Everything posted by impoutback 97
1997 Impreza Outback Sport Face Lift
Update. Still haven't mounted the fog lights. About to assemble the new motor and debating if I should still install the dual range trans swap with this much torque in front of it.
04 Forester trans into 99 obs?
You can build hybrid axles by swapping the cups and innards straight across to the impreza axles. Just the cups that mate with the trans.
I think I warped the heads when I lost radiator fluid from the deer encounter. Now its waiting for a new Frankenmotor. Ported heads, Delta torque cams, STI high volume oil pump, 6 qt Morroso oil pan, Forester water pump and oil cooler.
Whats the best coil over strut for a lifted Impreza?
Im currently running a 2" Legacy Oudback body lift, 98' Legacy Outback front and rear struts, 1" tophat spacers up front and Forrester rear springs with 1/2" tophat spacers. Im looking to upgrade instead of replace with the same. What are my options? can I swap over tophats so I can gett a taller shock, Say... for a Forrester? Is there a manufacturer that makes adjustible bolt pattern tophats, like a universal setup?
Full AWD swap into VW GTI body
2.0 sohc x 2.5 short block = high compression. same size as a stock 2.0 but like boring it out to a 2.5 piston size.
<p>the hood doesnt slope at the front lip like the legacy outback does, so there is a bit of a gap when lining up with the grill. the fenders needed to be trimmed for the outline of the indicator lights, which left a gap where the stock lights mounted but covered well with the bra until I get around to patching it.</p> <p></p>
- 1997 Impreza Outback Sport Face Lift
loose fit and without fenders. Finally able to delete the stock 97 bumper mounted indicators/running lights since the headlights have a bulb to replace them, just needed to wire them in using a 96 plug and splicing the hot wire in while grounding the extra ground wire thats left over from the stock bumper lights.- 1997 Impreza Outback Sport Face Lift
I replaced the twisted bottom radiator mount/ cross bar with a piece of 2x2 square tubing. A skid plate will mount to it nicely in the future too.- long travel Outbacks or making Subarus faster and more reliable offroad
oops, didnt see all the fabrication that went into this rig, so I deleted my comment. Wheel on!- 1997 Impreza Outback Sport Face Lift
- Frankenmotor: 2.5<2.2 heads single port vs dual ports
I think the dual port heads would have more air flow per cylinder, especially if you were to upgrade the head pipes to the head pipes ive seen that run an individual tube to each exhaust port, merging just before the first cat.- 1997 Impreza Outback Sport Face Lift
Progress being made slowley, but surely. The front headlights mounting bracket is off of a 96 legacy and I picked up a new/used front bumper off of a 98 outback. I still need to remove and replace the bottom radiator mounting bracket/crossbar due to bend and warp. I could try to bend it back more but figured I might as well just replace it and do it right. The exhaust header is an e bay special but Im satisfied with the welds and bends so far, we'll see once its mounted. It ought to breathe real nice with the WRX exhaust I'll have behind it. I still need to find a front grill off of a 98-99 outback too.- 1997 Impreza Outback Sport Face Lift
Yeah, Gloyal, I'm full of missinformation. I'll figure it out one of these days and actually do this board justice by actually making sense about what I'm trying to describe. Trust me, my verbal communication skills are just as bad... "Im looking for this part thats behind that one thing that does this and that. You know... That thing a ma bob????...- 1997 Impreza Outback Sport Face Lift
Correction, I think I'll have to use the 98-99 grill with the 98-99 bumper. Easy fix... And I guess the '96 is just a Legacy Wagon, the Legacy Outback didn't go into production till '97, I think...- 1997 Impreza Outback Sport Face Lift
The Outback bumper does not line up with the Impreza grill and lights. That, and the fact that the park lights are wired in the 96 turn signals, is why Ive decided to do the full swap. The 96 Outback head lights have 2 mounting points on the cross bar / radiator mount. Where the 97 Impreza does not. Another reason for pulling the 96 cross bar with the head light brackets attached and I wont have to mess with spacing this way, too. The stock 97 hood lines should mesh well with the new lights and grill. Its like its been waiting for this mod all along...- 1997 Impreza Outback Sport Face Lift
Yeah, Ive swapped so many parts from a 98 Outback though, This will be the icing on the cake And untouched territory. Thats what this forum is all about, isnt it? Taking these "Legos" and reassembling them in a unique fashion. Ive used all 4 disc breaks, 2" body lift, struts, sway bars and rims off of a 98 Outback. Also bucket seats and rear strut coils off of a Forester (98 I think), clutch style rear 3.90 LSD (reclaimed off of a 240 Z) and a 2.0/2.5 Frankenmotor with a 04 WRX exhaust. Next comes the Dual Range trans and ported heads with low torque Delta cams. I have a welded 3.90 rear diff waiting for some off road too... It should look like a mini Outback now, when the new front end is installed. I'll have to do a bit of cutting to the fenders for the turn signal curved cut/border and swap out the brackets that hold the turn signals in place. I plan on replacing both my fenders anyways, due to dents and rust patches, so the first set will be a practice run. I'll probably make a template for the cut line to avoid any gaps. Maybe I'll cut it a bit long so I can roll the edge? That curve will make it tough, I think. Any body guys on here with any tips and tricks on how to approach this?- 1997 Impreza Outback Sport Face Lift
My 1997 Impreza Outback Sport has been evolving ever since I found this site 5 years ago. Since then Ive lifted and converted parts from various Subaru models, picking and choosing what will work for me and my off road capable goal. This face lift has nothing to do with the cars function except It will incorporate the large foglights that come with the 1998-1999 Front bumper for a Legacy Outback. I plan on swapping a 1996 outback, single piece/face headlights and grill onto my 97 impreza by drilling the spot welds and removing the top radiator mount support and head light, sheet metal framing. Just like Legos, It should take little tweeking to make it work. I also plan to run a 1998-99 Outback front bumper. Everything should mesh well and I cant wait to have it finished. Why am I doing this? Ive been gathering parts here and there for a couple of years now. A month ago A deer jumped out in front of my car and took out my front end/bottom radiator mount, radiator, a/c evaporator, and the passenger side head light and turn signal. Hood made it out unscathed, as did both fenders. The deer caused my passenger side front disc break to lock up and pulled me into the oncoming traffic lane. Luckily no other cars were on the road and my dogs were safe. Needless to say, the accident forced me to put my parts gathering into action and see if it could be done. I allready know that the bumper will fit and line up with the wheel wells because that what I was running when I hit the deer. More pictures to come as it progresses...- Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
I also had a leak problem with the rear windshield washer hose, maybe that's it. imt willing to bet its the tail light- Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
I had the same leak problem. sealed the top of the brake lights with caulk and the puddles stopped. I've looked into getting the 220 low torque regrinds from delta cam for my non-roller style heads. They come with shims, wasn't sure if the roller style came with shims too.- Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
Do the roller rocker delta cats come with shims? What's your clearance height at now? That bumper/pushbar is tits. I was also thinking about throwing in some removable tool compartments behind the front seats. Im always driving around with my dog in the back and the seat backs down. so i am going to build them to be used with the seats down or up. keeping the weight in front of the rear axle and low cg. the guys at the shop were giving me ship for driving around with my tools all the time, saying "if you get in a head on collision, that toolbox is gonna give you a headache." Also thinking about throwing a full size spare tire gate on the rear.- Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
It looks like the abs subject has allready been a topic here on USMB. My bad, wasn't trying to rub it in.- Wagonstien taking fully independent suspension to the next level
looks f'n awesome! - 1997 Impreza Outback Sport Face Lift
