Everything posted by the_bard
Baja's Back: Sprocket Swap & Timing Belt Considerations
It's a long story, but I've got my Baja back. Short of it: guy who bought her kept in touch online. I asked for first dibs if he put her up for sale. A few weekends ago, she blew a head gasket in Saugerties. She's now sitting in my front yard, paid for. Just gotta finalize the paperwork with the DMV and swap my ISHKBAJA plates over from the Tacoma. My plan to rectify the head gasket situation is to pull the engine and throw it on a stand in the shed. That'll let me replace the head gasket and reseal the engine. It's been overheated, and I don't know how much I trust the lower end as a result. Doing the maintenance on it will be more of an educational adventure for me. In the meanwhile, I've got an '07 OBS with an engine that I've put 3k miles on myself. Runs well, consumes a bit of oil, but no more than usual. I'd like to drop it into the Baja, which means putting together a low end management system for the AVLS. I'll need to move the cam and crank sprockets from the old '06 engine to the new '07 engine, too. That leads me to a question... Since I'm moving the sprockets over, I should use the 304 timing belt to match the sprockets, correct? The timing belt on the '06 was replaced about 45k miles ago by myself; I'm half tempted to just replace it out of principle. They're not that expensive. Edit: should also note that I'll be using the intake manifold off the '06, since the '07 is drive by wire, and who knows what other emissions/sensors complications. Gonna hook up a digital RPM window switch to the AVLS solenoids; hardest part ought to be getting a tach signal to the switch. Assuming the '06 engine looks good otherwise, I'll pickle it and put it into storage as a back up should the '07 suffer an untimely death. Update #2: Looks like reports differ as to the tooth pattern on the belt; some folk say they're interchangeable, others not. Regardless, if I'm swapping out the sprockets and idlers, then I shouldn't have a problem matching up the belt. Also looks like the water pumps are different (t'stat sits on the bottom in the Baja, on the side in the OBS). Gives me reason to buy a new water pump. Yay, spare parts!
ABS Codes on a 2006 NA Baja
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTested the battery by connecting a cheap multimeter up to both battery terminals, while the vehicle was off. ~12.5 volts. The negative terminal was pretty clean when I pulled the battery... postive wasn't, so I cleaned it up a bit prior to reconnecting the battery. I may just bite the bullet and take it into the dealership to have the code(s) pulled. Edit: I should mentioned that I found the two green diagnostic plugs (one male, one female) that have something to do with SSM/flashing the ECU/etc. They are disconnected. There's another white plug (eight ports?) with only one wire connected. Might try to track down what that one wire does.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to my copy of the FSM... seems that they integrated the ABS control module (computer, not the pump) into the ECU. I did pull the carpet and the protective shield off. No sign of water there. The FSM only mentions the SSM tool, unlike other versions I've ran across the web that detail the manual method without the SSM tool. There are four wires in that plug. Three across the top, one on the lower left. Going off my (horrible) memory: Port 1 (top left): Honks the horn. Port 2 (top center): blows a 15A fuse in the engine bay and renders the interior lighting, radio, and keyless entry unusable. Port 3 (top right): does nothing noticeable. Port 4 (lower left): does nothing noticeable. As luck has it, I tried port 4 first, then three, thinking they might be substitutes for port #6. Then I tried port #1... and finally ended up grounding out port #2. After blowing that fuse, I figured I might better stop grounding out any more plugs. Last thing I want to do is fry the ECU.
So I got one for y'all. Despite the on again, off again showers this Sunday, I was bound and determined to get a few issues resolved on my Baja before the cold weather really sets in here in Upstate NY. Been having an intermittent P0420 code being thrown, so I ordered a replacement downstream oxygen sensor. I figured I ought to take care of that driver's side valve cover gasket that'd been leaking, as well. Ordered a new PCV valve, too... may as well, right? Put it up on ramps and chocked the rear wheels. Pulled the old oxygen sensor and installed the new, without incident. Discovered the new PCV valve is entirely different than the old (plastic vs metal; nipples were the wrong size; threads were the wrong pitch), but luckily the old PCV valve wasn't bad off. Cleaned it up a bit and reinstalled it. I did manage to rotate the plug the PCV valve screws into, but I understand the plug is press fit into the case, so it is what it is. Pulled the battery and windshield washer fluid reservoir, then the driver's side valve cover and replaced its gasket. Buttoned it back up again neatly, making sure to torque the valve cover bolts down in the proper order. Since all of the above went pretty smoothly, I finished ahead of time. Seein' as it was raining, I figured I'd address one other minor problem I'd had... a leak resulting in a small amount of water in the front passenger foot well. I'd also heard that unmistakable sound of water hitting the blower motor fan blades, but only once. I'd had problems tracking down the leak, since I had to park slightly uphill and leave it under a fairly hard rain to replicate it. I just left the Baja up on the ramps, and slowly poured a bucket of water over the passenger side of the windshield. Didn't get the expected result of lots of water in the footwell, but it did persuade me to address it some other day. Now here's where my problem lies... when I fired the engine up for the first time after doing all the above, the ABS light on the dash stayed on. At no point in my earlier wrenching did I come near the ABS system. I went back over and visually checked the wiring for the wheel sensors, and the wiring harnesses. I can't imagine that my pouring water over the windshield would've come close to the wiring either, but I suppose anything's possible. Cleaned up a couple of grounds, the first being the one located right next to the ABS module itself. Verified that all of the fuses are not blown, both behind the dash and in the engine bay. None of that made a difference. Now, I imagine life would be easier if I could pull the ABS code and know what the system is complaining about. Problem is... that little trick of finding the six port plug under the dash (usually black) and grounding out port #6 using the accompanying black wires located off the same harness as the plug doesn't work. There is no wire attached to that port #6, which makes grounding it out really really difficult . Obviously, an OBD-2 scanner is not going to pull an ABS code. I heard about FreeSSM, but it appears that it'll only talk to the ECU & TCM, but not the ABS system. Can't tell if the ABS system is working or not... hasn't rained since, and I don't have a good dirt/gravel road for miles around. Cruise control works perfectly fine. Is there any way for a shade tree mechanic to pull that ABS code? I'd have some difficulty convincing the wife I need to buy a Subaru Select Monitor device ($1,200 used off eBay). With my luck, I'd never have another ABS code thrown. I'd also love to stay away from the dealership if I don't have to... sure, $40-$50 to have the code pulled ain't horrible, but if it's something as stupid as a "Power Supply Voltage Too Low" (maybe when I was reconnecting the battery... a long shot, but with my luck...) then I'm going to be cursing.
The Awesome *NEWER* Generation Picture Thread
the_bard replied to Red92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA month or so ago, I had slapped a quick coat of paint on my Mudrat bumpers, in an attempt to keep the salt off of them over the winter. I'm hoping to get them sandblasted and either POR-15/Rustoleum'd or powdercoated come spring/summer. I also found replacements for the missing bumper cladding on the rear corners. It's not perfect, but she looks a lot better than she did before.
Things to do before dropping in a 2.2
the_bard replied to Bob Nieuwsma's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake a look at the "back" of the engine: http://www.ultimatesubaru.org/forum/topic/114457-96-impr-obw-oil-leak-guess-what-i-found-on-back-of-engine/
Busted Rear Shock (Dial-up beware)
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn Bloom helped me out tonight via phone, and pointed me in the direction of what I figure is the right answer. RockAuto lists the KYB 341276 as fitting the 2003 Baja. The only rear shock they've got available for the 2006 Baja is a Monroe 71113, which seems to have a pretty bad reputation online. When Subaru lifted the 2004-2006 Baja's, I'm thinking they changed out that rear shock. I'll be waiting for warmer weather before I put in another set of shocks, though. It's cold out there.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope. That would've made sense, but no. I ordered them off Amazon, and found it odd that they had shipped from two different locations, in two different boxes. Hence my "let's pair these up and see if they physically match".
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCount this as a lesson learned, and experience under my belt. The old one was busted up. The shaft, as you can see below, separated at the top. The amount of rust at the break line makes me think it had been broken for a while. In case y'all didn't know already, that bend in the shaft ain't supposed to be there either . Now, that being said, I may have a different problem on my hands. I removed the obviously broken shock first, and installed the new one there. I didn't compare the two, since it would've been pretty difficult considering the shape of the original shock. However, I did make sure that both new shocks were identical. Problem is, when I took out the "good" shock on the passenger side, I did compare it to the old shock. This is what I found: The bottom spring mounts aren't the same height. Methinks I'll be blessed with more experience installing shocks at some point in the near future, probably as soon as the weather warms up. I'm no genius when it comes to struts, but I figure that's going to alter the ride height of the rear of the Baja. It shouldn't blow up on me, but it'll be something I want to correct in the near future (Please tell me if I'm wrong, though I'm dreading it). I believe John "Mudrat" Bloom put the lift on, at the same time as he installed the bumpers. I figure I'll get a hold of him and see if he used different shocks, or if he cut & welded those bottom mounts. *sigh*. Story of my life. Makes for good stories, though.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWoohoo! Old shock is out, new one is in. All I had to do is follow the recommendations above: pound the bolt back in, get the shock supported so it didn't travel with the bolt, and support it from underneath a bit. The spring was at such an angle there couldn't have been much weight on it, but I still wrapped it with a towel, strapped it in, and packed the area in with that grungy mattress and old pillows. By the time I got the bottom half of the shock out, the spring simply hung in place, so there could not have been much weight on it. Putting the new shock in wasn't bad, either. Compressing the spring is the most labor intensive bit, since I was taking my sweet time and being very careful to compress both sides at the same time. Pics to follow. I want to swap the other side first.
Oil Pan Seal - $11 and change?
the_bard replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have in my hand, right now, a trim cap for the Baja. Part #91067AE01A. It's a piece of molded plastic, about half an inch in diameter. Paid $10 for it. I just wanted to see what it looked like, since they're rumored to self-destruct pretty well if you try to remove one from an existing trim piece. Gonna see if I can't find some way to recreate them using a cheaper method...
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep. '06 Baja. I had enough room to get two compressors in, but because the spring's bent outwards, I couldn't get them 180 degrees apart. They were more like 90 degrees. If I can get the bottom half of the shock in its proper position, I'm hoping the spring will follow suit and give me enough room to get the compressors on proper. We'll see. The weather's supposed to turn cold and windy for the rest of the week. I'm not sure when I'll be in the mindset to brave the weather and get back at it. This business of being in your mid thirties, realizing you're not as young as you were a decade ago, and being all sore after working on the car all day long is for the birds. Now I know why Dad had kids. So he could lay under the car and have a gopher grab the tools for him. On a good note, the mortgage was submitted and we're waiting on a closing date. After that, I can start looking at building a garage in the back yard. Four walls, a roof, a level floor, and a wood stove. Nice big wood stove.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's the crux of the matter. I need it to unload slowly. If it unloads quickly, it's liable to launch the bottom of the shock downwards. I can stay put of that path well enough, but when it hits the pavement, all of my bets are off as to where it may go. Heh. All I gotta do is tilt the Baja up onto it's side. Then I can knock the bottom loose and fire the remants of the shock into a net. Sounds like a plan. Hmm... What if I used three or four of the straps I usually use for tying kayaks down? They've got that knurled knuckle bit that clamps down on the strap. I certainly don't trust them well enough to hold the spring compressed by themselves, but would their clamping action slow down the decompression event? My original thought was to use the temporary restraints long enough to get it off the Baja, then put the proper spring compressors on, letting me remove the temporary restraints and back off the compressors slowly.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike a gun with a closed chamber. Never assume it's safe. Thanks!
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm... Never thought about using hose clamps. They're likely to hold better than straps and zip ties. Good idea!
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI figured I'd put three straps on the spring itself. I'll pick up some long zip ties as well, and tie it down as much as possible, balancing the load across the spring. I'm not sure it'll hold until I try it, so running two (or more) other ratcheting straps from the spring to points on the body. Heartless is right about the salt. I love the way it eats ice; I hate the way it eats cars. The Albany area tends to throw it down like cheese on a pizza, at any chance of ice/snow. I'd rather have dirt/cinders thrown down at times, but I doubt many would agree with me. Most folks in the area seem to drive in the winter like it's still August.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBrake pads and rotors are on my to do list; that left rear pad is down more than I like. They're not rubbing, though, and the rotor's brake surface is smooth. Between the salt and sitting for a week or two, those rotors look worse than they are. I love the Northeast, but I don't like the "Cover *EVERYTHING* in salt!" approach that NY takes.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo kiddin' there. I'm erring on the side of caution. I'd rather secure it too much and spend extra time than not enough and have it try to go through me. I've got enough brains to treat it like a loaded gun and stay out of the path of the fire. What I can't control is how it may bounce if it does let go... So I don't want it to let go. That would be a bad day.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh.. I'm seeing what y'all are saying. The bottom of the shock was traveling with the bolt as I knocked it out, complicating the bolt binding. I had strapped the shock in, but only with one strap, which let it wander. I'll see if I can't knock that bolt back in, strap it like I had, and find some way to secure it against the rear arm as I knock that bolt back out. Got a three pound cross peen hammer. I'm out of shape... If I need a bigger hammer, my arm may fall off. I'm going to need more socket extensions after this, too. I've boogered the ends up good. One of these days I ought to hunt down some proper long drift punches.
the_bard replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpstate NY has some huge potholes. ;oD Nah, I had an indication last fall that it was going. Had a few suspicions regarding the handling on the back end, so I asked the local garage to check it out while they were chasing down a transmission noise for me. They gave the shocks a clean bill of health. The lower bushing started squeaking a couple weeks later. I soaked it with PB Blaster, and it quieted down. Then the top end got noisy... Soaked it, too, but it didn't help much. A week or two later, it quieted down again. When it did act up, it sounded just like a loud noisy bushing. Then it snapped driving into work two weeks ago or so. We're a couple of weeks away from closing on a house, so we've been putting all of our resources into that. Was hoping it was going to hold together long enough to let me change it out after the house purchase. The best laid plans of mice and men...
I've read over the other recent shock/strut thread. I'm getting a mild kick out of the brain games, thinking of the different ways shocks can fail. Well, I got one for you: ' Yep, it's bent into an angle. Not happy. when I got the wheel off, this is what I found: The shaft is that bit just hanging out in the spring, not connected on either end. Not happy. I got the spring restrained as best as I could, but I still don't feel safe working around it, not with the inherent limits of the shock removed. There's just not enough room in there to get a proper spring compressor on it. To pour salt into the wound, I wasn't able to get the lower bolt out of the rear arm, either. It's got another inch or so to travel, and it should pop out of the hole. I think the combination of the spring placing pressure, plus the angle of the forces involved have bound up that bolt. I spent hours hammering on it today, but just couldn't get it loose. I slapped the wheel back on and buttoned her up for the night. Seriously considering getting her down to the local garage (probably via flat bed... I don't want to chance driving it, have that spring pop loose, and go flying into somebody's windshield; most of that quarter mile is on a two lane bridge crossing a major river), all of a quarter of a mile away, and letting them properly secure the spring to keep it from flying off so they can remove that lower bolt. They may as well finish up the install of the shocks, too. I hate being --> <--- close and giving up, though. Any thoughts before I hang my head in shame, anybody have suggestions?
putting in new spark plus outback 2005
the_bard replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe way I see it, finding out the cost of spark plugs is fairly easy. Finding the right type is pretty easy. Heck, getting them out is pretty easy, once you figure out just the right combination of swivels, extensions, and wobbly sockets. Me, I'm scared to death of cross threading 'em when I put them in. That could end up being a PITA to deal with. So the next time I do plugs (I'm due for 'em in my Baja, so that'll be soon), I figure I'm going to try a trick I read about somewhere on here: Mark the depth of the socket assembly when the spark plug is fully installed, so I know how far the new plug should sit once it's in there. Then when I'm installing the new one, I plan on slipping a bit of surgical tubing over the terminal end of the plug, giving me just enough friction to get the plug started properly, but not enough to let me cross thread it. So goes the idea, at least.
Orange XV in Skagit River collapse
Yeah, I think bits of the bridge hit the XV. Not that it's any less impressive... betcha those bits of the bridge were pretty solid. I'd love to hear that conversation between the owner and his insurance company...
Have a major question that might get me flammed off the site...
http://www.amazon.com/Build-Metal-Working-Scrap-Complete/dp/1878087355/ref=sr_1_6?s=books&ie=UTF8&qid=1370691359&sr=1-6 Looks like a project, no doubt. Have fun!
Getting a wheel off the rim!
Ach. Yeah, I meant rotor. I was distracted by UPS dropping off my new clutch kit at the front door. Yep, that's my story and I'm stickin' to it. ;oD
