tank. Throw a cover over it. The rest will be dealt with after coming out of storage.
Newb paint questions - changing color, costs..
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could take it to Earl Scheib. I'll paint any car for just $99.95!
1997 outback limited .rear door skin removal
Fairtax4me replied to beej37's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe switch plate just pops out. Get a hook pick tool and stick it in the hole by the switch and give it a good tug it will pop off. Or you can jam a plastic assembly wedge under the bottom edge if you have one. I promise there are no screws behind there.
disassembling 97 legacy and have questions
Fairtax4me replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDone that quite a few times. Usually it's snowing at midnight when I have to do tedious crap like that. The steering wheel, take out the two screws on either side, disconnect the plug for the airbag module, it's a funny clip that has to be worked a certain way. Then loosen the bolt or nut in the middle of the wheel, turn it out about 1/4" but don't take it off completely. Then give the wheel a few good tugs and it will pop loose. You leave the bolt there so that when the wheel pops off you don't hit yourself in the face with it.
Replaced Coolant Temp sensor, no change!
Fairtax4me replied to jbmorse's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe CEL should come on for a few seconds when you start the car and then go out. If it doesn't come on at all the bulb is probably burned out.
The tally thus far..... '96 Legacy FROM HELL
I feel the same way with mine. I haven't put much into it yet, but every time I turn around I find something else I need or want to do for PM. I think the "planned" list is up to about $1400 now. I can junkyard a few things for the time being but that just makes it cost more in the long run. Eventually I'll have to buy new parts if I don't want to be working on it every 3 weeks.
Help:Need detail pictures for leggie turbo
Fairtax4me replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be a diagram sticker on the bottom of the hood.
Fairtax4me replied to robm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe "canister filter' is probably the pump strainer, and there is really not much need to replace that unless you plan to have the pump out for replacement. It's not a fine filter like the one under the hood. It's there for bigger stuff like larger sediment.
Random overheating
Getting all of the air out helps. There should be a plug on top of the radiator for bleeding. Might help to park the front end uphill when refilling. There are tons of overheating threads here, I'm sure there is a writeup in the USRM about how to bleed the cooling system.
Torque Converter Replacement ?'s
If it's there, it's probably there for a reason. Get a new one from Subaru, can't cost more than a few bucks. Search the boards as suggested earlier for more detailed instructions.
Overheated...PO130 oxygen sensor related?
Fairtax4me replied to joneappleseed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXX2 Have the system pressure tested to check for leaks. Get a new thermostat and a new radiator cap. Refill and bleed the system.
which lights will light the road better
Fairtax4me replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Hella lights will work better, but you should make sure they're legal for on-road use in your state before installing them.
Fairtax4me replied to beej37's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's no screws behind the switch but you need to get it out to disconnect the wire harness. I think there's a clip back there though. Should just pop out with a good tug. Pull the bottom of the panel outwards and stick your hand up behind there to get more direct pressure on it.
Confused on which t-belt kit I need for this '96 Legacy
It's such a pain in the rump roast to get to the idlers on these, (or any other car for that matter) you'd be stupid not to replace them while you have easy access. In 6 months when that one idler that you decided not to replace locks up and snaps the timing belt, you get to tear the front half of the engine off again, and spend more money on another new belt.
cutting out while driving
Fairtax4me replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a procedure for setting the TPS that has to be followed for it to work right. You have to check the voltage feedback from the sensor at the ECU connector and adjust the TPS until you get it within the correct range. The idle code could just be a dirty IAC valve that needs to be cleaned. That's simple, requires nothing more than a $3 gasket, a can of cleaner and an old tooth brush. There are several threads here on the board about cleaning those. Takes about an hour at most.
Fairtax4me replied to jbmorse's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, but it would just cycle on and off every 2 seconds or so, not stay on constantly. And all the lights in the dash, and all the relays and solenoids on the car would be flipping out too. Least that's what mine does in test mode. I have heard of similar problems to this with some older GM cars (early to mid 90's) . It usually gets fixed by installing a new ECU. Does the check engine light come on when you start the car?
Rear defroster sucks
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMeh, maybe I'm just spoiled by my Lincoln. I think that thing could fry an egg on the rear window. It's 100% clear in about 3 minutes in the morning. It'll even melt away a pretty moderate amount of ice and snow in the winter. I have to remove the back seat to put in the new (used) rear struts I got today, so I'll pull the trim panels off while I'm in there and check it out.
Clunk sound heard when off throttle
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever used one of those but one of the techs at work has one and seems to like it. He only uses it once in a blue moon though. I might drop the money on a specialty tool if I planned to use it fairly often, but how often do you really have to change inner tie rod ends?
