86subaru
Everything posted by 86subaru
  1. will check , sure seems like that to me also , thanks all , very hot out , trying to get to hospital to see mother so it adds to it,
  2. yes i agree running fine, but one thing i did not check was the air filter , which was very dirty , the car would stumble a few time , so decided to clean maf sensor ,now it starts but stalls ,if i stomp the pedle it will run but stall out, no check engine light on
  3. cleaned it with mass air flow cleaner , it will start but stall out , also changed air filter which was very dirty , check all vacuum lines all good ?
  4. no cel, no stalls, just at 65-70 mpr , not sure how old wires plugs are, temp gauge in the middle, very hot humidity very hi ,shifts fine all gears, new hg , valve job, also mpg is only 21 mpg, a/t , could it be a coil pk going bad, ?coolant temp
  5. 99 forester 2.5 a/t 157,000mi + mpg is 21, sluggish at take off , i have not cleaned it yet, new air filters, cleaned intake, new fuel filter,
  6. my boy had a accident no one hurt, front bumper cover broken, tire blown out, , fender, went to put on different tire same rim same size tire, the tire almost hits the mud flap , not sure what is bent
  7. it should show full, check it when engine is cold
  8. yes one of the tail lights were out , replaced it ,thanks
  9. buy a 95-97 with a 2.2 subaru , will last well over 200,000mi , i own 3 subaru;s 97, 97, 2000
  10. checked it out again no spark , changed coil before , for some reason the plugs are hard to change the socket will not go all the way in , i have a deep well
  11. the old one really had to get out ,broke off the top of the sensor
  12. ordered a new one oem, the old one broke off trying to remove it, is there another place which can be mounted and work , still no start, new cam sensor, coil , fuel filter , plugs wires, check all fuses, grounds , and getting fuel , newer timing belt, water pump, just cranks, just about ready to tow it to the junk yard
