Everything posted by saeble
WRXenstein
I have : A) a rolled, cosmetically destroyed 1996 clubspec Rallye WRX (ie organ/parts donor) an 1981 L series wagon I want : Everything cool and worthwhile from A) into Where does the WRX stop and the GL wagon begin ? Just the driveline ? Or axle to axle and driveline ? I'm wondering if there are any recognised pitfalls to avoid. Any clues or nuggets of hardwon wisdom will be much appreciated. Once I start this project, I'll do my best to keep a journal in the hope that I can help everyone else with other equally fun conversions. cheers in anticipation fellas ! Beer supplied to anyone who comes to help
Electrical Weirdness
- Subaru GL wagon dizzy
Can I get a nice set and forget electronic dizzy for my 82 GL wagon ? (ea81) Im getting very tired of dealing with the constantly drifting dizzy I have at the moment. Is there anything else that I should be aware of when it comes to ea81 ignitions ? I have a sneaking suspiscion that the plate through which the distributor bolt goes through is shifting. cheers !- Ignition timing
went out and adjusted it and yes... huge difference. I haven't had it that long and it seems that someone negelected to tighten the dizzy adjustment bolt, or its worked itself loose in the last few weeks, which would make sense, because it got steadily worse. for the record I had 10 deg ATDC.... suffice to say that probably fixed all the ills previously mentioned, though I'm still looking for more reasons just in case. I've had too much experience with cars that have been 'fixed' by shadetree mechanics in the past.... the things people do to cars !- Ignition timing
thats a start... thanks !- Ignition timing
I went to check the ignition timing on my 82 Gl wagon(EA-81). I hook up the timing light and then open the Haynes manual... paraphrasing... "Look at the sticker under the hood for the correct timing figures" Some bastige has repainted my car at some point and very thoughtfully removed any signs of a sticker under the hood on my car. Hence I have no idea what degrees from TDC +/- I might need and at what revs/idlespeed this needs to be. Right now the car is dieseling, running quite hot, backfiring, refusing to idle at a reasonably low RPM, and just generally seeming to be telling me it's out of whack in the iginition dept. If my guesstimates are wrong I'm more than happy to hear anyone elses. I just thought the timing was a good place to start What idle speed and timing setting do I need ?? cheers in anticipation !- Aussie Hatch... Now ej22 Converted. (with pics)
If someone can send me a very accurate drawing of the adapter plate for this conversion, (and any adapter plate I guess), I could digitise it and then cut them professionally with A CNC water jet cutter. They could be made to look almost stock, such is the nice finish a water jet will give you. Best bit about it is they are reproduceable, anywhere. I have a pal in the states who does CNC cutting, so you Yanks need not miss out either, (I'm in AU). Jet cutting isnt too cheap but considering the month of Sundays cutting one of these adapters by handwould require... it is probably well worth it. I cant get an accurate quote without a file to quote from but I'd be happy to do the digitising and arrange a quote for nix. There also may be some advantage in economies of scale. If I work out the best way to lay them out on the sheet, it may be possible to cut lots from the one blank. If any of you guys want to try and swing a semi-commerical sort of deal, just give me a shout. If there are any other brackets and doo-dads you may require in ally or steel then by all means ask. Just be aware it sometimes isnt cheap unless you are cutting lots of the said item. Mind you, the finish is perhaps better than factory stamped components when its done well. Not to mention I can punch weight saving from them, add a simple logo even.. Just let me know !- My Soobie has cancer
I was doing some messing around under the dash on my soobie when I discovered some nasty rot behind the front wheel below the A pillar. While its not terminal yet it has the potential to be. Im also moving to a coastal locale so its likely to get worse fast. Looks like classic 'wheel throw' type rust inside the guard has done some creeping. While I've done my share of wax-oiling and so forth I thought I'd ask around and see what everyone else does to cure cancer, other than rustectomy surgery, which isnt really an option for me right now. If anything I'd like a way to just arrest its progress and then seal it up without costing me several limbs. Any clues ? You poor beggars up in salted road country must have a few ideas. cheers !- Good god!
- why i hate deer
a young doe ? venison anyone ? we have the same sorts of problems with kangaroos, they like the good grazing on the edge of the road, because AU is so dry, when it does actually rain, all the grass springs up alongside the road because of the runoff from the blacktop. The end result is lots of casualties, both cars and 'roos. If you ever drive any distance out here in a rental, make sure you're covered for 'roo damage, it IS a seperate clause. You DONT automatically get cover for animal damage on alot of rental cars. Thats why my Soobie wears a big aluminium 'roo bar. Very handy device. great for mounting stuff on, like lights and winches and stuff. Also comes in handy when you want to creep up behind a mates car, drop it in Low range, kiss up to his bumper and start pushing him out into the intersection.. (Don't try this at home kids, this is only for irresponsible adults)- a tale of two diffs
I installed the 3.9 today... drove it a fair distance and it seems to be happy. Go figure. Who knows, perhaps its had some donor organs in the past. Incidentally I also replaced the big phat rollpin in the gearshift linkage and man... I can get first, second and reverse without tearing a hole in the gearstick boot each side of the stick..- Clicking sound while braking
you may have the beginnings of CV joint death. Constant velocity joints are the universal joint type suckers which allow the axles to transfer power through a variable bend, you've got 8 on board your soobie, (sorry if you know this, it just for clarity), theres one at each end of your axle shafts. I don't know which ones tend to go first on Soobies but basically every front wheel drive and four/all wheel drive has CV joints. When they start to die, they click in a repetitive fashion. It's usually first noticed when you go around a corner under alot of power. As it gets progressivly worse it will click under lighter and lighter loads, and lesser and lesser degrees of turn, until it finally shirts itself and scares the crepe out of you when it lets go and locks up a wheel or something equally hideous. Some people are crazy. I've seen a small FWD making more din from rotten CV's than a car witha broken conrod... and they wonder why they have to stop driving it and fix it ! I digress... your clicking noise may be the same sort of deal. When the axles are loading up from braking it may be popping the CV's as they change from driving/coasting/braking. I'd suggest you find a nice parking lot and put on full lock in each direction and go round and round in circles under power to see if you get a 'click click click'. If you do, you probably need rebuilt axle shaft/CV's. Fitting them is easy enough if you have a decent jack, axle stands and a few simple tools. I just replaced the rear diff on my car and I was mightily impressed with how easy it is to extract bits of Subaru from the rest of it. Given the year of your car it may be a manufacturing fault if it is CV's. You should have many miles left before you get problems like the above. Outside of that I'd check your brake calipers and discs for anything unusal. Big tracks cut in your discs, or loose stuff. There may also be something in the suspension which is acting up under load. It may pay to climb under the car when its safely on ramps or something similar and get someobody to bounce you car up and down to simulate weight transfer like you'd get under braking.- Help with my 83 GL Wagon
Are there any other symptoms ? Does the rear end howl or growl at speed ? Does the car make a repeated clicking sound when going around corners ? When you bring a problem to a place like this always try and give as much info as possible. It's hard enough consulting a 'crystal ball' as it is. While I havent been to this board for long I do know the same sorts of things apply on other car nut boards. The more you can add the better.- Just got rear-ended
If your doors are wonky I would seriously suggest you make sure your shell is still relatively straight, the doors not closing is a telltale sign of frame or shell problems. If it's split a seam somewhere it could rust or do something equally nasty in a bizarre place. I've seen a wagon from an entirely different maker suffer a rear end hit, and 12 months later it was unroadworthy because a major seam has split in the accident and the red cancer had eaten some important sections of the floorpan, after $1000's had been spent on the repair to the car elsewhere. Always check an accident damaged car with a freakin microscope. And of course if it is too far gone to save, (and I hope thats not the case), make sure her bones and organs go to worthy recipients.- a tale of two diffs
ok... NOW I'm confused.... The diff that was in the car is as much as I can tell a 3.9, and yet everyone says that AUs production wagons in 82 with D/R are supposed to be 3.7 I've since driven the 100k round trip to the wreckers to get a 3.9, which seems to be a very rare beast, everything else in stock was 3.7 Ok, so if it some idjut has put a 3.9 in a car set up for 3.7 (with a 3.7 front diff), deliberately and consciously, what's the advantage ? More launch from the lights ?? I think I'm going to bung the 3.9 replacement in and see what happens, if it starts doing strange shirt I'll put a 3.7 in... ...sigh... all I want to do is drive the danged thing.- a tale of two diffs
****e.... looks like I may have to rebuild the old one, seeing as the wreckers cant seem to source a sound 3.9- a tale of two diffs
I have an 82 D/R 4WD wagon. It had a shot rear diff. I pulled said diff and it has no final drive ratio sticker, long since fallen off. I turned the prop input 20 times and got 6.5 turns of axle output shaft. I then counted the turns on my replacement diff which I bought at a wreckers which is a 3.7 and got 5.75 turns of the axle output shaft. Here's the issue. The wrecker insists that vitually every soobie of the vintage mine is are all 3.7's. Only some direct import Brat/Brumby utes from Japan, (2nd hand, not thruough a soobie dealer), had 3.9's. How do I tell what I should have in the car ? How can I tell what the front diff ratio is ? My suspisicion is that the previous owner has fitted the wrong rear diff to the car. What's likely to be damaged if this is the case ? It looks as though the diff has been in there for quite some time. It looks original. Suffice to say I'm at a loss as to what I should be doing here..- Anyone have EA81 FSM online?
thanks for the gregorys manual Will... bewdy..- El Junkyardo
Junkyard crawling is an art in itself. They vary so widely. Some are out and out pirates. While I haven't hunted for Soobie parts until very recently I have spend hours scavenging over other species of car corpses. I stick with the little independent guys, and with the 'You pick and pull' guys. The ones with warehouses full of already catalogued labeled stuff are places to avoid unless you like being shafted. For instance, rear diff for my newly purchased Soobie wagon at a reasonable wrecker = $95AUD Same rear diff at a specialist Subaru wrecker (or probably more accurately Subaru owner rapist) = $450AUD Polish up your inerpersonal skills and go talk to the little guys. They rock. Just bring your own tools and dont steal. The little guys often live on the edge of making a living because they dont charge like wounded bulls. Look after 'em and they'll look after you. I had one guy on tap at one stage. I gave him $20 bucks and said "Keep an eye out for 'X' part and let me know when it enters the network and sure enough 2 weeks later, its there for me at a reasonable price. Mutual back scratching is the way to go.- G'day fresh convert to Subaruism
what weight is best ?- G'day fresh convert to Subaruism
thanks mate- G'day fresh convert to Subaruism
dude... I'm looking at doing an ENTIRE transplant, from the wheels in, right upto and including the engine from a rolled or otherwise totalled donor car... I'm happy for fate to deliver such a thing with time.. Thanks for the headsup on the tranny and the carb ideas. Speaking of which, the syncros on second are shot I believe, so a G/box swap may be good news, the change is not brilliant in fact... is there any way to reduce the slop in the stick ?- G'day fresh convert to Subaruism
I've just picked up a nice tidy 1982 EA81 D/R 4spd Soobie Wagon with 277K on the clock. Aside from a shot LHS diff bearing, it all works. There is a little rust around the rear glass in the hatch lid but other than that it's rust free. I got it for $1200 AUD, from a used car yard no less ! I also picked up a replacement diff for $95AUD on the same day, plus a few ancillary knobs and such for the dash. I love it. I've been a good boy and read through all 28 pages of threads so I think I'm entitled to ask a few questions, seeing as I couldn't find any direct answers. 1) It looks like I've got one of the best drivelines straight out of the box, whichis sort of dissapointing. I was hoping I could cut and paste some more fun/power into it. I saw the remains of a sweet red WRX being dragged onto a tilt loader, totalled and I know where it will end up... at one of several local auction houses on behalf of the poor bastards insurance company. After a quick prayer to the car gods on behalf of the newly departed I thought about organ donation. WRX to Wagon donation.. I'd prefer to buy something like the remains of that WRX and cut and paste the whole danged driveline into my nice wagon shell, if and when the ole EA81 dies, (prolly at around 2billion K's ). What is the best total swap to do ? In terms of benefit VS expense/time consumed ? 2) Are there any lil' tweaks and stuff I can do now to improve my ride in terms of performance ? I'm talking about the shadetree simple stuff I can do without alot of dismantling and swearing. I have a pretty well equipped workshop so perhaps add a couple stars to my competence levels than you may expect. I'm just not familiar with Soobies. I've fully restored two other 1960's cars so I'm a long way from 'babe in the toolbox'. I do include suspension, brakes and such in the above, not just grunt. cheers in anticipation fellas.. - Subaru GL wagon dizzy
