Everything posted by 86subaru
battery went dead
was putting in a different stereo in the forester oem , had key on for awhile , after install battery dead, jumped battery everything good, wondering if battery is going bad, it looks older , yes leaving the key on will kill battery but after awhile not 5 min
Outback rear jacking point
86subaru replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have used a floor jack on the rear diff
strange noise 99 forester rear end
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, when i have time and car is here, thanks,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats what i was thinking also , will check it out , thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXafter sitting aleast 10 min or longer , pulling out of driveway onto road, seems like right rear noise , but not sure , and road noise ,
noise only happens when you first start the car and move it going straight, , stop, engine still running go foward no noise, if it was a wheel bearing noise would be there all the time ???? a/t
Best place to buy new floor mats for 95 Legacy?
86subaru replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXebay , all weather ,
99 forester will not start after maf sensor cleaning
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwife picked up car, throttle body and injectors, i had put sea foam into tank and alittle into throttle body , and losen up all the crap , replaced maf , it runs real quite now , mpg should inprove now
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell got it back 150 bucks, it was all plugged up with carbin , runs great now, so yes i caused it , and 300 bucks later,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i checked everything , it got towed to local shop , will find out tomorrow, no tools here to check fuel regulator , if over 200 bucks going to have it bought back home , either junk it or strip it , thing is i just bought it , off ebay ,seller did alot of work to it , so maybe bought some one elses problems ,thanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcars starts ,if i hold down the gas pedal it will run , as soon as i let up it goes back down and stalls ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, i agree on fuel pump , but switch , it starts fine first turn , idles for 3-4 seconds and stalls out , what would be the best way to check fuel pump, before i trailor it to shop , i have a spare fuel pump from a 95 lsi sedan , not sure if it will fit
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXabout 2 hours north west of you ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXinstalled new maf sensor still same problem , starts and stalls , rechecked and rechecked everything , , towing it to shop , then junkyard,
required tool maf
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbought tools, still not problem , towing it to shop as we speak , [ junk]
required tool maf
what tool is required to remove 2 screws holding maf , seems like torx ,but center tab ??
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchecked yesterday ,but will check again after new maf arrives,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunplugged maf ,start it but stalls out, , so if new maf does not work will trailer it to shop for repair
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno foresters at local junkyards , closes one 60 miles away, subaru's are not real common around here,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot after market , will not bolt up ,wife pick it up today, either drill it out or take it back , it plugs in fine and is the right one,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan i use after market,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, no junk yards around here with my maf sensor, hardly any subaru;s
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalready unpluged the maf sensor and - side of battey no difference , starts but stalls , no cell , send pm with price and pay-pal again
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsorry camera is broken, i never removered the maf sensor i sprayed into it , i could see where to spray , changed dirty air filter, also checked other air filter, and changed it, could i have caused damage to the maf sensor?which now needs replacing
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunpluged maf tried to start ,still the same stalls out,
