the3rsss
Everything posted by the3rsss
Look for the obvious first. Double check your connections. A vac. Leak will make it run bad. Does the idle seem to be a little higher. Don't see how a compression test will help much. If a valve is slightly off the compression will still be fine. what plugs did you install? Plug wires ok? Don't be so quick to assume its the worst. You might have fixed it with the dist:plug. Wire tie. It so it wont happen again. You might want to walk away from it and think about it for a day or two. Sometimes I get frustrated and need to step away.
Double check your vac lines and elec. Connections. Cel on? Did you use oem gaskets on the intake? You can check the marks by pulling the covers and turning the crank. From what I have read here when your off a tooth it won't start or really runs like crap. Did you at least check your valve clearances while the engine was apart? All ok? Sounds like it could be something minor.
This one actually sounds fairly easy to diagnose. No heat and high temps at idle. Air in the system right? Do we all agree with that? Now, how did it get there, thats the question. A small leak? Maybe a bad clamp or hose? Did you recently open up system to do some work? These things can be a *************** to burp. Hopefully its not headgaskets but it always seems to be.
Just wanted to wrap this thread up. I tried a few different motor oils to see if it lessened the piston slap and here is what I found. 1. Mobil one 0 w40. This was by far the loudest and took the longest to go away. Even knocked a little when fully warmed. 2. Mobile one 10w 30. Still knocked though not as bad. Mobil 5000 5w 30. Quieted down the motor a bit. Fan best with this. Didn't seem to tolerate synthetics well at all. Just my 2 cents. Also, if I warm up the car with the block heater I get no slap.
I didn't trust the eBay kits on my dohc 2.5 but didn't want to pay for oem. I went with a complete gates kit. Belt and all idlers. Then picked up a gates water pump. Whole thing was about 150. Get the pn from the gates website, then look on eBay. It will save you money. BTW. The gates kit had oem jap bearings in the idlers and the belt was perfect.
I am having a hell of a time finding the correct hoses for this (99 obw 2.5) auto. Ordered them from gates but they were wrong! Don't want to go to the dealer. Can I just bypass them? Will it effect my warm-up or anything else? Can't figure out why they would want to heat up the tb. What do you guys think?
Ok. I've read a million threads about piston slap (mostly on gm forums), what causes it and what can be done about it. I have a few questions about it. Now, a lot of this is from my memory so bear with me. Lower end noise, big and small end bearings, crank bearings, etc. Get noisier and are more pronounced under load and on a warm engine. Valve train noise is the opposite, it is noisier at startup but never really good away when warm. Piston slap , for the most part, vanishes in ten or twenty min of driving. Do I have this right? Are there any other knocking noises that disappear once the engine warms?
There are three major mfg of car batteries. East penn , johnson controls and exide. Johnson is by far the largest with brands such as interstate,optima, etc. They also supply batteries to sears, autozone, advance auto and many many others. Napa uses exide batteries. The johnson batteries get very good reviews. The stock battery for my car called for 550 cca. I got a sears die hard gold with 640cca and 100 hr reserve with a 3yr replacement and 100 month warranty for 107. I believe most subarus use a 35 group battery. any top of the line johnson battery will last a very long time. Also heard good things about the exide batteries but napa is kinda far from me so i went with johnson.
I just replaced the rollover valve in my 99 obw. it was leaking vac and causing a cel p0446 i believe, anyway had to order a new valve from the dealer. 58$. After I put it in, the cel cleared up but it was very very slow taking gas. Pump kept shutting off. I tried diff stations and pumps, same thing. Finally, i reversed the hoses to the rollover or vent valve(whatever subaru is calling it now) and it takes gas. I would take a pic or mark the hoses before i take off the old one.
