Everything posted by mons72
Symptoms of a clogged catalytic converter.....
if you shake the cat and hear everyting in it moves, then the cat is gone. even if a cat is broken, the engine can revs up normaly. i had a car were the cat was broken, and i didn't have trouble with the engine to rev up. try to shake the cat and hear if there is some parts in the cat that's moving arround in there.
highbeam problem
i did find the problem i have whit the high beam. it was only a sreew on steering column. i removed that sreew and the problem was fixed. the sreew shortcutet the high beam switch for me.
Water Pump Help Needed in the Northwest
tel your father to go too a junkyard and get a new watherpump there. they wont cost 600 bucks there. it is second hand part but it may work very well.
No BS.
i dont thing your crazy or insane WJM, i like the plan you have. i i have a plan too, to increase hp on engine. and so far i happy with my calutaion on hp. i'm gona stop on about 250 hp on an ea82t engine, it's more then enough for me. there is one thing i have to say too you WJM, and it's like this. GO FOR IT:)
No BS.
cool. i like what i see. i'm gonna do something like this, with some other parts and things.
auto to manual swap in a turbo
yes it can be done, you can use both 4 and 5 speed tranny. the axels are i'm noth sure of they fitt right on. the axel from tranny to rear end may perhaps be changed. i will say that you should use a d/r tranny.
finally got my photo gallery rolling!
nice work:) and a nice car
Wish me luck
i wish you the best of luck from norway, hope for you and your family that everything is ok with all of you. i hope also that your brat is ok without damages.
5 lugs conversion
thats ok. no harm done:)
5 lugs conversion
ok, but it's gonna cost a lot to ship it to norway. so i have to try and get the parts from j/y up here. but thanks anyway.
5 lugs conversion
thanks. thats nice:)
5 lugs conversion
does any one now from witch car i have take parts from, to do a 5 lugs conversion on my 86 sube. and is it much work with it? im happy with all answeres i get from you all.
90 Loyale (should i buy)
go for it. good car for a nice prise:)
Just want so say "Hello"
welcome
1987 Subaru GL10 Wagon (Should I Buy)
i only have to say. GET IT:) you ill love the car
A new Member
welcome to board, i'm from europe too. from norway to be precise.
ignition problem
the barrel cant be taken apart after what i now, the only thing i can recomend is to get a new one j/y. you can check the conection on the barrel, see if it's lose or it's dirty.
styling
does someone now where i can get some styling to my 86 sube leone.
A leak I can't seem to find!?!?
it can be the waterpump, but chech the coolant hoses. it can be a small hole in one of them.
1989 DL dies at low rpm
can be the carb is adjusted too lean and it get to litle gasoline. try to check it out
towing capability of a GL-10?
my 86 subes towingweight is 1140 kg, and i have an ea 82 carb engine. so i dont think you can tow somthing thats hevyer than that.
Car's got a name!
nice name:) . my car is called suben, short name for subaru.
Twin Cab Brat?
crazy, but a nice project. good luck on it:)
more EA82T max out information
i got 163 on a std ea82t engine
i agree with you wjm, it can be done. i have heard it my self and i've heard that the trans can do 300 hp with out trouble.
