tyler_s18
  1. i have the same kinda problem. not exactly but close. mine is a 93 impreza so i will be watchin for a answer to
  2. ok cool. what would the front cross member gain me? and if i pull the harness out will it just plug into the impreza harness that goes to the the rest of the car? then to my instrument cluster and all? when i just did the harness to go from auto to manual there were two harnesses. one on the dash and one behind the heaterbox that went to the computer and engine. would i need to do both? if i do the swap i want it to be clean and easy to work on and have info on.
  3. has anyone on here done a swap like this? or is there another forum that dose more this kinda swap?
  4. i believe they will. someone said the trans outta 91 legacy will fit in my 93 impreza so i bet yours will work to
  5. thanks sorry i thought i read it all but i guess not lol. i think the only for you to get the bigger bore is either a bigger block in general or take out the sleeve and cut into the actual block but it sounds like the 2nd option there wouldnt work. maby there is a stroker ket for these?
  6. so one could simply swap blocks? will the ej18 harness fit on the ej22? im wanting to do this same swap and have both motors complete.
  7. ok cool. i will search and see if i can find that thread and what pins i will need to mess with. the imprezas never came turbo right? at least not this body style. i have 14" wheels so i do think the others are bigger but they are mags of some sort so i would rather have them anyways
  8. thanks man. i work at autozone and stil cant work the website lol. i think the biggest thing i want is the motor to plug in. it makes sense to me that it would but the guy earlier said no so...lol i wonder if the harness from my 1.8 would go on the 2.2 so the car thinks its just a 1.8. i would think it would get enough fuel i do have a bigger fuel pump so i will just mait for more feedback and keep tryin to do more research
  9. ok even if my car is a 1.8 manual it wont plug in? lol i just pulled all the dash off mine and put it back on lol are the breaks different? i need rotors in mine so was hoping they would be the same part number lol
  10. so my friend has a 91 legacy 2.2 turbo 5 speed that i will probably buy for parts for my 93 impreza. i mostly want motor and turbo set up with full exhaust and back up trany and diffs. what else can i use? struts, breaks, interior? will the exhaust bolt on or will i have to modify it? thanks tyler
  11. what dose the yellow do? just looks or dose it make them work better in fog?
  12. i dont wanna hijack the thread so pm me if you want lol... where do you guys buy the lift kits?
  13. sweet thanks man. its a 93 impreza L? engine came from a 5 speed wagon. im thinking about getting my friends turbo legacy no title, keys and the body is in pretty bad shape if i remember right. but pull that motor and turbo and possibly 5 speed and diffs then put the motor and turbo in mine and put the 6 speed behind that and then make the diffs lsd and make it a wannabe sti lol. or make it rwd and have a sleepy drifter lol. i think his motor is a 2.2 but not for sure i will try to go over tommorow and see what i can find out
