Everything posted by old sub freak
Brat jump seats for sale
old sub freak replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey scoby, i still have them .sorry i thought i hit the button to let me know about reply's.... and its best offer -
Hey all ...My 84 hatchback has no power to the fuel pump..I think its the "roll over switch"..Its just above the hood latch,a little blue box...can these be bought or bypassed ? Thank you ,todd
I have a good set of Brat seats with all the hardware.the seat belts are a little iffy but with some determination i think they could work...$200 bucks for the whole deal ..Thanks.Hope i posted this in a right spot,Todd
wide open throttle !!
Well....Easy peasy Japanesy I sprayed down all the linkage with PB Blaster...Ta Da Fixed it haha ,Yep just stuck linkage ..Got it to idle nice and on with the program...Its been through the mill BUT its a runner !! Thanks for the help !! -
Hey gang..So I just got a 84 brat running after sitting 6 years? well I got it running but instead of purring it is ROARING !! I can't get it to idle down.The cable is loose so its something to do with the carb? I think ?? I'm going to check the power to the different wires on the carb and see if that might be it ..Any thoughts ?/ Thanks PS..If i pull one of the spring loaded piston things it will come down some...but still..its a ha toch ee
So .... Who has the best replacement distributors? for a 1982 1600 ..two wheel drive .....Any thoughts? Thanks,The Old man
1982 1600 tachometer bouncing
so...who's got the best aftermarket distributor ? I can't remember where on line I got it.... -
BINGO !! thats it.I forgot that test..so i guess this is a classic ...you get what you pay for. its not even a year old..Liven learn...again Thanks again -
Hey Gang,well my daughters 1982 1600 2 wheel drive hatchback tachometer bounces ..? mabey 2 or 3 rpm's. .in the past i would oil the shaft and it was fixed. But here's still bounces..Runs great ,no change in the idle...any thoughts? its a on line aftermarket Distributor...Thanks ,The Old Man
87 gl 4x4 no spark
old sub freak replied to Displaynamerequired's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the fuses ? -
4 sale 1983 GL 10
I'll throw in a good tranny ..you pull -
4 sale 1983 GL 10
HmmmmI will figure out the picture.and yes...no turbo ect just electronic dash board...250,000 miles ...send a text and i'll send the pictures ..I can't figure the pictures out 360 421 8810 Todd ATT00001[1].txt ATT00001 (4).txt -
Hello,my daughters Subaru wagon just lost 3rd gear and she is ready to move on ..all stock except a weber carb... $600 bucks Mt Vernon, Washington ATT00001.txt ATT00001 (1).txt
so ...did you fix it? I just went through the same dance...No heater fan ,wipers or radio..messed n tested with fusable links ..Then out of the blue everything works...Till this morning turned the key to on and again all is working.....then i started it and nada.nothing !! So i gentley wiggled the key while it was warming up and ..Bingo everything works again..must be the contacts in the ignition switch...Now do i replace it or hope i can clean the contacts and go on with life haha have fun with your new ride..Great Rigs !!
Brat gets stuck in 4th gear
old sub freak replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so ..di you get it fixed? I have had to replace a couple trannys that were stuck in 4th gear.we could not get it out of gear. tryed everything...Hope you got it going without too much work..I have a few trannys if you need one...yea the guy spaced and started in 4th gear and that was that !! -
5 Powerless fuses
well i went out this morning and turned the key to on...everything worked, wipers,heater fan and radio...so i started it up and......nada nothing works now....so i gently jiggled the ignition key and wa la everything works again....so ..think i should replace the ignition switch or just try n clean it with contact cleaner..anyone had this problem ?? Thank you -
5 Powerless fuses
Well that’s optimistic.. haha . Yes , chasing wires . I’ll keep at it . Wireing .....ugg.. . Thanks again -
5 Powerless fuses
Like the ignition switch may be working intermittently? Yea it’s a ood one 5 fuses in a row crap out .. I would think the switch is ok it’s only got 101, 685 miles on it haha . That’s sounds like a lot but you know .. they’ll go 300,000 .. live em thanks -
5 Powerless fuses
Hey Dave, do you mean 10 in a twenty . Wrong amp ? Yea now everything is good but she said it had a history of loosing power to wipers ect... I’m going to do the jiggle test on the wires around the fuselage links . Just in case .. thank you ! -
5 Powerless fuses
Yes , I took them off and with a test light checked them on the positive post . All good ... but after that .... All is well . Power to everything.. hmmmm. I can’t let it slide as I don’t want it to get hot again .. I’ll look n see what link goes to what and go from there.. dumb luck ...I followed her for 15 miles and no white smoke so Mabey It didn’t blow a head gasket. Changed the oil . Looked funky. So I will keep at it . Thank you -
Hey gang,My daughters 1982 1600 hatch overheated (insert sad face) There is no power to the radiator fan ...Or the wipers or the heater fan...(insert surprised face)...5 of the fuses on the top bank of the fuse box are powerless..any thoughts,,maybe a rabbit out of the hat fix ha ha,Thanks,The old man
ea82 cam tower oil seal question.
old sub freak replied to darsdoug's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And still is haha..i too just ordered 4 of them.The ebay gasket set had no cam tower seals and the ones for the head gasket were thin o rings.The gasket does have copper inserts around the oil channel... -
Subaru Parade,World Record !
old sub freak replied to old sub freak's topic in Meet n' Greet. Your USMB Welcome Center
So i talked to the folks at Birch bay and they are SHORT a few Subaru's....So If you are not busy that weekend it should be fun and lots of subaru stuff going on...see ya there,todd.
