Everything posted by 86subaru
no start,97 2.2
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok,think i found the problem cam sensor, but had to order one, as much $$$$ as i spent i should had it towed to a shop
no start,97 2.2
changed coil , fuel filter, plugs / wires, oem, crank sensor, getting fuel , but seems no spark on crank, any more suggestions ????????????before i quit and torch it
dumb questioin 97 legacy
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstill no start, checked fuses, relays, new fuel filter, plugs / wires, oem, different crank sensor, getting fuel , but seems no spark , changed coil pack , any more suggestions
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck all fuses and relays, chaunged coil pack, but will check again
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno check engine light on ,yes on the raw fuel
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno it;s not the one we did a swap on, [ white wagon] it will not start , changed coil pack and it ran great and started right up , now no start , changed coil pack again, maf , changed plugs/ wires oem, crank sensor, good battery, full tank of gas,
my 97 will not start 2.2 a/t 176,000mi ran fine before,are all coil pack the same dimond , are all crank sensors the same , i used spare parts,the car stumbles and almost starts
Any non-EGR 96-99 EJ's on here?
86subaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXautomatic
spark plug socket size
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes on the rubber plug, went and bought a 5/8 1/2 in deep well socket, will try tomorrow , if not working, thanks
86subaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 2000 has no egr unless it is located in a different place ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea, the the store is closed up , menards might have one, lows, ,broke 1 plug wire ,so ordered a new set, still not the starting problem , it almost starts but strumbles , changed fuel filter, coil pack, tank full of gas, checked all fuses, relays, battery good, could be coolant temp, or fuel pump,yes oem nkg plug/ wires,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXboth my 95 and 97 are 2.2 legacy L wagons , thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 5/8 fits , but to fat to fit ino hole,i'll try the tool in the pouch , , strange thing is the 5/8 works fine on the 95 2.2 i did have ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have changed other 2.2 plugs on my 95 ,with no problems, not sure what your talking about peanut socket ? thanks, one plug came out and looked ok , so the plugs are not my problem ,but no harm to change them
need to change the plugs in my 97 legacy L awd a/t 2.2 motor wagon , the 3 different sizes i have do not seem to fit all the way down into take the spark plug out,5/8 seems to work , but the plugss seem to far in,
no start 97 2.2 a/t legacy
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnew timing belt water pump 3000 miles ago , but i;ll look
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstill will not start , stumbles and almost i smell gas, ???
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno but i will ,thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchecked all fuses , going to try alittle starting fluid ,could be fuel pump, i have a spare, going to try another coil pack+ new fuel filter,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalmost started ,but ran battery down , will do tomorrow night , thanks
coil pack question 2.2 legacy
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX97 2.2 a/t awd ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno start after sitting, all night , ran fine yesterday , changed coil pack 2days ago .i give up for now , to cold outside 10 above , almost tries to start , but battery goes down,
ok, switched coil packs seemed good 2 days ago, no start now, switched maf , new timing belt, water pump , tenisioner , full tank of gas, but bought cheaper gas last week, it will crank , seems like it is not getting fuel , new plug wires, [ oem] , fuel filter 20,000 mi ago, running battery down trying any help,+ changed crank sensor, got down to 0 last night , put a can of dry gas in tank, good thing i have a spare car to drive , may have to wait until spring to drive it,
Reliable quick oil change operators
86subaru replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid they replace the tranny filter with the right filter, that same thing was did to my subaru a few yrs back, but the place said nothing had saw what they did and used a wrench on the tranny filter, screwed it back on, started to leak , replaced filter myself,
Dies out
86subaru replied to woosha's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 95 2.2 did the same thing , coolant temp sensor, real pain to get to ,
