			Gsir08
				Posts121
Everything posted by Gsir08
	EGR questionGsir08 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Anyone around here have a 1997 Legacy with a 2.2L and a 5 speed in it? I'm pretty sure the 97 2.2 5 speeds didnt have EGR and that would be the ECU I need. I need to find out if any 97 2.2's had no egr
	EGR questionGsir08 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Thats cause its a 2000, I think they did out with all them completely after like 99. not sure though
	EGR questionGsir08 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX that could be... 2.5 is likely to produce much more emissions.
	EGR questionGsir08 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Your 98 2.5 MT HAS an EGR valve?
	EGR questionGsir08 replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Do ALL 5 speed outbacks, up to 99 atleast, have NO EGR? And basically the reason being because in a MT car you'd have no optimal time to introduce exhaust gasses.
	I took the a constant 12v power wire, and hooked it up to the wire that what labeled ignition in my wiring diagram. It's a yellow wire, and I know when its not hooked up the ECU does not power up. I'm like 99% sure I got the right wire for the harness I'll double check with my voltmeter to see if the wire I used is a constant 12v.
	I don't get why subaru leaves out options like a tach on brigton models, if everything wired, it cant add much to the overall cost of building a car. They just must leave those things out so your more likely to be annoyed by not having simple little things like a tach and you'll just buy the loaded model.
	So now I have another question. I see that in 97 they made a change to the 2.2 intake manifolds. This is taken from wikipedia "Other Engine Modifications (2.2L 1997) The intake manifold has been reshaped to increase the airflow mass and speed, contributing to improved low and mid engine speed operation. Components located on the intake manifold have been relocated as compared to the 1996 models. EGR Solenoid, Purge Control Solenoid, etc." So apparently they changed the intakes in 97 and changed the locations of some stuff and the overall shape, but I'm assuming these should fit also?
	Basically how it works is, they take the car and drive it into there bay and hook it up to the computer running, and start the test. The test then makes them shut the motor off or they cant continue so they shut it off and turn it back on. I believe just to make sure the CEL light functions? So it all has to work like normal. And moneypit, the reason the loyale passed is cause its OBD1, they only put a sniffer int he tail pipe on OBD1's, and it can throw as many codes as it wants. YOur 97 of course will not pass or even come close with any CEL on, for anything.
