Everything posted by Setright
Oil Change - Do you "dry crank"?
Setright replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guys, for some reason the lads on Imprezasport.net seem to believe this theory. I was hoping you would support me :-) I would also worry about unburnt fuel reaching the catalyst during such a dry-crank manouvre. Although the missing crank sensor would hopefully mean that the ECU keeps the injectors shut. Check it out: http://www.imprezasport.net/forums/index.php?showtopic=4036
Whats this and why is it leaking?
Setright replied to theDirtyRue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it manual or auto? Manual will have two drain plugs: on the engine oil pan the plug is angled, sitting next to the exhaust manifold on one side. The transmission plug is pointing straight down, and is close to the exhaust pipe. It's quite a big plug. The auto will of course also have the drain plug on the engine oil pan. However, there will be two drain plugs on the transmission. The one closest to the engine is the front differential, and the one further back is the geabox itself. You would want to drain the diff I think. Now, be careful when you loosen the plug. If it's stubborn, get a long extension on your wrench, for goodness sake don't hit it with anything. Try to find a new washer for the plug, and don't overtighten the plug when you re-install it. The spec is 40Nm. Don't use the extension when you tighten it. A wrech about eight inches long should give you enough leverage. Tighten until the plug won't move easily anymore.
Setright replied to theDirtyRue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's not a clutch cable, they connect to a fork on the other side of the engine.
I have been confronted with a theory that seems a little absurd to me: After changing oil, disconnect the crank sensor and crank the engine until the oil pressure light goes out. The idea is to ensure that all the oil galleries are primed before you allow the ignition to come on. Yes, the filter is primed during the oil change. The word is that "Subaru's are notorious for throwing a big end bearing after oil changes". Anyone ever heard of this????????
Setright replied to theDirtyRue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure looks like the speedo cable to me. Too far back to be engine oil. Auto tranny as far as I can deduce, which means that it's your front differential leaking. That uses 75W-90 oil. Drain it and refill with the correct amount.
Creaking Clutch Pedal and more....long...
Logically, it can hardly be clutch related. The shunt must stem from the engine and transmission mounts. They are probably just soft and goo-ey to stop noise entering the cabin. Of course, excessive drivetrain slack could also cause the problem, but that would take an obscene amount of gear-wear to arrive so quickly. Maybe the dealer lifts the engine out to replace the clutch and puts new engine mounts in? Some people have apparently had succes with stiffer engine mounts - STi parts.
Josh (Legacy 777), How's Your Tranny?
Setright replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, flat as a flat thing. Keeps the wind blowing though :-)
96Legacy valve cover gasket cost!holy crap!!!
Setright replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, they are not cheap! But they will last a long time. UNlike the ones that the car came with from the factory.
Shroud removal question
Setright replied to unverviking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, just plastic rivets that are pressed into rubber-rings. Easy.
How does AWD work in slippery conditions?
Setright replied to jeansain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI though she had some sort of accident...and those were double airbags :-)
Setright replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHolstebro, eh? Nearly Hillbilly country ;-)
Synthetic Oils-There is a difference!
Setright replied to outbackfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChip, that would be part of the idea. Extend drain intervals. You could do like me and replace oil and filter between 6 and 7 k miles. Or, as I am starting to consider, replace the filter at 5k, top up the oil, and not actually drain until you reach 10k. That would easily match the price of mineral.
new '96 Impreza owner
Setright replied to tls223's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI already did that! 100,000km timing belt. 50k km coolant and trans oil. 12,500km engine oil. Remember, that is from the manual.
Setright replied to outbackfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, my experience with many cars, over many years has been an improvement of 4-5% when they were switched to Mobil 1. I am not talking about brand new cars that were only just running in.
Setright replied to outbackfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXErm...well..the best objective proof I can muster is that Porsche and AMG choose Mobil 1. BMW selects Castrol's fully synth. At least that means these oils aren't crap.
Setright replied to tls223's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt at 62k or four years. That's the REALLY important one. Engine oil and filter at 7k. Manual transmission and Differentials at 30K. (Not sure on the automatic) Coolant at 2 years or 30k.
Setright replied to jeansain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEXACTLY! Better to have the wheels on ice spin away the excess torque, as with open diffs. LSD will keep power going to those two on the pavement and produce a serious amount of yaw. Even if it's only the rear that has LSD.
Can a head gasket be replaced without
Setright replied to gsrxrsx68's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, did it on my EJ22
Help please. Engine running very rough and p1507 code.
Setright replied to rjp98outlook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck all the rubber hoses, one of them might have fallen off.
Setright replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJosh, some dealers here in Denmark recommend a straight 85 og 90 gear oil. I of course have turned to a new religion and insist on using Castrol TAF-X, which is 75W-90 and really flatters the Subaru gearbox. AKA "Syntorq" stateside. If you want a good drive: Get your car on a freight ship and we can meet at the Nürburgring "Nordschleife". I am planning to go again next summer :-)
Driving without thermostat...
Setright replied to stanigu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour headgasket problem, compression leaking into the coolant, causes overheating by producing tiny bubbles in the coolant. The pressure drop across the water pump has a tendency to expand these bubbles so that they collect and cause a gas pocket in the water pump. This stops the coolant circulation, and your engine overheats. Without the t-stat, there is enough flow to keep the bubbles moving. This is only a temporary fix, the HG leak will grow and you risk mixing oil and water and wearing out the engine very fast. Start saving for the HG repair!
Whirring under gear lever
Setright replied to Zik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGearbox main bearings. Drain the oil and check it for metal shavings.
96 Legacy valve cover gaskets.....
Setright replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXagreed.
Setright replied to jeansain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. Your Sube would have to spin two wheels, that takes more effort than the Merc to spin just one.
Setright replied to outbackfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlitz ! Ranger, I cite the Porsche and AMG choice to highlight the protection of Mobil 1. Of course, you cannot overlook their desire to free up as much power to the wheels, instead of losing it in the oil.
