Everything posted by WANTONSOUPGUY
Outback: missing cylinder problem
WANTONSOUPGUY replied to vtdaug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know you probly got it all fixed up by now, but for any future readers, I would definately get a new mechanic. A simple compression test which takes 20 minutes per cylinder, if that, would determine if the cylinder has a bad valve or broken ring/piston. Ditch him.
How do you reset a CEL (Check Engine Light)
excellent suggestions.....thanks for all your help
Hey all, I just pulled a misfire code from my engine, and i'm pretty sure the matter is resolved, as my 2000 OBW is running quite smoothly. Does anyone know how to reset the CEL? I tried in the past to pull the battery negative, but to no avail. My other option is to see if AutoZone can somehow reset it for me. Any ideas?
Rear Moonroof/Sunroof Shade Problems...
Maybe this will help someone with the same problem so they don't have to pull the whole car apart. My 2000 OBW Ltd. rear sunroof cover jammed one day....wouldnt open all the way...I was like, RRrrrr...tried and tried again to slide it with no avail...then I opened the rear moon roof up all the way and after it wouldn't shut cause the cover was stopping it! Ugh! Finally I opened the roof again, and slid the cover up and out the top. When I looked inside, attached to the glass roof are 2 small spring-loaded thingys, that apparently are supposed to 'open' up when your roof is closing, thus pushing the cover closed with it. Well, one of mine was stuck open, making it impossible to shut it completely...So...I superglued the broken one in the "up" position. Then I bent the 2 rear metal clips attached to the rear of the cover to make them straight, and re-installed it from above, gently sliding it in. Now it slides on its own with no help from the roof. I will miss how it opened with the roof and all, but tweaking it out without going to the dealer has helped a person with an empty wallet to get by without unneeded bills. Hope this helps another Sube dude.
Loyale auto tranny "clicks" when it shifts
Ive got a 2000 OBW...does the same thing from 1st to 2nd....Clik!....kinda hesitates to shift in on a cold day, but has been like this for like 50,000 miles,((since I got it)) so I will drive it until it explodes, and then I will deduce that the tranny needs rebuilding...I wouldnt worry about it till it doesnt shift...
Done with cvaxles.com
WANTONSOUPGUY replied to DerFahrer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI went with Napa axles...they were 1 inch SHORTER (measured lying flat on ground) than stock axles...which resulted in a blown axle upon a tight turn. They also seem to be built with greater tolerances in the axle teeth, which resulted in a slight grumbling vibration when at a stop, in drive (auto trans.), with the brakes on. I brought mine back to NAPA and installed Subaru remanufactured. Now when I drive (less my arm and leg for the axles) it drives smooth, no probs. Hope this helps.
Torn CV Boot (DOJ - Inner)
WANTONSOUPGUY replied to NorthLight's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just tried replacing a front inner boot for a friends 97 impreza with a subaru brand one-piece boot...pulled the axle, removed the old boot, and how in the world do you get the one piece on? I think you would have to machine press the axle end off to do it (to get the new boot on). So we just bought a new axle...much simpler.
Half-Axle Replacement causes idle shudder....?
Well, I didn't take a photo, but i'm pretty sure they were about an inch too short...maybe the outer spindle was longer? Either way, one of them did blow up on me, which was the final straw for me to go get my money back. Strangely, my tranny fluid also went low (after a recent fill) about a quart. Maybe the vibration shook it out! Oh well. It's a used car. Stay away from aftermarket parts.
I figured it out, folks. The NAPA half-shafts are 1 inch too SHORT. I was told by the manager at Napa that the axles are made from subaru shafts, but this can't be true, because of the length difference and even difference in shaft thickness. Once I replaced both cheesy NAPA shafts with Subaru re-mans the shudder for the most part went away. (I must say though that the Portsmouth NH Napa was very nice and gave me a full refund for both shafts) :*) So thats it everyone...stick to Subaru parts...expensive, but it will save you a lot of frustration.
Shudders when stopped at lights
WANTONSOUPGUY replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi am so glad to find this post. I replaced a half-axle on the front passenger side and immediately after it started vibrating at a stop with the brake on. Coincidence? I think not. Ran like a kitten before. Now it is driving me crazy messing with idle speed and sensors. BTW...no engine light and idle is at a strict 500 rpm with no problems at all starting. I think I have to go to the Suby dealer. Thanks for the post.
I have a 00 OBW which just blew up the passengers cv boot. I replaced the axle with a NAPA part, and now when the tranny is in drive and my foot on the brake the engine shudders...or rattles. It is almost like there is a vacuum leak or something (I checked and found none). It runs fine at all other speeds, but makes this shudder until I take my foot on the brake. What do you think? Did I mess up something in the ABS? Subarus always idle ridiculously low...mine is 500 rpm, but before the axle replacement I never had any issues with it. Anyone have similar?
Front axles replacement report
WANTONSOUPGUY replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would like to add for anyone doing their first half-alxe job on a newer suby. My 00 OBW took me 9 hours (3 travelling for parts and 1 for stupidity). If you want to disconnect the lower ball joint to get the new axle in, and you feel you must hammer it to loosen it, make sure you put the crown nut or another nut over the threads of the ball-joint. Otherwise you will destroy the threads on the ball joint which will take you alot more time for ball joint replacement. Also ***very important***when you attempt to put the new axle on, make sure the splines match up with the hole. If you put the axle on it may look like it is lined up, but wont work because it needs to be flipped 180 degrees. I hope this saves someone the pain of having to pull apart and reassemble everything because of the spline thing. I have no service manual, but when they come out I will be the first in line.
rear wheel squeal/squeak on '98 Legacy goes away when I touch the brakes
WANTONSOUPGUY replied to Bright1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found with my suby that aftermarket rear pads fit too tightly in the pad grooves. This causes the pads to rub the rotor even when brake pressure isnt applied. I just drove 100 miles yesterday hearing squeaks that would only quiet for a moment after hitting the brakes. I will just grind the break pad tabs down just so that they slide freely and can retract easily enough so as not to "stick" to the rotor as it turns. Hope this helps...
Should the Outback be Upfront?
Well, it looks like I "lucked out" as far as engine damage...all looks to be in good shape. I noticed that the intake drain holes are progressively smaller as they near the filter. I doubled the size of each one and hope I get to find some big puddles again. Thanks for the posts.
WANTONSOUPGUY replied to Bright1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same problem (exactly) on my 00 OBW. I took the rear brakes apart and lubed the brake slides and it went away. Then it came back 3 months later ....supposedly when there was enough dust and dirt to keep the pads from moving back into place after releasing them... perhaps a design flaw? Either way I am going to check my caliper out when I have time to blow. :*)
Any Ideas On In-dash 6 Cd Changer Replacement?
I drive a 2000 obw, and my cd changer just died. Any ideas where i can find a cheap replacement, or an aftermarket in-dash changer? Thanks, Wanton
interior panels falling off?
WANTONSOUPGUY replied to georgefgd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGeorge...i have the same problem with the rear hatch. I work out of my suby and once in a while I will find the rear plastic 'hanging'. I think it could be fixed with some new yellow snap thingies the dealer sells, but I am too lazy and just whack it back into place. Hope you fix your problems.
Recently, I took my 00 OBW down an old logging road just to see whats down there. After passing through a 40 foot long puddle at 15-20 mph, I realized the road was blocked by rocks. So, within a minute or so I turned around and went back through the puddle and on my way out the engine stopped...to make a long story short the engine sucked up water. I pulled the plugs and cranked the engine and all is now fine. What happened is, Subaru made 3 water traps on the plastic intake tubing with small drain holes to let the water drain out once collected. Since I went through so much water in so little time the traps filled up the first time through the puddle, and then were overwhelmed by water the 2nd time through...MY QUESTION IS: Would it be wise to drill out the drainholes in the plastic intake tubing? I would probably double their size to prevent this from happening again. Either that or stay off the back roads??? (sniff). http://www.smresto.com/carpuddle.jpg
Bad Component Or Tire Problems???
I think I figured it out. (the tires Are all the same sizes and inflation) The power steering pump is beginning to whine when cold, and I realize that the shudder is when turning...even on some not too slippery surfaces. So, now I have to see if it is the rack or just a weak pump...???
I own a 2000 OBW w/ ltd. slip diff. When the first snow came I had 4 new snows put on, which I found out after were 1 size taller than I had asked for. Figuring that they were all the same size, I let it go. When driving in slippery terrain only, I hear and feel clunking as I turn the wheel. I have searched this forum and it seems like it could be some kind of worn out coupling? Or am I a complete idiot for leaving the slightly oversized tires on? Hmmm... Wanton
Low to Mid-speed ONLY tire vibration...HOW???
Thanks...i'll try retorquing the wheels and wiggling the tires to check for bad bearings... Wanton
0483 Cooling Fan Code---how To Fix???
Thanks for the advice everyone...turns out after a month the light went out by itself and has not come on since. My thoughts are a chipmunk was getting cozy in my fan, which the resistence to the spinning fan may have triggered the engine code. Those little critters don't even clean up their nuts after themselves...how rude! Smelling the winter acorns burning.... Wanton
I own a 2000 OBW (Limited). I have noticed that with or without my snow tires on the car a low to mid speed vibration completely smooths out at high speeds. By low to mid I mean 30-60mph. Does anyone have any ideas? It is not caused by poor balancing(as far as I can tell) or snow in the rim..The car has 106,000 miles with original struts, half-axles and rims. Anyone have any ideas? Thanks in advance! Wanton
Check Engine Light in 00 OBW
WANTONSOUPGUY replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the gas cap is tight and drive it to see if it disappears. Some parts places, such as AutoZone offer free check engine light code readings. That will give you a good idea of where to start.
Climate Control Backlight
WANTONSOUPGUY replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd like to thank everyone who posted here for bulb replacement. When I realized bulbs in my car were burning out all over I went to 2 Suby dealers and they both told me they didn't sell bulbs and it was a sealed unit. They said I would have to replace my fog light, cruise, rear defrost and drivers heated seat switches....(Isn't that like $500?!?) I went here and found very different, getting 10 bulbs from radio shack for $15 (some are back-ups) saved the day. It is sad that Subaru doesn't allow their technicians that work for them to show their true skill...saving money and resources for their customers and the environment. Thanks again all for the good advice..keep up the good posts!!
