Everything posted by 86subaru
knock sensor
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk thanks
knock sensor
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI broke the connector.off by mistake used a different one .car runs worse know .any help? Thanks
knock sensor
Is there a difference in years of knock senors.like from 99 to 95? Thanks
95 awd a/t 243.000 2.2
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK.now brake light comes on a few times.thanks will clean cables on starter
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like weak battery .but only last like 2-3 seconds and starts fineq
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid that.could it be the coil pack?
Hello all.no codes .no alt issues.start up hesation just for a few seconds.good battery.new NGK plugs wires.new fuel filter..air filter.sea form thing..what next to look at ?
transmission fluid leak 95 awd a/t wagon
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow easy is this ? what parts to i remove to get to it ?
- transmission fluid leak 95 awd a/t wagon
Easiest way to test fans?
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems like it takes a long time to heat up.coolant is set up at -30 heat is not real hot temp gauge is 1/2 way possible thero stat?
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot real cold out. Will check
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe temp sensor is pluged in
- Easiest way to test fans?
Check engine light on 91fwd a/t
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot it thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChanged it o ut with good one.the old one was really cracked never changed
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk knock sensor. Code 22.could this be a old ghost code in memory??
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLong long short short
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk after reading code is it possible to clear code
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan not seem to find black wire. What color does black wire plug into
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks
How or where is the plug to put in the code reader? Car runs fine
- Code po440 evoporation control system
2001 outback limited
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHis asking price is aleast 1000 more than it's worth .so more than likely not buy it
