86subaru
Everything posted by 86subaru
  1. can i drive it with one belt on ? alt, crank , .the other tenisioner broke and until i get one ??? will there be any possible damage ? thanks
  2. 16 flashes at start up ,are all duty c the same in the 90s ? if that is what it is ?
  3. ok, 16 flashes on start up , put fuse in light on dash came on fwd , whats the cost of duty c solinoid ? or used ? can it be picked up at parts store ?
  4. no tight turns ,but the abs light is on also. only flashes like 5-6 times, where is the duty c solinoid ? i have already drained fill of tranny , i will put fuse in to see if light comes on and flashes go away,if that does not fix problem i have read that you can make it fwd all the time not sure of location ?
  5. my 95 impreza a/t flashes at start up , but goes away after a few seconds , not sure if this is normal ? 137,000 mi
  6. sounds like something rubbing just a quick rubbing , when i put newer hub, bearing knuckle ,parking brake , brake line , i did not adjust anything , used the shoes that came with the whole unit , the other side is good ,
  7. ok, seems to be different or looking at the wrong bolt, thanks
  8. seats are out still can not find fuel pump 2000 legacy wagon
  9. yes they do , but the rear do but a pain in the butt
  10. thanks, they look like they would and are in better shape,
  11. will seats from a 2000 legacy wagon work and fit inti 95 wagon , the 2000 seats look better and set better
  12. yes sorry, thinkin it was a dumb question, anyways replaced both headlights with a brighter ones, there a certon way they go back in, ? seems that one of them is adjusted way up now,
