86subaru
Everything posted by 86subaru
  1. already tried to add , fuel it up drive 125 miles reads quarter of tank
  2. my gauge is off , it works but off , thinking i read cleaning the fuel pump with a number 2 pencil?
  3. ok, thats what i was thinking , alittle smaller than a wagons i have ,thanks
  4. whats the fuel tank size ? i have no manual ?thanks
  5. pulled antenna all the way up , checked all fuses all good, abs and air bag light on ?
  6. dfid it now radio still no work , , yes got spare radio ,
  7. mine seems not to power up , any way to pull it up and leave it up ? tools needed from inside or outside ?95 sedan 2 door awd a/t
  8. just bought it abs , air bag radio works but power antenna does not go up , check fuses all seem good ,any help ?seller said did not jump start , but had set a few months, 95 awd a/t 2 door impza
  9. what would cause the airbag light, abs, and radio not working after sitting a month .95, thinking it is a fuse,
  10. dam 2000 went down , will the rear disc set up work on a 95 , drum to disc? 2000 to 95?
  11. my 95 has rear drum brakes, the forester part is rear disc
  12. willl a hub bearing knuckle from a 98 forester fit on a 95 legacy wagon , just asking
  13. ok, if i buy hub and seperate bearing can i take it some where and get bearing pressed into hub with out knuckle
  14. went to order whole hub bearing already pressed in , all auto stores are seperate why ? 95 legacy l awd a/t rear
  15. yes, but thinking about scrapping it out since the popping noise in motor and will need alot of work $$$$,buy another subaru
  16. doing some reading seems easier to replace whole hub/ bearing
  17. awd a/t 131,000 mi , noise in rear drivers side, thinking it is wheel bearing, but when i apply brakes noise goes away, also rotor is getting groved out, ? so bad caliper pads ?
  18. car runs fine , 194,000 mi just code every 3 -4 weeks
