86subaru
Everything posted by 86subaru
  1. repaced whole hub parking brake, rear axle, ,all at one time , sounds like something rubbing while driving , are there adjustment ?
  2. will a radiator from a 95 legacy L wagon a/t 2.2 fit into a 95 impreza a/t 2.2 ?
  3. code came on how hard is it to change it ? 3 bolts and cable,95 awd 2.2 ,easy way to change it..neutral safety switch
  4. 1- the netural safety out , by putting it in netural it starts, will this work all the time, ? 2- several times wipers + radio will not work when i first start the car ,but after several minutes they work ? thanks for the help, 225,00 mi and has been cold outside 0- to 10 above at nite
  5. new tires, found one of the front axles with torn boot,
  6. 95 awd, a/t wagon 2.2, seems to like float driving down the road, shocks good , ball joints, sway bar ok, shifts good, 205,000 mi on it,
  7. will a axle from a 95 legacy wagon fit onto a 95 impreza both awd, both a/t
  8. replaced wheel bearing , axle, parking brake , wheel cylinder , on rear , only 1 side, while driving i can hear whats sounds like something rubbing , are there adjusting needed ?
  9. removing the fans will give me enough room to put in the keyway [ half moon] ?
  10. ok found a key way [ half moon] is it possible to put key in with out removing radiator 95 impreza a/t 2.2 ?
  11. 15,000 mi ago on timing belt, key way is gone no spare, but spare spocket
  12. crank bolt came off while driving lost belts, bolt came all the way out , my question is any damage done , ? it starts and moves ok, lost key also, 2.2 a/t awd, sedan
  13. ok, my brother in law needs tires and low on cash and the 15 inch are new tires , my 95 imperza has 15 inch tires and rims on it ,bought it that way , with no problems , thanks
  14. will 2000 legacy 205-70r 15 inch, fit onto 95 legacy l wagon all four ? any problems rubbing etc...
