Everything posted by bonvo
old oil pump that we took apart cleaned and resealed all the check valves were cleaned and lubed with assembly lube when put back into there proper place it didnt have this issue before which is what is puzzling me
went out and messed with the oil pump a little as i was having low oil pressure at idle and put the last parts on it then took it out to seat the rings. im seriously doubting my dads compression tester at this point it runs way to good and way to smooth and pulls to good to still have 100 psi of compression still having oil pressure issues at idle once its hot not sure what the deal is any ideas?
nope no need thats what the gaskets are for no leaks so far
very glad someone watched the video i was worried because its so long people wouldnt watch it
video of startup
got the subaru all back together it seems to run better and the motor is a lot tighter then before but according to the compression tester the results havnt changed beginning to suspect dads prehistoric compression tester but its still hard not to feel defeated after going threw all that and seeing those numbers
well today i got it put together and ready to drop the rebuilt motor in tomorrow tried something new and recorded the whole think its a little long
bearings are in tomorrow spoob starts happening
bearings why you no here yet!!!
adding these to the list BRAND NEW main bearing set ordered these for my rebuild and my parts supplier says there for an early ea71 main things to take into account is that the thrust bearings are identical they do not have the lock tabs offset as apparently the later ones do but they are brand new i still have the original box only thing i dont have is the shrink wrap just looking to get what i paid of them $30.00 + shipping the lock tabs i mentioned above again these are BRAND NEW BEARINGS someone has to need these things
hit a snag today here are the old bearings these are the new see whats wrong? one lock tab is in the wrong place the 5 other main bearings are perfect but 1 of the trust bearings has the lock tab in the wrong spot calling my parts supplier tomorrow about it cleaned up and painted the radiator and fan set up while this pistons soak in the dip
this is how we started today head off first peak in the bores bell housing/ timing cover off oil pan off wrist pins were giving us trouble tools for extraction video of the halves coming apart everything laid out on the bench this is what the bores looked like got the hone out bores afterwards painted some parts bores after a hone now question for you guys is this a ghetto white trash or other hot tank
Making later model wheels work on our gen 1's
bonvo replied to maestro's topic in Historic Subaru Forum: 50's thru 70's
i would highly suggest changing that rear set up stacking spacers is almost as bad as stacking washers -
78k 1978 DL Wagon I just got last night...
bonvo replied to Sickly's topic in Historic Subaru Forum: 50's thru 70's
im beginning to think this was subis favorite color -
spent the day cleaning the crap out of the engine and bay tomorrow or sunday parts start flying
Trying to find tires for my brat
bonvo replied to MattyH's topic in Historic Subaru Forum: 50's thru 70's
lol i know what you ment i was reffering to sjschlag saying that tires are kinda hard to find hey arent hard to find finding OFFROAD or PERFORMANCE tires in 13s is difficult -
fixin' to resurrect 1976 gf coupe "honey bee"
bonvo replied to chikaskia's topic in Historic Subaru Forum: 50's thru 70's
i see 2 shifter boots in the car 4wd??? -
tires hard to find? dude any tire shop carried 13s there not very good tires but tires none the less -
hey man you provided the extra set of hands to get the engine up and out of the bay as for whats comming not much just a re ring job
with a help from stewartkb loaning an extra set of hands motor is out
we need pictures
