86subaru
Everything posted by 86subaru
  1. i have 1 also from harbor freight , it works pretty good , but do not use it every day
  2. yes by the pc, both my 2000 legacy and forester, less than 2 bucks ea.
  3. check tranny fluid , or change it, front/ rear diff , make sure all 4 tires match, oil leaks, belts , hoses,
  4. how about using the white ones any good, ? some one gave me a few 3593a
  5. kinda of, my garage door opener would lock my car sometimes with the key in car , that was on a 2000 outback
  6. just do not use stp oil filters, no check valve very cheap made
  7. well tried it , drained filled tranny again and seemed to help alot, will tell more in the morning, [ used x tranny stuff]
  8. yes. but after that it is fine sitting 10-12 hrs at work,
  9. drained filled drained filled tranny changed filter, 160,000mi on it a/t , after sitting all nite it shifts good but shifts alittle hard first time after that good, should i drain fill it again but use royal purple , ansoil , or = to it , thinkin it might help ,any suggestions ?
  10. none here at true value hardware, here in cincinnati now, going to u pull monday, or dealer,
  11. need aleast 2-3 metric bolts 8mm thread 12 mm head , threaded all the way up 6 inches long, they are for the alt hardware , the bolt many people brake off
  12. put in heated power mirrors , 98 forester L model a/t , where is the relay for it , or fuse et.. looked under glove box , steering wheel
  13. 1/2 in rachet, or 1/2 in braker bar,passanger side dip stick for rear diff, thinking 22mm front diff
  14. 99 forester , it took 2 people to put it back on,
  15. took door panel off , found window motor unplugged, had more trouble putting door panel back on,
  16. ok, found a different master switch , still drivers window will not go up ,.a buzzing noise in door now all others work , battery seems to hold a charge now, could i have not hooked up something while having the door panel off ,thanks
  17. new alt, old battery it is a oem stereo from a newer outback ,broke the door switch also board ,now window will not go up, never did this before all plug and play now dead battery ???????dam
