Everything posted by Setright
There is one clip hiding in the middle of the grille, you need a narrow screwdriver to undo it. Work out how to release it by examining the other clips - they are the same. BUT! Before undoing the grille, there is a threaded rubber stopper for the bonnet at each front corner of the engine room. These can also adjust the height at which the bonnet rests when closed. Just turn the rubber stopper clockwise to lower it, and CCW to raise it.
The 2.5 does have 30 horses more, but why pass up the opportunity to get your hands on the fabulous EJ22? I still miss mine. Sentimentalities aside, the EJ22 will take a beating and love it. The 2.5 could turn into a money pit. If you do go for the 2.5 fit some thin metal gaskets instead of the squishy stock gaskets.
The hot top, cold bottom hose is a sign of bad circulation. This can be caused by blockages, worn/loose water pump impeller, or "vapour-lock" in the water pump. Vapour-lock can be caused by compression and exhaust gases leaking into the coolant, across a tiny leak in the head gasket. The pressure drop across the pump has a tendency to expand the bubbles and when enought of them collect in the pump, there is no circulation. Not what you wanna hear is it? By all means, flush your radiator, but start thinking about replacing head gaskets. You might be able to bide your time by fitting a higher pressure radiator cap. I believe your model is 0.9 Bar. Newer models are 1.1 Bar. Might be worth getting a brand new 1.1 from a dealer to see if you can control the overheating until money drops from the sky and you can afford the HG work. Dang it! Why must head gaskets fail???
Dang it! I just did a long write up of pros and cons on suspension setup and the internet ate it! Heres a short version: Impreza chassis is very stiff already, only if you intend to fit very stiff springs will you need a strut tower brace. For AutoX you should start by fitting an adjustable rear sway bar. It will allow you kill the roll induced understeer, by balancing the car. Lowering an all McPherson strut setup will induce more roll. Just go for stiffer dampers, and leave your ride height alone. After fitting dampers, get an alignment, and get as close to -1 degree camber on the front as possible. (Stock is 0.0) Rear camber should be similar, but easy to get, as this is close to stock.
Lug Nut
Setright replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
M12 x 1.25 pitch, 60 degree seat. -
Oil Filler
Setright replied to TerryHowe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is an o-ring on the pipe, no plan gasket between filler and rocker cover. -
Oil Filler
The whole pipe or just the screw cap? I am fairly sure the cap will fit straight over. If you do get the entire pipe, make sure you replace the o-ring seal on it. -
Erm, no. Those two sensors are both for the coolant temp. One for your dashboard gauge, one for the ECU. Never had trouble with an oil pressure sensor on a sube before, so I don't know for sure where they are. However, if you poke around the top of the block you should be able to find it. It'll look like the water temp sensor thingy. (It's not the knock sensor that lives under the throttle body. Black ring.)
