Suba_GL_87
Everything posted by Suba_GL_87
nice size for lift on mpg compare other. haha.
ya, i find from the rear driver light from the plastic box ...there is 6 code with small white/yellow connector? it's for wire connector trailer? also... i was looking for internet try to order hitch bar... but no drilling? so, i check under my wagon there have a 'rubber with black circle' (which can take off the rubber) for install hitch but there is big hole than i thought? it's normal or what.
15 gallon gas tank and more than 500 miles w studded snow? awesome.
Oregon Law highway 55mph. 34mpg highway. 28mpg city.:cool:
ball joint.. when u see rubber mess up like a worn out. cause your tires have a bald on the central tire? maybe... lose the engine's holder bolt on the cross member. make a shake when u get high torque?
i could put on yellow for subaru fave. but i would like to Red because of my grandpa's blind-color. he had passed away from year ago. my wagon will must higher torque from my grandpa's angel push on wagon, while i driving. im still thinking about weber carb. but i heard about some they do drilling on manifold before install weber carb? silly..
stabilizer bar lose? check on the bolts under-car. shocks lose, maybe went bad? you use snow tires, maybe bad balance? if not... go to alignment.
thank for sharing. im still project for body, under-technician, electrical & driven-train shaft.
280K miles easy than you think 8) rebuilding; 3.900 dual range, over-haul engine and gasket kits. sexy. thank you for my sharing,
Ea82 head gasket replacement how to
Suba_GL_87 replied to Murdockleone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, new manifold gasket before sorry. do you know how to what u do for timing belt on ea82? it's tricky. whats kind your head gasket? cuz torque reason. -
i was use the lube with mainshaft and drive-driver with wide flats. i was put like a perfect on the seal...and deep as enough. BUT i thought so, i need get the pvc collar in home depot, should be them more deeper than i thought. it's make a sense to me. im question for how much cost for repair seal in shop rate? when i send my car..?
http://www.ultimatesubaru.org/forum/showthread.php?p=1082047&posted=1#post1082047 I've been problem for three times and replace oil pan with RTV, rear seal main-shaft and breath plate with RTV when i was removed the automatic transmission... and then, there's still leaky from main-shaft rear seal...when i was started on the engine under the 30 sec became pour the leaky?! what's wrong with it? did i wrong put main-shaft seal? or have go to shop for replace new main-shaft seal?
