Everything posted by wysei82
Hello from WA / ID / OR border
Sure thing man. I'll PM you my phone number call or text me if you got any questions and i'll come give you a hand.
well it's scoob if you're asking. I live in lewiston if you ever need any help.
Passive turbo?
I would not buy that is not gonna increase your power at all it will actually reduce power if anything.
Northwest folks.
Rochester, WA
1988 Subaru GL Transaxle Problem
your spider gears may be shot causing alternate power deliverey. I would check your gear lube for metal shavings.
Old Subaru's from little Iceland
That my dear freind is a toyota pickup not a toyota 4Runner.
jumping into 4wd
Maybe she just thinks she's an AWD
Coolant loss
wysei82 replied to sussman00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, but i would expect it to steam a good amount while it was warmin up but sound like it only does it for a second by what you are saying
Motorcyles, what are you riding?
97 hond XR400 that has been bored and stroked out to almost 500 pretty peppy but Im a pretty hefty guy so it would be much faster if I weighed about 80 pounds less. I am not riding them but there are two classic nortons sittin in my shop. A 72 750 dunstall commando and a 74 850 commando
THE 24HR of LEMONS
if you really wanted a cheap track car get yourself a early to mid 80's celica with a 22R. It is rear wheel drive and would definately take the abuse. Can usually pick a runnin or close to runnin for a couple hundred wing wangs
Rod Knock after Swap - Damage?
wysei82 replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim guessing a hydrolic lifter if it went away after a short time. But that would be more of a loud tick than a knock
Fog lights for roll bar??
If you got a harbor frieght tools near you that would be your cheapest bet.
Please Gauge My Progress
if you are really missin the oil and volt gauges that bad you coul get some after market gauges if you didnt care about them being right next to your speedo and tach
Auto tranny pan bolts snapped...
wysei82 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBefore you try drillin the bolts out get yourself a small punch with a sharp edge.Then try to tap the remaining threads out by tappin on the outer edge of the threads and hopefully catching some little lip or edge. This has almost always worked for me
Ej swap...which tranny?
if it were me I would try to find myself a turbo tanny with dual range
