Everything posted by 86subaru
dash lights out 95 wagon
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok,what does the lighting amp look like ?
cv axle question 2000 forester
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbehind the hub ,thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon the cluster ,yes there is a switch on the steering wheel ,wondering if a away to by pass the switch with a toggle switch
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsorry 99 forester has bad passanger side cv axle, i have a spare good axle from a 95 legacy L sedan , wondering if it will fit ? my mistake
seems to be the switch, do not have one, would there be away to put a toogle switch to turn on the dash lights or not , or a relay some way, to replace ,thanks or where would the relay located, checked all fuses ,and under hood, ?
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgreat ,almost went out and bought one, thanks
will a axle from a 95 sedan awd fit onto a 99 awd forester ,both a/t , thinking it will not ,but worth a try ?
coolant leak after coolant change
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes coolant , put cardboard on floor and found green coolant on cardboard several times now, center of motor right where u would put a floor jack if jacking up car in the front, all heater hoses were dry , i hope no hg
justy 93 questions
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, thinking 1300 is alittle hi , drivers seat needs replaced , broken on one side, also wheel bearing + tires,
justy 93 questions
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, yes did a search , owner thinks motor has been replaced, asking 1300
justy 93 questions
155,000 mi 5 speed, white, front wheel drive, good points ? bad points ? or things that are common problems ,yes basic car ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtook it for drive , parked it ,started to leak between motor and tranny quarter size, no bubbles in over flow, under cap looks good, heater hoses good, radiator hoses good, nothing leaking on top of motor,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, funny thing is all i did was change the coolant , drained and filled flushed out with water only, did not leak before,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot some sealant , still leaks but only leaks after driving it and sitting with motor off size of a quarter , so trying to see where it leaks , checked all hoses after sitting all nite, all look good , but will drive it again and check again , any suggestions
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgreat post , got it all sealed up no leaks could have been to much coolant in reserever also
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, looking closer seems like it coming from the water pump area instead , may need new water pump + gasket , thasnks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcalled dealer , no longer available , i guess replace head gasket
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i know the subaru conditioner is better , but is there any other stuff that works as good, that can be found at any parts store ? it will take aleast 3 days to get here and wanted to put it in today ? thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, dealer is like 1 hour away , yes i will
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno subaru stuff put in yet, no burp, just drained and filled flushed out with water used good name coolant, seems to come from center of motor, thanks merry christmas / happy new year
flushed out changed the coolant in my 2000 legacy 2.5 a/t now leaking alittle coolant size of a quarter , :horse:any comments , hg ? going ready to blow, 127,000mi
Did Subaru improve its head gaskets?
86subaru replied to alaskanjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot sure about hg , i delivery at the plant where they are made, i asked a few people there, they suggested changing the coolant more often, than what the manual said,
2000 legacy possible u-joint
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for all the help, will do the easy simple things first,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks, also seems like the rear drivers side caliper goes on real tight, remembering , i have a whole hub new bearing , for a 99 forester will it work or not ?
