Everything posted by 86subaru
95 legacy lsi awd sedan, tranny question
bought a 1995 awd , 2.2 a/t lsi sedan , 174,000mi , it goes into drive good and shifts good, but after warmed up it takes a alittle time for it to go into reverse, no weird noise , besides changing the fluid , what else could i change ? any help.
outback maitenence tips.
86subaru replied to hardtail_pride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchange all fluids also, tranny, diff, oil, tune up, ngk plugs, ngk wires, coolant,
Can't find the tapping noise!
86subaru replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame noise on the 97 outback 2.2 , the owner before , new resurfaced heads, hg, timing belt, water pump , pullies, drove it 200 miles and started to make noise in motor, i took drivers side timing belt cover off , timing belt new and ok, noise seems to come from around oil pump area, started it removered plug wire no difference in noise, noise gets louder if i rev the motor up ,
IT'S DONE! Swapped EJ22 for EJ25 in '97 Outback
86subaru replied to kaltree's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreaad all the posts, will a ej 2.2 from a 92 legacy work into a 97 outback , 2.5 not worried about emission stuff,
Wtf, cooling issue!! please help
86subaru replied to codytotheh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you use a oem thermostat ? could have a air pocket , i just did a timing belt job and changed the thermostat + hoses + water punmp had the same problem you did , so i changed the thermostat again but used a oem
98 forester transmission codes
86subaru replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi use a code reader, any auto parts store has one, and will read it for free,
How to change fuel filter? 99OBW
86subaru replied to DiscoStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwear safety glasses when changing fuel filter, pull it outside it will loose alittle gas [ smell garage up] make sure you put it the right way on, real easy, i always spray ailttle pb blaster on the fittings to loosen the hoses, will be fairly tight ,if you use pliers be careful not to put a hole in the line,as far as the belts i would
97 obs tune up now stalling?
86subaru replied to Pgh_Scoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa body shop close by got nailed for not replacing a door on a cop car , instead repairing the door and charging for a new one,
95 legacy tranny question
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell it all depends on what else is wrong, but i offered 250 and have not heard back , alot of good parts, alum rims, new tires, new axles, interior good, ,
Mileage Drop
86subaru replied to cobalt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXiam in the same boat, but 170,000mi legacy a/t wagon i have changed everything , except rear 02 sensor, still getting 1 code map sensor, which could affect mpg, i am only getting 20 city ,
Rear dif grease change
86subaru replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse a 1/2 in breaker bar, and slide a pipe over the handle,
86subaru replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you slide a breaker bar over 1/2 in rachet , thats what i used
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, have not seen car just was told about it, thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i agree , 700 way to hi with bad tranny, thanks
afriend of mne called today asked me if i wanted to buy a 95 legacy l awd a/t 238,000mi ,but will not go into reverse + weak battery, 700 obf , not seen it yet but thinking about the tranny issue, any opions ??
po420 code, 97 legacy 2.2 170,000mi
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have not changed the plugs or wires since i bought it, 38,000mi ago, ok on the gas cap losse code, yes i cleared the code , i do have a subaru o2 sensor [ new] sitting in abox , thanks,
check engine light came on , checked with code reader, catalyst effeciency below threshold, below bank 1, car runs fine, mpg 24-25 city, did a search front o2 sensor , headers, etc... any opions, ??? also my wife may not have put gas cap on tight enough ,
ea81 brat fuel tank question
also new fuel cap, ok, thanks
afriend of mine with a 84 brat a/t ,ea81 motor , carb, he bought a different gas tank [ used], but good shape, his problem is it is vapor locking ,,new fuel filters, different canister , ,he can only drive it with the gas cap real loose, , if the cap is tight the truck will hardly start, he switched the lines still the same thing, any help ??
First Tranny swap...Done!! Pics with Lift!
86subaru replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust wondering if there is crap like that in any of the diffs in my legacy's, wondering if putting a magnetic plug would catch this ?
gm top engine / injector cleaner
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, where is a good vacuum hose on a ej22 to do this ? though the idle air control ?
ea81 rear wheel bearing 4wd question
can you drill a hole in the rear bearing housing and put a grease insert ,or better to put in self sealed bearing , and can you still buy them ? thanks
Hmmmm....milkshake crap on my oil cap....
i am also getting it in my oil catch can but on a 95 legacy 2.2 motor
Rear bumper sagging 1/2 inch on OBW
86subaru replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes that is what i wanted to say
14 mpg!!!!
86subaru replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis might be a dumb question , but has she changed driving habits, meaning shorter trips , more idling, both my subaru's are 2.2 1 is 95 other 1 is a 97 , the 95 gets around 22-23- mpg, the 97 gets 24-25 mpg, and both have 170,000mi om them , i have done everything possible to the 95 to get better mpg, , but i make short trips with it,
