Everything posted by RapidElastic
Overkill on a CEL question
Mine are there also the newer models had them in the engine compartment. The green connectors will put it in test mode when connected and the white connectors clear the codes. They shouldn't be connected all the time though just when your trying to diagnose problems. Maybe that's why it keeps coming up? I believe to erase codes you connect the white connectors while the vehicle is off and then put the ignition on. The test connectors should be disconnected. If you need more info ill look in my book I'm going by memory.
1987 GL wagon Tick of death?
I did cam seals, oil pump, and valve covers all at once I would recommend it. Stopped my clicking and no longer leaks oil. And I did timing belts as well while it was all apart.
SnowRat
Good job man! Looks like it will take on anything!
Oh EA82, how you...put confused looks on my face
Neutral safety switches exist on manuals. Its on the clutch pedal and makes sure you have the clutch pressed down before you start the car. Almost all manuals have it, except Volkswagens from what i know.
1989 Subaru DL coughs/sputters when cold
How cold are we talking here? My car did this once but it was around -25 celcius. After it warmed up it was fine. And there should be two white connectors that go together and those will clear the codes. I'm not sure of the exact procedure and my book isn't with me. You may have to have the test connectors and the memory clear connectors at the same time I can't remember. My memory clear connectors are in the engine bay by the fuel filter (93 loyale EA82).
where to EGR Vacuum from hose to 87' EA82
That's the best quality I'm allowed to upload and it shows all you need. The picture is right where you drew the yellow box on the manifold. I cant take another picture cause its in auto class.
There's your picture does this work? As far as my brakes I pumped them and saw its pouring out of my rear passenger drum. Hopefully ill pull it apart today and take a look and get it fixed by tomorrow.
I can do that for you tomorrow. Since I lost all my brake fluid I'm not gonna be driving very far
Finally put a muffler on my car. After 3 months or so with it straight piped it sounds very very stealthy.
EA82 cam timing/belt replacement?
Yes it can run but the effects on performance can be drastic.
This is difficult to understand maybe you should reword it. I put a new EGR vacuum solenoid on my car which is what you have pictured and it connected right to the EGR valve. Hope that helps, mines FI though.
1991 Loyale Alternator Question (car audio)
Replacing the alternator is easy. Its right on top of the engine and easy to get at. I got a new one for $120 CAD after the core return. Or you could try fixing the alternator. Machine the stator, new brushes and new regulator but the parts are hard to find generally.
92 Loyale AT new to Me. Oil pressure nil. Possible short draining battery too.
I got my crankcase pulley off by using a impact socket on a breaker bar and resting the bar on solid piece in the engine compartment then went and turned the key just for a split second. Starter motor loosened it good.
1992 loyale coolant worries...
I got my cam seals for 6 bucks each right from the subie dealer in town.
Trouble code troubleshooting
My EGR solenoid went and my fuel consumption was garbage! I pulled another one off at the autowrecker and replaced it helped lots. Ide just replace it if you can find one easily.
Water pump or head gasket?
I have the same problem with my fan! Electric one never turns on ive replaced thermostat and checked the connections. But it never turns on ive got the engine hot, turned on a/c and it never works. Doesnt bother me much it doesnt get too hot here in Canada and the mech one works
the ticking never ends, does it?
Im hoping mine wont come back after im done with the oil pump :/
help with ticking lifters
Im going to be tackling the oil pump seal this week in auto. When i went to the subaru dealer the head mechanic said I should put one or two small 5mm washers in the oil pressure relief valve. Im guessing this would boost my pressure a bit i didnt really understand what he was getting at. Has anyone done this or advise against it? Seems like some buckshee mod that may or may not work.
Cold Air Intake Mod?
Besides not being heatshielded and not having a high flow filter sure ive decided i wont do it anyway. Not worth the effort. Just thought ide try and squeeze some more juice into it since it wouldnt cost me anything. Thanks for the help though!
Quite true i guess for the amount of work i wont be getting much probably wont bother. And i dont want the MAF to get all finicky.
True i would have worse heat sink. If I were to cut a hole in the hood above where the filter is and place a walmart hood scoop over top then Im thinking i may get some benefit. It would look bad but the car isnt beautiful anyway.
My friend has a K&N cold air intake on his honda civic hatchback. But after getting hit by a snowplow he is parting the car out So my question is can I fit this to my 93 loyale? And has anyone done something similiar? My main concern is getting the MAF in there. I'm going to look at it later today. If anyone has advice or info it would be much appreciated!
New here, Need input. Wiper issues?
Oh yes they like to leak alright. Mines currently leaking from both valve covers and oil pump.
Replaced my EGR solenoid it was fried and i had burned a half tank of fuel in 3 days and i barely drove :/ luckily thats fixed and my fuel economy is back on track
