Moto7man
Everything posted by Moto7man
I know I have to remove the next section to get access to the pinion nut. I have already removed the external case bolts with the double washers.Do I move the governor, the speedo gear and the oil pump drive shaft,the turbine output shaft by removing the oil pump shaft bushing,the spring pin,the snap ring,the speedometer drive gear,the other snap ring? Then will the 2nd section of the case split away?
Brat Blower Motor Relay~Problem solved!
Moto7man replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This was a very cool thread. I'm fixing the fan on my loyale right now. I'll try to post some updates. -
I just changed my timing belt and water pump about 8 months ago. no problem at all. Here is the step by step video that gives the procedure. Very helpful. The only difference is the sooby in the video is a sohc.
- 49 replies
- turbo
- timing belt
(and 3 more)
Tagged with:
Sloppy steering fix? Loyale
Moto7man replied to Subarocket's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a lot of play in my 91 Loyale. I replaced the inner and outer tie rods and boots and the tie rod ends. This tightened up the steerings a lot. then I replaced all four struts and the front strut tower mounts, HUGE difference. The car is very tight now. The strut replacement isn't too bad if you know how to use a spring compression tool(which can be very dangerous). -
Thanks for the information!
Thanks! So, non turbo 5spd will use the 23(auto)spline axles? If I use a turbo 5spd tran, will the 25 spline axles bolt into my original wheel spindles without a problem?
I'm replacing the front stuts on my 1991 Loyale 2wd non turbo automatic. The new struts are Gabriel and they have a tab that compresses the strut rod. Do I bent the tab forward to release the shaft or what do I do with this tab? My old struts don't have this tab but the rest of the strut is the same.
Ok I think I am in on this conversion. But I am hesitant to crawl under that old sled with just "jack stands" holding it up. Does anyone know an alternative stand or method or a safety backup to protect you if the jack stands fail?
Thanks for the response. Can you run a 4wd trans in FWD and wait until later to install the rear diff, drive shaft, bearing carrier etc?
