WTB shifter please help
Fairtax4me replied to penth2o's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCall a few junkyards in your area. Or better yet find a pull apart and grab one for really cheap. Or you could just rig it with a bent up clothes hanger.
Removing brake rotors on '01 Outback
Fairtax4me replied to beenaroo_01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had good luck with Duralast parts. I'd probably go with the high end ceramic pads, but I tend to be a bit rougher on brakes than most people. (read as: I drive it like I stole it) I prefer the brakes to be just as responsive after repeated hard braking as they are under normal conditions. Little tip for the rotors. If there is a lot of rust build up on the hub sand it off before installing the rotors. This will help prevent them from warping due to excessive run-out. It also helps to sand down the inside of the wheel where it sits against the rotor. You don't want to do too much, but get the really heavy corrosion off.
cutting out while driving
Fairtax4me replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInfinite resistance means an open circuit, so yes, that could very well be the problem. Be sure to stop by the Subaru dealer and get a new seal for the IAC.
Steering rack bushings
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been looking into these as well. I'm pretty well decided on the Whiteline poly bushings. I just have to get off my duff and measure the rack so I buy the right size. From what I've found, most of the suspension will swap directly between the Legacy and Impreza, up to 2004ish when the Legacy chassis changed.
stumbly/rough idle
Fairtax4me replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRough idle, low power, usually symptoms of a vacuum leak.
Ej20H engine, Ignition coil/timing?
Fairtax4me replied to Adam45's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe by 95 they were all electronic, no distributor. You have a position sensor on the crankshaft that tells the ECU when the pistons are in the correct position to fire. If you're positive you aren't getting any spark, check all the fuses, check to see that the coil is getting power. You can also test the crankshaft position sensor for operation by checking for 5V reference from the ECU at the sensor. And check the return wire for a voltage pulse when the engine is cranking.
Previous owner + Stereo Install = No dash lights
X2, follow the wire and find out where exactly it comes from, and if anything is spliced into it along the way that isn't supposed to be. (old wiring for an after market alarm, remote starter, tachometer, etc.)
Where can I find a used 2.2 in WA?
Fairtax4me replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy local U-pull -it (an hour and a half away) charges 149 +25 core for any 4 banger. Not bad if you ask me.
JDM engines... any good? worth getting one?
Fairtax4me replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't bother. They have all the same problems that the US market engines have, and you pay twice as much (or more) for them trying to ship them over here. Plenty of good used engines here in the states that will make good replacements.
Trans bracket bolt issues
Fairtax4me replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had problems like that with other cars, usually because I tightened a few other bolts before all of them were in place. There is also the possibility that the chassis is flexing enough to throw off the alignment of the holes when the car is on the jack stands. It sometimes helps to put the car on 4 jack stands to minimize chassis flex and everything may line up better.
constant vibration even felt in pedals 98 obw
Fairtax4me replied to wardssix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe shifter has a bunch of bushings that isolate vibration pretty well, so you probably won't feel much there. I would think a bad bearing would make a pretty noticeable noise if it were bad enough to resonate through the whole car, but I guess you never know. Another thought occured to me, the dogbone mount (Subaru calls it a pitch stopper) bolts right to the firewall. If the bushings in it are worn out it would transmit a fair amount of vibration directly into the firewall, and consequently into the pedals.
Squeaky mornings PS pump driving belt 02' Legacy GT
Fairtax4me replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerrin is a performance after market parts manufacturer. http://www.customcarscentral.com/prnpspeng100-subaru-wrx-sti.html
Fairtax4me replied to wardssix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, so its a constant vibration but it's a high frequency. Is it a 10k rpm Dremel? Or more like a drill in concrete kinda feeling?
Fairtax4me replied to wardssix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do you mean by "quick" ? No movement could mean the engine is sitting on the frame. Best way to check them is to get under the car with a pry bar. Put it next to the mounts and try to lift the engine.
coil pack with wire to inside question,
Fairtax4me replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe for an after market tachometer? Any strange holes drilled in the dash board inside? Is there a tach in the cluster?
Fairtax4me replied to wardssix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your motor mounts.
Opinion on a potential project
Fairtax4me replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a good project to me. I'd take a free car any day, especially if it's rust free. I'd be wiling to help out if you were a little closer. DC area is a pretty good drive from here though. :-\
Fairtax4me replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't believe they are the same no. Pretty sure one of them is a tooth wider.
Fubar!! What did i do?!?!?!
Fairtax4me replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt least you remembered to put the drain plug back. And no the drain plug should not be very tight. Its going into aluminum, which is easy to strip.
Fairtax4me replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe alternator belt drives the PS as well. AC belt should be separate.
CEL Concerning VSS: I'm Confused
Fairtax4me replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVoltage issue sounds likely. Probe the connector at the VSS and see if it is getting 5V from the ECU.
95 legacy tranny no traction after flood waters
Fairtax4me replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah water damage is almost always an instant killer for automatic transmissions. It damages the clutch packs and wreaks havoc on electrical parts (shift solenoids). Can also clog up the valve body with sludge. Time for a used transmission to swap in.
92 Legacy Relay Clicking Stalls Engine
Check engine light is a good diagnostic aid. Scan the codes and post them here. I don't know exactly how but the FSM should tell you how to get the CEL to flash the codes.
High Idle Problems
Fairtax4me replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXECU may need a reset. Did you mess with the solenoid on top of the valve any? Maybe try removing the solenoid and make sure the valve moves easily. (just flip it back and forth with your fingers, should be smooth as butter) Be sure to mark it's position so it can be installed back in the same place. Did you disconnect any vacuum hoses when you did the cleaning? Double check that they are connected tightly and aren't split.
CEL p0026/p0028 codes
Fairtax4me replied to cgflyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting. Oil starvation can be quite detrimental. I'd be sure to keep a closer eye on the level from now on.
