Everything posted by 86subaru
Head gaskets or not?
86subaru replied to RussellW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso bought a 97 outback with t-stat out, but dropped a 2.2 in it,
buzzing noise 2000 legacy a/t wagon 2.5
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreplaced both relays making noise , still getting buzzing , no hard start , runs fine , does not buzz all the time , very cold outside, everything is off , here is one thing there is a remote start ,but i have no remote to use it,
coil pack question 2.2 legacy
there are 2 different types of coil pack for ej22 motors , 1 with plug on pack and one with a pigtail and a plug are they the same or different, thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, my spares were different will not work,but the strange thing is only makes a noise when it is cold out checked #rc 5001 and rc 5008. 3 of each .
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, i'll change both will autozone carry them or special order ? well found spares but from a 95 lsi 2.2 denso type are the same 4
buzzing noise coming from main fuse box under hood , located which one the 2 black breakers closes to the drivers side strut ,but only does it when it is real cold out 10-15 degrees , checked both out all clean , should i replace or nothing to worry about,right before i start the car,
what's it worth?
86subaru replied to Ceejus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes around 600 bucks, check underneith , for bad axles, oil leaks, touque bind,+ parts aleast around here are some times hard to find, but then you can buy them here,
Suicide by timing belt Please Help!
86subaru replied to Jaimesbeam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfind a good used 2.2 motor
Transmission fluid
86subaru replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo not use wal-mart brand oil , it will make your subaru smoke alittle,
P0400, P0115, P0420 codes
86subaru replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX;;;;;;;;;;;;;
86subaru replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, but still would not hurt to clean it, any pics of the part your talking about, i have all spare parts, i am thinking it's the brown color sensor,
86subaru replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake egr off clean it with old tooth brush or wire brush
86subaru replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot the same code tonight po400 code exhaust gasket , cleared it , wondering if the egr needs cleaned out ? not sure if i have done that
Stalling at a stop after a long drive - car's first problem
86subaru replied to Kraynek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany check engine light on, could be coolant temp sensor, autozone will check it for free, i had the same problem ,
ATF Leak -- is it special tubing?
86subaru replied to gl2tosl2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine leaked also , 3/8 hose , i used a piece of new hose , good quality
thermostat
86subaru replied to derby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshould be lower radiator hose round gray color
fuel pump noise 2000 legacy
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsilver in color round ?
every so often after sitting all night , the fuel pump makes a noise coming from the main relay box under the hood , on my 2000 legacy L wagon, a/t , could it be the fuel pump relay ? if so where is the relay ? passanger side , or drivers side , or black box under the hood , if so which relay ? thanks
Seriously, Recommend Me Some Wipers
86subaru replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanco winter blades
Acceleration and Idling Challenge?
86subaru replied to Quest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany cell showing up, autozone will read it for free, i kinda had the same problem , bad coolant temp sensor, real pain to change ,
What is this hidden plug in the door?
86subaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes tweeter kit option
coil pack with wire to inside question,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell it does have a factory tach in the dash
noticed a wire tapped into the coil pack and running though fire wall to some where inside , car runs fine mpg is 23 city , idles fine ,etc.. just wondering why it is there, 2000 legacy wagon a/t awd, 108,000mi thanks
adding conditioner,2.5
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes new coolant + timing belt, water pump, stat, thanks will add,
should i go ahead and add the subaru conditioner to the 2000 legacy 2.5 , no over heating ,no problems now, or wait ? or over kill
