Everything posted by 86subaru
bad wheel bearing rear
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcar has 219,000 mi on it but motor runs great ac even works , nice stero
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpassanger side rear , also lost brakes , ? almost caught fire ?
bought a 95 awd a/t wagon with a bad wheel bearing , got alittle hot driving home what damage could have happaned ?melted booth on rear axle how hard is it to replace rear wheel bearing , or buy a used hub with good wheel beaing already in it
2000 legacy poping problem
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, already swapped coils , but my spare could be bad
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalready did , but will look again
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare the exhaust valves easy to change
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtiming done at 100,000 mi no damage, mpg at 25 highway ,when you push on gas is when it pops alot
2000 legacy a/t 131,000 mi popping comin from drivers side , check engine light flashing , code reader 3-4 misfire, shop says cam is damaged , new plugs, wires, ejectors cleaned, fuel filter,good coil
2000 legacy took a dook
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes no real time working 6-7 days a week now,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX130,000 on motor, timing belt done at 100,000 mi
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe shop i took it to said it was cam problems, drivers side, looses power, almost back fires, when you give it gas, mpg is still good 25 high way, can no longer get coolant stuff,
motor leaks coolant, drivers side cam needs replaced, possible wheel bearing , but still runs , but needing another subaru
2000 legacy a/t problem
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, thanks, may just take to my mechanic
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno but will check , changed pvc , fuel filter, plugs, wires, no real change misfire 3and 4
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchanged both plugs with ngk, , found cylinder 4 plug covered with oil ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, are the seals hard to change,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchanging the wires did nothing, alot of oil inside plug wires, power is very slugish , 3and 4 cylinder misifire , check engine light on flashes 8 to 9 times , if you slowly press gas pedal it is ok, mpg is less now, wouls changing the plugs help or not, 129,000 mi on her,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame cylinder
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstill having problem,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes good thinking easy , thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, newer ngk wires/ plugs , 6,000 mi ago
check engine light on , code says po304, , changed fuel filter, coil pk, gas cap, still on , flashes 8 -9 times stays on, starts fine , but when i push down on gas pedal sounds almost like ready to back fire ? any help thanks
dash lights out 95 wagon
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks to all reply
