4x4brat
Everything posted by 4x4brat
  1. if you need help machining some from raw urethane let me know
  2. Welcome Capt Great group of people and Super Information!!
  3. Who has a good pattern? or a old one in good condition? Who Else? tony5143 biffanyus 0225wrx yellowsub bendecker
  4. NO one has ideas? or do you..like me...... just do not know!! grrr:-\
  5. 1983 brat with hitachi and A/T 1st :-\ I need help with a ECM code 22...... vehicle speed sensor where is it ? how do in check it ? or replace it? 2nd:-\ i have no dash lights or running lights..... fuze #12 blows when installed Where do i start to look to find short??? Any help Would be Greatly Appreciated
  6. It Sure Looks Kool but I sure do not plan hauling it this way is a 154" long track..... A short track would fit great! Yes its on top of the wheel wells
  7. you can put in longer studs......better safe then.........
  8. i got an 83 brat with electric HEAD LAMP issues passenger side works fine drivers side low beam is dim and the HI beam will not work at all:-\ any help/ideas would be GREAT Thank You
  9. A few more takers?? i could water jet them out !!
  10. i got some front half shafts..... and 4" lift kits cheep
  11. I had them Nickel Plated this RUN......Get YOURS........ Order Today!!! :eek: "WHILE THE SUPPLY LASTS" :slobber:
  12. tap out will eat the bolt and hardened steel and not the aluminium!! Works great!!
  13. well after looking at my other brat i notice that the new rotors are 1/8" thicker....grrrrr:mad: this is causing the rotor to hit the brake pad hanger and stops the rotor from spinning anyone have this issue or seen this problem with the older gens?
  14. Thank You Brian....(subarujunkie) for bringing me out the cone washer!! after replacing with all new front end parts i tighten the axle and its causes the rotor to rub the brake pad hanger any ideas? Thanks for your help!!
  15. Who heard of such Thing?
  16. Cocanie.........Sniff...sniff:eek:
  17. replace the damaged head with a GOOD one save your self the head ache
  18. whats one worth to ya with tinted windows?
